The EventGhost project is looking for translators!
Post by Bitmonster » Thu Nov 30, 2006 4:42 pm
EventGhost is fully multilingual and has a built-in language editor. The editor is so easy, that everybody should be able to understand and use it immediately. So if you master another language, you are predestinated to become a translator of EventGhost. You can also help to enhance my poor english for the default english translation with it or give better english descriptions of the actions.
To start the language editor, you have to use the "-translate" commandline option with the latest version of EventGhost. So you can easily create a shortcut to EventGhost.exe on your desktop with a path like this:
"C:\Program files\EventGhost\EventGhost.exe" -translate
After the window shows up, you simply have to use the menu command "Open..." to start with the language you want. If your language is not listed there, let me know and I will include it.
It would be hard to translate each and every plugin in the beginning, but it would be fine, if the translation could include the "core plugins" that are named "EventGhost", "System", "Window" and "Mouse".
When you think, your translation is complete enough to be included in the normal distribution, you can email me your language file.
(EDIT: The new board supports attachments. So you can simply attach the file here instead of sending it through email.)
Bartman
Post by Bartman » Thu Nov 30, 2006 6:49 pm
While exiting I get a message window with "Erros occured" telling me to check the log file for details.
This is the log.
EDIT: Log removed, because information no longer needed. Bitmonster.
Writing the log in the program directory will also cause problems with limited user accounts.
Post by Bitmonster » Thu Nov 30, 2006 8:27 pm
Build 801 should fix this problem.
Bob
Post by Bob » Wed Dec 13, 2006 6:04 pm
I've got an error. Here it is :
My version is :
Bob
Post by Bitmonster » Wed Dec 13, 2006 6:07 pm
The error seems to be caused by your custom plugin "XEventGhost". Can you mail me the source so I can look into it?
Bob
Post by Bob » Wed Dec 13, 2006 7:33 pm
It was written in the log and i haven't seen it. Sorry. :oops:
This plugin is no more used. It was a plugin to communicate with Xlobby, but I never found time to finish it.
But my bug is now fixed.
fidoboy
Post by fidoboy » Mon Jun 25, 2007 7:53 am
I've just discovered this program and it's really useful, many thanks for the effort, keep up the good work!. I can translate it into spanish. please, add the files to translate them...
Regards,
Re:
Post by Bitmonster » Fri Jul 06, 2007 3:19 pm
fidoboy wrote:I've just discovered this program and it's really useful, many thanks for the effort, keep up the good work!. I can translate it into spanish. please, add the files to translate them...
You don't need any extra files. Just set the language editor to spanish.
And since the new board supports attachments, you can simply attach the resulting language file here.
fredrik.jacobsson
Re: The EventGhost project is looking for translators!
Post by fredrik.jacobsson » Thu Aug 02, 2007 10:52 pm
I have done a swedish translation for EventGhost, including some of the plugins... :)
______________________
Fredrik Jacobsson
Telldus Technologies
http://www.telldus.se
sv_SV.py
(49.53 KiB) Downloaded 1199 times
Post by Bitmonster » Thu Aug 02, 2007 11:10 pm
fredrik.jacobsson wrote:I have done a swedish translation for EventGhost, including some of the plugins... :)
And I have included it in the latest beta. :)
Thanks for your contribution.
fredrik.jacobsson
Post by fredrik.jacobsson » Wed Aug 08, 2007 8:37 am
Found some faulty translations, my bad, here comes a new translationfile.
sv_SV.py
(49.53 KiB) Downloaded 1198 times
Post by Pako » Fri Oct 19, 2007 2:42 pm
I'm on base version 0.3.6.1145 made updating of file with Czech language.
cs_CS.py
(74.62 KiB) Downloaded 1148 times
Post by Bitmonster » Sat Oct 20, 2007 11:47 am
Thanks. Added to 0.3.4.1149.
Post by Pako » Mon Oct 29, 2007 12:16 pm
New Czech language file (including MediaMonkey).
cs_CS.py
(84.87 KiB) Downloaded 1092 times
Post by Pako » Fri Nov 02, 2007 1:14 pm
New Czech language file (including MediaMonkey 0.1.1).
cs_CS.py
(85.81 KiB) Downloaded 1110 times
