ESP-IO-BBT
ESP-IO-BBT
Post by Pako » Mon Sep 25, 2017 3:44 pm
I've finished the first version of the next plugin.
This is almost the same as ESP-IO, but it brings a whole new feature:
  • The device may be in a completely different network than EventGhost.
  • Only Internet connectivity at both ends is a condition.
  • No public IP or VPN or port redirection is required.
This is possible thanks to the Beebotte service.
All that's needed for this project is on my GitHub.
ESP-IO-BBT.egplugin
Version 0.0.1
(174.29 KiB) Downloaded 157 times
Re: ESP-IO-BBT
Post by kgschlosser » Mon Sep 25, 2017 4:35 pm
ut oh Pako is hooked on the little esp modules.
Have you tried micro python yet?
User1306
Re: ESP-IO-BBT
Post by User1306 » Tue Sep 26, 2017 3:00 pm
this is amazing i really cant to try it.
i was wondering if maybe in the future you make a version where we can attached 0.96 Inch OLED display (they are super cheap and easy to work with). given the small size of the ESP and the oled display we can make a very small monitor to send text to.
i can add this in my car and tether my phone to it, to know what's happening in my house.
Re: ESP-IO-BBT
Post by Pako » Wed Sep 27, 2017 8:28 am
i was wondering if maybe in the future you make a version where we can attached 0.96 Inch OLED display (they are super cheap and easy to work with). given the small size of the ESP and the oled display we can make a very small monitor to send text to ...
A similar idea was already here: Re: Digispark-LCD
I think it should be nothing difficult. I'll order one OLED display and we'll see ...
User1306
Re: ESP-IO-BBT
Post by User1306 » Thu Sep 28, 2017 2:09 pm
Thanks Pako, i'm really looking forward to that, i hope it wont be a lot of work for you.
if you need help testing things, i'm more than happy too
Re: ESP-IO-BBT
Post by Pako » Thu Nov 09, 2017 11:46 am
Finally done !
ESP-OLED
Please, test it !
User1306
Re: ESP-IO-BBT
Post by User1306 » Thu Nov 09, 2017 1:05 pm
Amazing, i have been checking the forum for this since we talked about.
cant wait to test it :)
thanks for the hard work
