vuego
Post by vuego » Tue May 31, 2016 4:12 am
I would say, don't throw away your dusk relay just yet until you've made sure you're happy with SunTracker :)
SunTracker simply calculates the sunrise and sunset according to the coordinates you input and the computers date and time.
Post by krambriw » Tue May 31, 2016 4:27 am
The sunrise/sunset is internally calculated by the plugin itself so no dependencies to external data from internet sources. If you start to use weather compensation, the weather data is fetched from Weather.com. But this is just used to calculate offsets in the actions and if it fails to get data, it will work anyway but offsets can then of course not be calculated.
Regarding the reliability, I hope other users can comment on this better, I have no idea how many are using it but it is many. Myself I have had it running in my home automation system since 2008. During the years many new features and improvements have been added and I feel it is very stable. Whenever there would be a problem, I would be notified here in this forum. Most of the time that has happened was when the weather service stopped working (we used Yahoo earlier) or when users had a suggestion for a new feature.
Post by krambriw » Mon Aug 22, 2016 9:14 am
New version released
Compatible with EventGhost 0.5.x
User1306
Post by User1306 » Wed Sep 07, 2016 1:07 pm
hello
i keep getting this error below when i try to check "GetForecasts"
15:06:22      Error in Action: "SunTracker: GetForecasts"
15:06:22      Traceback (most recent call last) (1722):
15:06:22        File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionBase.py", line 170, in CallWrapper
15:06:22          return self(*args)
15:06:22        File "C:\Program Files (x86)\EventGhost\plugins\SunTracker\__init__.py", line 5431, in __call__
15:06:22          return self.plugin.weather_data['forecasts']
15:06:22      KeyError: 'forecasts'
i tried updated my location but it didnt help
any idea?
thanks
Post by krambriw » Wed Sep 07, 2016 3:07 pm
Yes, ideas we do have, there is a problem with Weather.com
Check this link
https://www.reddit.com/r/Rainmeter/comm ... _provided/
Post by krambriw » Wed Sep 07, 2016 6:03 pm
One possibility is if you try another location/city in your neighborhood, it might happen it works
User1306
Post by User1306 » Thu Sep 08, 2016 7:52 am
thanks for the feedback, i'll try a different location close by.
thanks
jachin99
Post by jachin99 » Wed Sep 21, 2016 3:09 am
I'm getting undefined no matter what value I put into the location ID. I even tried the NY location ID at the start of the thread. I have seen other posts bring this up so I'm guessing its a common problem. Anyone find any fixes for this yet?
Post by krambriw » Wed Sep 21, 2016 4:05 am
Simple check: are you using the latest version? If you are using the version included in EG distribution, you need to update. Download latest version from my link below
jachin99
Post by jachin99 » Wed Sep 21, 2016 5:37 pm
Updated, and got it working. One thing to note is if you do an internet search of weather.com and your city, the url will come back differently. The best way to find your URL is to go to weather.com, search for your city.
Post by krambriw » Thu Sep 22, 2016 5:19 am
Yepp, that's the way.
Now let's hope for continued nice autumn weather
eirik226
Post by eirik226 » Fri Nov 25, 2016 11:52 pm
I have some troubles with this plugin - i am fairly certain I've updated it, but seem to have a few issues with the EGplugin format.
Im at version 1.5.6 - is that correct? EDIT: I see now, that this is not the latest plugin. I'll try a few more times with the EGplugin format, just thought of a mistake I might have made.
The trouble I am having is:
Main.Weather Condition: ''
This event - sometimes it says something else, like mostly cloudy etc - but most of the time it's just this: Main.Weather Condition: ''
Just one " - does anyone know a fix for this? The location should also be set correctly.
Post by krambriw » Sun Nov 27, 2016 2:27 pm
The thing you can try to is to find a better and more reliable weather station. Try another location that is pretty close to where you live.
eirik226
Post by eirik226 » Sun Nov 27, 2016 4:40 pm
krambriw wrote:The thing you can try to is to find a better and more reliable weather station. Try another location that is pretty close to where you live.
I did that and it worked! But as the closest location I could find is pretty far away it's not that reliable.
I'll see if I can find something else, thank you :)
yokel22
Post by yokel22 » Sun Nov 27, 2016 8:57 pm
I'm having problems getting non metric values returned from this plugin. My locations are set using (US) zipcodes & the plugin is set for non-metric. It still always returns metric. Also, is it possible to get more than 5 days returned on the forecast?
