J. River Media Center Command Sender
Post by kgschlosser » Sat Aug 19, 2017 5:35 am
Version: 0.2
This is a very basic plugin. all it does is sends commands into J. River Media Center (JRMC)
This plugin is a work in progress so some of the commands may not function at this point in time. All of the JRMC command base that is available are in this plugin.
This plugin is not like other JRMC plugins in that it sends the commands directly to the program instead of using keyboard emulation, which can be problematic due to window focus.
There is zone support as well.
Some of the commands have /require additional parameters. these parameters I have not documented so you will have to play around with it. If there is a required parameter and you have not configured the action you will be informed of a problem.
This plugin will only use the highest version of JRMC that you have installed. So if you have more then one copy.. for the time being it will only work with the newest one.
There are going to be problems with this plugin as it is new. If you encounter an issue please edit the plugin's __init__.py file and near the top you will see DEBUG = False. change the False to True. and turn on debugging inside of EG as well. then replicate the issue and paste the log output in a post.
to install simply double click the file.
JRiverCommands-0.2.egplugin
(18.61 KiB) Downloaded 52 times
jachin99
Re: J. River Media Center Command Sender
Post by jachin99 » Sat Aug 19, 2017 9:16 pm
Just to caveat off of the multiple versions of JRMC, unless someone is testing a new version there aren't really any good to have an old and new versions of JRiver. Even then unless there is a weird bug someone can't live with in a new version, they would just upgrade the other machines so I don't see that being worth your time to support. Did you type this whole thing up, or did they have a file with the commands already available?
Post by kgschlosser » Sat Aug 19, 2017 11:55 pm
jachin99 wrote:Just to caveat off of the multiple versions of JRMC, unless someone is testing a new version there aren't really any good to have an old and new versions of JRiver. Even then unless there is a weird bug someone can't live with in a new version, they would just upgrade the other machines so I don't see that being worth your time to support. Did you type this whole thing up, or did they have a file with the commands already available?
as far as the version support goes. It is far simpler to iterate the registry then to key out specific reg keys for the different versions. so adding support for multiple versions is not that difficult to do because i have to iterate the registry anyways to get the version data. so to simply add a drop down to the plugin config so the user can select which one they want to use is a snap.
They had the information on their website. so I had to write code to parse the web page. that got me the constants. then I had to write another script to parse the page again to grab the value daya and to change them. then i had to write another script to combine the information from the first 2 scripts. then manually go through them and correct any typos. I also added to the constants for basic things like on and on. or things with a limited number of values.
I probably had to key out 500 lines of code to get the data and format it. then i had to go through all of the data and correct the little oddities and change things up a bit to make it easier to handle.
jachin99
Post by jachin99 » Sun Aug 20, 2017 7:05 pm
I tested it on JRMC V 23.36 and EG .5.0 RC 4 and it works great but you need to make sure you tell each command which zone you want to execute it. I can see this getting pretty confusing for some because I'm pretty sure you name your zones in JRMC whereas EG displays a zone number.
Post by kgschlosser » Sun Aug 20, 2017 7:33 pm
the API only allows for sending a digit not a name.
jachin99
Post by jachin99 » Sun Aug 20, 2017 7:46 pm
There was a plugin out there that broadcasted JRMC events also. How hard would it be to roll that plugin into this one, or vice versa?
Post by kgschlosser » Mon Aug 21, 2017 3:03 am
the other plugin only gave you events for play stop things like that.. JMRC supports a whole lot of events. and I did plan on adding that. In the future. I am pretty sure there is a way to leverage JRMC so we can get things like playlist names and zone names. This is all going to be added in the future. I wanted to get a proper command set working without the need to use keyboard emulation.
And the plugin you are talking about has quite a bit of voodoo code in it. it is going to be easier to start from scratch then to try and figure out what the other developer did to bring the 2 together.
jachin99
Post by jachin99 » Wed Aug 08, 2018 8:05 pm
I just installed plugin on version 24, and it looks like its throwing an error because it can't find the registry key. I looked up the registry key on my machine, and it looks like its in the same location. The only difference i can think of is one is for my old setup, the old key was probably nested under J. River/Media Core/Installations/ Media Center 23 where my new installation is under //Installations/Media Center 24. Here is the error log:
  File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginInstanceInfo.py", line 102, in CreateInstance
    plugin.__init__()
  File "C:\ProgramData\EventGhost\plugins\JRiverCommands\__init__.py", line 3197, in __init__
    key = _winreg.OpenKey(_winreg.HKEY_LOCAL_MACHINE, reg_path)
WindowsError: [Error 2] The system cannot find the file specified
I went to that line in the init_py file for the plugin, and here is the class you have defined for it.
class JRiverCommand(eg.PluginBase):
    def __init__(self):
        high_version = ''
        self.jriver_exe = None
        self.jriver_cwd = None
        reg_path = r'Software\J. River\Media Core\Installations'
        index = 0
        while True:
            try:
                sub_key = _winreg.OpenKey(
                    key,
                    _winreg.EnumKey(key, index)
                version = _winreg.QueryValueEx(sub_key, 'Version')
                if version > high_version:
                    high_version = version
                    self.jriver_exe = _winreg.QueryValueEx(
                        sub_key,
                        'Launcher Name'
                    )[0]
                    self.jriver_cwd = _winreg.QueryValueEx(
                        sub_key,
                        'Path'
                    )[0]
                index += 1
            except WindowsError:
                break
        if self.jriver_exe is None:
            eg.PrintError('J. River Media Center is not installed.')
        action_list = ()
        for command_description in sorted(COMMANDS.keys()):
            command_data = COMMANDS[command_description]
            code = command_data['code']
            value = command_data['value']
            class_name = 'fn' + command_description.replace(' ', '_').upper()
            action_list += ((
                SendCommand,
                class_name,
                command_description,
                [code, value]
        self.AddActionsFromList(action_list)
    def __stop__(self):
        pass
    def __start__(self):
        pass
Finally, here is a screenshot of the key I believe is being queried
With this error, I don't even get an option to add macros for JRMC. Thanks.
jachin99
Post by jachin99 » Wed Aug 08, 2018 8:10 pm
And my brain just kicked in, and I believe I have figured out the problem. My old install was a 32 bit JRiver whereas my new install is 64 bit. Could this be my problem? The path key is different to account for the difference between 64 and 32 bit versions but I don't know enough python to fix it.
Post by kgschlosser » Thu Aug 09, 2018 8:25 am
where the registry key is typed into the plugin.
it will say SOFTWARE
you need to change out the SOFTWARE to read SOFTWARE\\Wow6432Node
Post by kgschlosser » Thu Aug 09, 2018 8:27 am
becomes
reg_path = r'Software\Wow6432Node\J. River\Media Core\Installations'
jachin99
Post by jachin99 » Thu Aug 09, 2018 6:06 pm
Thanks for looking at this but unfortunately that isn't working either. Would there have to be more than one version installed for this function correctly since it enumerates through them? Here is a screenshot of the wow 6432 key
Post by kgschlosser » Thu Aug 09, 2018 9:27 pm
do me a favor and do a reg dump of software\j.river. and attach the file to a post for me.
This way i can make sure that everything is there.
jachin99
Post by jachin99 » Thu Aug 09, 2018 9:31 pm
Here it is and thanks
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Installer]
"Run Auto Install"=dword:00000000
"Install - Install Count"=dword:00000002
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins]
"Webpages"="1.0.17"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Display]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Display\3D Visualizations]
"IVersion"=dword:00000003
"Company"="JRiver, Inc."
"Path"="[Install Path]Visualizations\\vis_main.dll"
"Index"=dword:00000001
"Version"="1.0.1"
"URL"="jriver.com"
"Copyright"="Copyright (C) JRiver, Inc. 1998-2018"
"Description"="JRiver main display plug-ins."
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Display\Track Info]
"Index"=dword:00000000
"Version"="1.0.1"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Display\Visualizations]
"Index"=dword:00000002
"Version"="1.0.1"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Adaptive Volume]
"IVersion"=dword:00000001
"Path"="[Install Path]Plugins\\dsp_main.dll"
"Index"=dword:0000000b
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Adaptive Volume (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Analyzer]
"Index"=dword:00000007
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Analyzer (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Convolution]
"Index"=dword:00000009
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Convolution (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Effects]
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Effects (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Equalizer]
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Equalizer (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Headphones]
"Index"=dword:00000005
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Headphones (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Output Format]
"Index"=dword:00000003
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Output Format (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Parametric Equalizer]
"Index"=dword:00000008
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Parametric Equalizer (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Parametric Equalizer 2]
"Index"=dword:0000000a
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Parametric Equalizer 2 (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Room Correction]
"Index"=dword:00000006
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Room Correction (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Tempo & Pitch]
"Index"=dword:00000004
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Tempo & Pitch (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\DSP\Volume Leveling]
"Version"="1.1.6"
"URL"="jriver.com"
"Description"="Volume Leveling (part of JRiver main DSP plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\AIFF Encoder]
"IVersion"=dword:00000005
"Path"="[Install Path]Plugins\\enc_main.dll"
"Version"="1.0.1"
"Ext"="aif"
"URL"="jriver.com"
"Description"="JRiver main encoder plug-ins."
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\Apple Lossless Audio Codec (ALAC)]
"Version"="1.0.1"
"Ext"="m4a"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\DSD]
"Version"="1.0.1"
"Ext"="dsf"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\External Encoder]
"Version"="1.0.1"
"Ext"=""
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\FLAC Encoder]
"Version"="1.0.1"
"Ext"="flac"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\Monkey's Audio (APE)]
"Version"="1.0.1"
"Ext"="ape"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\MP3 Encoder]
"Version"="1.0.1"
"Ext"="mp3"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\Musepack (MPC)]
"Version"="1.0.1"
"Ext"="mpc"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\Ogg Vorbis]
"Version"="1.0.1"
"Ext"="ogg"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\Uncompressed Wave]
"Version"="1.0.1"
"Ext"="wav"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\WavPack]
"Version"="1.0.1"
"Ext"="wv"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Encoders\Windows Media]
"Version"="1.0.1"
"Ext"="wma"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Handheld]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Handheld\Portable Drives]
"IVersion"=dword:00000007
"Version"="12.0.1"
"URL"="jriver.com"
"Configurable"=dword:00000000
"Path"="[Install Path]Plugins\\hh_portable.dll"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\3GA]
"Path"="[Install Path]Plugins\\in_mp4.dll"
"Plugin Description"="MP4 & AAC input plug-in"
"File Description"=" 3GA Audio File (*.3ga)"
"Name"="MP4 & AAC input plug-in"
"IVersion"=dword:00000004
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\AA]
"Path"="[Install Path]Plugins\\in_aa.dll"
"Plugin Description"="Audible Plugin"
"File Description"=" Audible Audio File (*.aa)"
"Name"="Audible Plugin"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\AAC]
"File Description"=" AAC Audio File (*.aac)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\AIF]
"Path"="[Install Path]Plugins\\in_wav.dll"
"Plugin Description"="WAV & AIFF input plug-in"
"File Description"=" AIFF Audio File (*.aif)"
"Name"="WAV & AIFF input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\AIFC]
"File Description"=" AIFF Audio File (*.aifc)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\AIFF]
"File Description"=" AIFF Audio File (*.aiff)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\APE]
"Path"="[Install Path]Plugins\\in_ape.dll"
"Plugin Description"="APE Plugin (v4.34)"
"File Description"=" Monkey's Audio File (*.APE)"
"Name"="APE Plugin (v4.34)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\APL]
"File Description"=" Monkey's Audio File (*.APL)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\AU]
"File Description"=" AU Audio File (*.au)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\AUDIOTEST]
"Path"="[Install Path]Plugins\\in_audiotest.dll"
"Plugin Description"="Audio test input plug-in"
"File Description"=" Audio Test (*.audiotest)"
"Name"="Audio test input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\CAF]
"File Description"=" Core Audio Format File (*.caf)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\CDA]
"Path"="[Install Path]Plugins\\in_cda.dll"
"Plugin Description"="CD audio input plug-in"
"File Description"=" CDA File (*.CDA)"
"Name"="CD audio input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\DFF]
"Path"="[Install Path]Plugins\\in_dsd.dll"
"Plugin Description"="DSD input plug-in"
"File Description"=" Direct Stream Digital Interchange File Format (*.dff)"
"Name"="DSD input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\DSF]
"File Description"=" Direct Stream Digital Stream File (*.dsf)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\FLAC]
"Path"="[Install Path]Plugins\\in_flac.dll"
"Plugin Description"="FLAC input plug-in"
"File Description"="Free Lossless Audio Codec (*.flac)"
"Name"="FLAC input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\FLAC16]
"File Description"="Free Lossless Audio Codec (*.flac16)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\FLAC24]
"File Description"="Free Lossless Audio Codec (*.flac24)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\L16]
"File Description"=" L16 Audio File (*.l16)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\L24]
"File Description"=" L24 Audio File (*.l24)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\M4A]
"File Description"=" Apple AAC / ALAC Audio File (*.m4a)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\MAC]
"File Description"=" Monkey's Audio File (*.MAC)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\MP+]
"Path"="[Install Path]Plugins\\in_mpc.dll"
"Plugin Description"="MPC input plug-in"
"File Description"="MPEGplus file"
"Name"="MPC input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\MP3]
"Path"="[Install Path]Plugins\\in_mp3.dll"
"Plugin Description"="MP3 input plug-in"
"File Description"=" MP3 Audio File (*.MP3)"
"Name"="MP3 input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\MP4]
"File Description"=" Apple AAC / ALAC Audio File (*.mp4)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\MPC]
"File Description"="Musepack file"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\MPGA]
"File Description"=" MPEG Audio File (*.MPGA)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\MPP]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\OGG]
"Path"="[Install Path]Plugins\\in_ogg.dll"
"Plugin Description"="OGG input plug-in"
"File Description"=" Ogg Vorbis File (*.OGG)"
"Name"="OGG input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\SACD]
"File Description"=" Super Audio CD ISO (*.sacd)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\SND]
"File Description"=" SND Audio File (*.snd)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\W64]
"File Description"=" W64 Audio File (*.w64)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\WAV]
"File Description"=" Waveform Audio File (*.wav)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\WMA]
"Path"="[Install Path]Plugins\\in_wma.dll"
"Plugin Description"="WMA input plug-in"
"File Description"=" WMA Audio File (*.WMA)"
"Name"="WMA input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Input\WV]
"Path"="[Install Path]Plugins\\in_wavpack.dll"
"Plugin Description"="WavPack input plug-in"
"File Description"="WavPack (*.wv)"
"Name"="WavPack input plug-in"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Interface]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Interface\TiVo Server]
"CLSID"="{20592666-1B90-46A6-9DD7-F88F833EDEE0}"
"Path"="[Install Path]Plugins\\server_tivo.dll"
"Version"="1.0.35"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Live]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Live\ASIO]
"Path"="[Install Path]Plugins\\live_main.dll"
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="ASIO (part of main JRiver main live plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Live\IPC]
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="IPC (part of main JRiver main live plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Live\Loopback]
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="Loopback (part of main JRiver main live plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Output]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Output\ASIO]
"Path"="[Install Path]Plugins\\out_main.dll"
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="ASIO (part of main JRiver main output plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Output\Direct Sound]
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="Direct Sound (part of main JRiver main output plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Output\Disk Writer]
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="Disk Writer (part of main JRiver main output plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Output\Kernel Streaming]
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="Kernel Streaming (part of main JRiver main output plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Output\Network Streamer]
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="Network Streamer (part of main JRiver main output plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Output\Null Output]
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="Null Output (part of main JRiver main output plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Output\WASAPI]
"Version"="1.0.7"
"URL"="jriver.com"
"Description"="WASAPI (part of main JRiver main output plug-ins)"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\RemoteControl]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\RemoteControl\IRMAN]
"DisplayName"="IRMAN"
"EnableOnInstall"="0"
"Path"="[Install Path]Plugins\\rc_main.dll"
"Version"="1.0.1"
"URL"="jriver.com"
"Description"="JRiver main remote control plug-ins."
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\RemoteControl\MCE]
"DisplayName"="Microsoft MCE"
"EnableOnInstall"="1"
"Version"="1.0.1"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\RemoteControl\Raw Input]
"DisplayName"="Remote, keyboard, gamepad or other HID"
"Version"="1.0.1"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\RemoteControl\USB-UUIRT]
"DisplayName"="USB-UUIRT"
"Version"="1.0.1"
"URL"="jriver.com"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\System]
"Equalizer"="installed"
"Effects"="installed"
"Volume Leveling"="installed"
"Output Format"="installed"
"Tempo & Pitch"="installed"
"Headphones"="installed"
"Room Correction"="installed"
"Analyzer"="installed"
"Parametric Equalizer"="installed"
"Convolution"="installed"
"Parametric Equalizer 2"="installed"
"Adaptive Volume"="installed"
"Webpages"="installed"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Theater View]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Theater View\Lighting]
"IVersion"=dword:0002e668
"Path"="[Install Path]Plugins\\tv_lighting.dll"
"Version"="1.0.1"
"URL"="jriver.com"
"Description"="Theater View Lights plug-in."
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Theater View\News]
"Path"="[Install Path]Plugins\\tv_news.dll"
"Version"="1.0.1"
"URL"="jriver.com"
"Description"="Theater View RSS plug-in."
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Theater View\Weather]
"Path"="[Install Path]Plugins\\tv_weather.dll"
"Version"="1.0.1"
"URL"="jriver.com"
"Description"="Theater View Weather plug-in."
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\APE Plugin (v4.34)]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\APL"
"1"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\MAC"
"2"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\APE"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\Audible Plugin]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\AA"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\Audio test input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\AUDIOTEST"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\CD audio input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\CDA"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\DSD input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\SACD"
"1"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\DSF"
"2"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\DFF"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\FLAC input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\FLAC24"
"1"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\FLAC16"
"2"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\FLAC"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\MP3 input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\MPGA"
"1"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\MP3"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\MP4 & AAC input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\3GA"
"1"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\AAC"
"2"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\MP4"
"3"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\M4A"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\MPC input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\MP+"
"1"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\MPP"
"2"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\MPC"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\OGG input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\OGG"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\WAV & AIFF input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\CAF"
"1"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\W64"
"2"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\SND"
"3"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\AU"
"4"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\L24"
"5"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\L16"
"6"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\AIFC"
"7"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\AIFF"
"8"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\AIF"
"9"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\WAV"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\WavPack input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\WV"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\Webpages]
"0"="VSoftware\\J. River\\Media Center 24\\Plugins\\Webpages"
"1"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\main.css"
"2"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\index.html"
"3"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\yellow_corner4.gif"
"4"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\yellow_corner2.gif"
"5"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\subscribe.gif"
"6"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\google.gif"
"7"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\dark_corner3.gif"
"8"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\dark_corner1.gif"
"9"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\button_search.gif"
"10"="F[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\bg_topb.gif"
"11"="D[Install Path]Data\\Default Webpages\\English\\Web Media\\images\\"
"12"="D[Install Path]Data\\Default Webpages\\English\\Web Media\\"
"13"="F[Install Path]Data\\Default Webpages\\English\\TV Tuner\\index.html"
"14"="D[Install Path]Data\\Default Webpages\\English\\TV Tuner\\"
"15"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\PreviewSmall.png"
"16"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\Preview.png"
"17"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\Play.png"
"18"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\home.html"
"19"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\Details.png"
"20"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\cd_stack.png"
"21"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\Background.png"
"22"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\5stars.png"
"23"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\4stars.png"
"24"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\3stars.png"
"25"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\2stars.png"
"26"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\1stars.png"
"27"="F[Install Path]Data\\Default Webpages\\English\\Suggest\\0stars.png"
"28"="D[Install Path]Data\\Default Webpages\\English\\Suggest\\"
"29"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\main.css"
"30"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\index.html"
"31"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\services.gif"
"32"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\pink_corner4.gif"
"33"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\pink_corner2.gif"
"34"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\google.gif"
"35"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\dark_corner3.gif"
"36"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\dark_corner1.gif"
"37"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\button_search.gif"
"38"="F[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\bg_topb.gif"
"39"="D[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\images\\"
"40"="D[Install Path]Data\\Default Webpages\\English\\Services and Plug-ins\\"
"41"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\main.css"
"42"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\index.html"
"43"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\yellow_corner4.gif"
"44"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\yellow_corner2.gif"
"45"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\subscribe.gif"
"46"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\google.gif"
"47"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\dark_corner3.gif"
"48"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\dark_corner1.gif"
"49"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\button_search.gif"
"50"="F[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\bg_topb.gif"
"51"="D[Install Path]Data\\Default Webpages\\English\\Podcasts\\images\\"
"52"="D[Install Path]Data\\Default Webpages\\English\\Podcasts\\"
"53"="F[Install Path]Data\\Default Webpages\\English\\Playlists\\main.css"
"54"="F[Install Path]Data\\Default Webpages\\English\\Playlists\\index.html"
"55"="F[Install Path]Data\\Default Webpages\\English\\Playlists\\images\\green_corner4.gif"
"56"="F[Install Path]Data\\Default Webpages\\English\\Playlists\\images\\green_corner2.gif"
"57"="F[Install Path]Data\\Default Webpages\\English\\Playlists\\images\\dark_corner3.gif"
"58"="F[Install Path]Data\\Default Webpages\\English\\Playlists\\images\\dark_corner1.gif"
"59"="F[Install Path]Data\\Default Webpages\\English\\Playlists\\images\\bg_topb.gif"
"60"="D[Install Path]Data\\Default Webpages\\English\\Playlists\\images\\"
"61"="D[Install Path]Data\\Default Webpages\\English\\Playlists\\"
"62"="F[Install Path]Data\\Default Webpages\\English\\No Internet\\index.html"
"63"="F[Install Path]Data\\Default Webpages\\English\\No Internet\\images\\NoInternet.gif"
"64"="D[Install Path]Data\\Default Webpages\\English\\No Internet\\images\\"
"65"="D[Install Path]Data\\Default Webpages\\English\\No Internet\\"
"66"="F[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\main.css"
"67"="F[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\index.html"
"68"="F[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\images\\dark_corner3.gif"
"69"="F[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\images\\dark_corner1.gif"
"70"="F[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\images\\blue_corner4.gif"
"71"="F[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\images\\blue_corner2.gif"
"72"="F[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\images\\bg_topb.gif"
"73"="D[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\images\\"
"74"="D[Install Path]Data\\Default Webpages\\English\\Drives and Devices\\"
"75"="D[Install Path]Data\\Default Webpages\\English\\"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Center 24\Plugins\Uninstall\WMA input plug-in]
"0"="KSoftware\\J. River\\Media Center 24\\Plugins\\Input\\WMA"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Core]
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Core\Installations]
@="Media Center 24"
[HKEY_LOCAL_MACHINE\SOFTWARE\J. River\Media Core\Installations\Media Center 24]
"Path"="C:\\Program Files\\J River\\Media Center 24\\"
"Version"="24.0.45"
"OS Version"=dword:000003f1
"Launcher Name"="MC24.exe"
"Uninstall Key"="Media Center 24 (64-bit)"
"GUID"="{2C3D755E-F077-404F-9129-AA5A58471EC7}"
Post by kgschlosser » Thu Aug 09, 2018 10:26 pm
Try replacing the beginning section of the __init__ definition in the jRiverCommand class with the code below
def __init__(self):
        from pkg_resources import parse_version
        high_version = None
        index = 0
        try:
            while True:
                    key,
                if (
                    high_version is None or
                    parse_version(version) > parse_version(high_version)
                        sub_key,
                        'Launcher Name'
                    )[0]
                        sub_key,
                        'Path'
                    )[0]
                index += 1
            pass
