Set Persistent Variable in Webserver HTTP Event
neilmahaseth
Post by neilmahaseth » Fri Jun 09, 2017 11:22 am
I am new to EventGhost so please excuse me if this is very easy. Is there a way to set Webserver Persistent Variable using a HTTP Event through say a Get Parameter or a Post Parameter.
Basically what I am trying to achieve is create a http webserver event which will set key value which in turn will be passed to the keyboard emulation. So instead of creating separate events for emulating different key press. I am looking to pass the key to emulate dynamically through Http GET/ Post request. Any help would be greatly appreciated.
neilmahaseth
Re: Set Persistent Variable in Webserver HTTP Event
Post by neilmahaseth » Fri Jun 09, 2017 2:40 pm
Ok after a bit of tinkering and a couple of google searches I found the solution. No need for setting the persistent variable.
Just call the web server address using the following syntax. If you are accessing from the local machine. Then http://localhost/?key&h
In this key will be the event name and the string after & will be passed as {eg.event.payload[0]}. So create a macro with the trigger event as HTTP.key and then in Emulate Keystrokes in text to type enter {eg.event.payload[0]}.
Hope that helps someone.
