RDM6300
RDM6300
Post by Pako » Sun May 28, 2017 6:56 am
I created another plugin. This time it is hardware plugin that receives events from RFID readers RDM6300.
This is a very inexpensive module that is compatible with EM4100 (125 kHz) tags. Plugin supports multiple readers. You can name your tags, so events will be much more human readable.
In my case, reader is connected to a PC using the Silabs CP2102 USB/serial converter.
Connection is more than simple:
All necessary files (including EventGhost plugin) can be found in the Github repository.
