Text Messaging
holdestmade
Re: Text Messaging
Post by holdestmade » Wed Jul 19, 2017 1:15 pm
KG, not spotted this before, so am giving it a try,
Could you add Vodafone UK ?
Simon
Re: Text Messaging
Post by kgschlosser » Wed Jul 19, 2017 8:40 pm
@Simon
I thought that Vodafone UK was in there.. I could have mislabeled it.. who knows.. let me check. and if it is not in there i will add it. if it is in there i will relabel it.
Re: Text Messaging
Post by kgschlosser » Wed Jul 19, 2017 8:55 pm
it has been added. well it was already there. so relabeled US and UK use the same server with Vodafone
Re: Text Messaging
Post by kgschlosser » Thu Jul 20, 2017 7:38 am
I am updating this plugin I just have to bug test it. but what I have done is I have separated the carrier selection by country. and then by carrier, and then by e-mail gateway.
I am also adding a whole slew of additional carriers to the list and here are the totals
there are 58 countries in the list
with 317 carriers
and a total of 517 e-mail to mms/sms gateways
I will post the updated version later today
Re: Text Messaging
Post by kgschlosser » Fri Jul 21, 2017 3:35 am
OK I updated the plugin. it's on the first post
holdestmade
Re: Text Messaging
Post by holdestmade » Fri Jul 21, 2017 11:22 am
Brilliant, cheers, I'll give it a go.
Simon
Re: Text Messaging
Post by kgschlosser » Fri Jul 21, 2017 2:43 pm
sweet let me know what you come up with. and if it works right or not.
holdestmade
Re: Text Messaging
Post by holdestmade » Wed Jul 26, 2017 7:47 pm
Hey,
Given this a go but cannot get it to send a text.
I get an email saying:
Address not found
Your message wasn't delivered to ###########@vodafone.net because the address couldn't be found. Check for typos or unnecessary spaces and try again.
The response from the remote server was:
550 5.1.1 <##########@vodafone.net>: Recipient address rejected: vodafone.net
I guess it is sending to google OK as I'm getting an email ?
What format is required for the phone number ?
Any ideas ?
Cheers
Re: Text Messaging
Post by kgschlosser » Wed Jul 26, 2017 10:39 pm
How this works is in the plugin config you will enter the SMTP and port of whatever e-mail server you choose to use. there are settings for using different types of authentications. The information that is factory set in the plugin is to use Googles GMain servers. for this to work you will have to make sure that you have SMTP turned on in your e-mail settings on google's site. and then enter your gmail login information into the plugin. it uses the SMTP server entered to relay a message to an e-mail to sms/mms gateway that the phone carrier has.
the format of the phone number in the US is
123 456 7890
area code exchange subscriber
or a 3-3-4 number set
now what I have discovered about vodaphone is this
44##########@vodafone.net
but you have to do this before you can use it.
dial 242 for info. activate via website
I will update the plugin to automatically add the 44 but for the time being manually enter it after you activate via the website.
holdestmade
Re: Text Messaging
Post by holdestmade » Thu Jul 27, 2017 8:45 am
Thanks for you help, just spoke to vodafone and apparently they have withdrawn SMS gateway service in the UK.
Never mind.
Cheers
Re: Text Messaging
Post by kgschlosser » Thu Jul 27, 2017 2:15 pm
ohhhh that stinks. why would they do that???
there is another option. you can use the google voice plugin. if you have a google voice account. from that you can send a text message from the google voice phone number to your vodaphone number.
Septik
Re: Text Messaging
Post by Septik » Thu Oct 26, 2017 10:52 pm
Wow, this is pretty awesome. Gave it a shot just now with my own number, and it's unfortunately not working for me. My carrier is Telia (Norwegian), who semi-recently changed their name from NetCom. I tried manually sending a couple of e-mails to mynumber@sms.netcom.no as well as mynumber@sms.telia.no. With the former, nothing at all happened. With the latter, I got an automated reply that boils down to:
550 5.7.1 <mynumber@sms.telia.no>... Relaying denied
Can I somehow help you troubleshoot this?
Re: Text Messaging
Post by kgschlosser » Fri Oct 27, 2017 2:00 am
you would need to call Telia and ask them this exact question "How do i access the email to sms gateway?". and you can tell them when you send an e-mail to mynumber@sms.telia.no a response of Relaying denied is sent back.
Once you are able to do this manually through your e-mail then we can work out the bits to make it work from the plugin.
Septik
Re: Text Messaging
Post by Septik » Fri Oct 27, 2017 9:48 am
I'll get to it. Thanks for getting back to me so quickly. Will edit this post and PM you when I've spoken to them.
Edit: Alright, I got in touch with them. Unfortunately, they have closed down their SMS gateway. :( Guess this means you should exclude Telia (formerly NetCom) from your plugin.
I know people on Telenor, though. I'll see if their gateway still works and report back.
Edit 2: Getting a "User not found" error with Telenor (########@mobilpost.no). I've left them a message asking if they still have an SMS gateway. Will edit again when I hear back from them.
