Problem installing .egplugin on EG 0.4 (Split from RFXtrx)
kalinkamaen
Re: RFXtrx
Post by kalinkamaen » Sat Jan 14, 2017 2:40 pm
Trying to install latest RFXcom Eg plugin. When double clicking on Eg plugin, nothing happens! What could be wrong?
Windows 10
Eventghost Program Version: 0.4.1.r1722
Regards Morten
topix
Re: RFXtrx
Post by topix » Sat Jan 14, 2017 7:36 pm
kalinkamaen wrote:Trying to install latest RFXcom Eg plugin. When double clicking on Eg plugin, nothing happens! What could be wrong?
Windows 10
Regards Morten
I'm not sure, but i think EG 0.4.1.r1722 must be running while double clicking on the .egplugin.
kalinkamaen
Re: RFXtrx
Post by kalinkamaen » Sat Jan 14, 2017 8:44 pm
It was running, I have tried 2 different computers with same result!
kalinkamaen
Re: RFXtrx
Post by kalinkamaen » Sun Jan 15, 2017 8:09 am
Tried you latest update with 3 different computers with same issue. Nothing happens.
Could the reason be because I have installed Eventghost directly to C: and not in programfiles?
Re: RFXtrx
Post by krambriw » Sun Jan 15, 2017 9:09 am
I have no control how the plugin is installed, it is handle by the core part of EG. A manual work-around is to open the .egplugin file with winrar and extract the content directly to the plugin folder.
topix
Re: RFXtrx
Post by topix » Sun Jan 15, 2017 11:26 am
kalinkamaen wrote:Tried you latest update with 3 different computers with same issue. Nothing happens.
Maybe :) In a windows command line please enter the following and check if the path is correct:
reg query "HKCR\EventGhost Plugin\shell\open\command"
kalinkamaen
Re: RFXtrx
Post by kalinkamaen » Sun Jan 15, 2017 12:29 pm
krambriw wrote:I have no control how the plugin is installed, it is handle by the core part of EG. A manual work-around is to open the .egplugin file with winrar and extract the content directly to the plugin folder.
Installed it this way with no problems. Did not know that I could unpack it. Thank you!
kalinkamaen
Re: RFXtrx
Post by kalinkamaen » Sun Jan 15, 2017 12:30 pm
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Users\Loftstue>reg query "HKCR\EventGhost Plugin\shell\open\command"
HKEY_CLASSES_ROOT\EventGhost Plugin\shell\open\command
(Default) REG_SZ "C:\EventGhost\EventGhost.exe" "%1"
topix
Re: RFXtrx
Post by topix » Sun Jan 15, 2017 4:35 pm
Hmm, to bad :cry:
Next try (from command line):
C:\EventGhost\EventGhost.exe RFXtrx_v2.0.2.egplugin
and if that still doesn't work:
C:\EventGhost\EventGhost.exe -debug RFXtrx_v2.0.2.egplugin
Re: RFXtrx
Post by kgschlosser » Sun Jan 15, 2017 7:00 pm
and no one has thought of this yet!??!?!
your file associations are boogered up... if you have more then one running version of EventGhost only one of them is associated to the file... so check your file associations and make sure it is pointed to where it needs to be.
kalinkamaen
Re: RFXtrx
Post by kalinkamaen » Sun Jan 15, 2017 7:45 pm
I am not sure what it is, but I have managed to install plugins the old way, and I am happy with that.
If you guys want to know whats doing this i will continue searching for the problem. If not I am okey with
unpack etc.
Anyway, thanks all help!
Re: RFXtrx
Post by kgschlosser » Sun Jan 15, 2017 9:15 pm
No No No, we need to know if there is in fact an issue. because if there is an issue with EG we really have to fix it..
one person with a problem is one person to many in my opinion...
In all seriousness. have you checked your file associations??
it's under control panel default programs.. second link down. it will bring up a list of file extensions and what program opens them.. make sure it is pointed properly to your EG installation folder...
and if it is pointed to an old copy of EG or something like that let us know...
But the egplugin file should also have a big green arrow for an icon. if it doesn't then it is pointed somewhere it shouldn't be
sometimes this happens. like with the plugins. it can be opened with zip. so when you click on open file with... there is a sneaky little checkbox that i usually forget to uncheck as well.. but it makes the new program you select the default program.
if you right click the egplugin file and click open with you will see EventGhost in there... if there is more then one EventGhost in there then you have more then one version installed... now whether it is actually installed or not is a different story.
kalinkamaen
Re: RFXtrx
Post by kalinkamaen » Mon Jan 16, 2017 5:05 pm
I have only 1 Eventghost installed. And I am 100% sure the plugin isassosiated to EG.
topix
Re: RFXtrx
Post by topix » Mon Jan 16, 2017 8:49 pm
kgschlosser wrote:and no one has thought of this yet!??!?!
I thought of this, that's why i let him checked the regestry. :wink: I wanted to see that path realy links to the path where he said he installed EG into.
And now i wanna know what happens, when he starts EG from command line with the egplugin file.
Hej kalinkamaen, i still would like you to try the commands i posted previous and tell me (maybe with the result of the -debug).
Re: RFXtrx
Post by kgschlosser » Tue Jan 17, 2017 3:32 am
my whole thing was not where eg was pointed to.. but if by accident he.she changed the file association to something other then EG..
I am right there with ya now on this. so we know the association is right. and the reg path is correct. then the plugin should be installing...
but... is he.she double clicking the file with EG open or closed. I have noticed if my EG is closed nothing happens as well.
it used to launch the plugin installation. (i think)
it no longer does this. it will only launch the plugin install if EG is open. and it being minimized does not matter
