MiCasaVerde Vera UI5, UI6, UI7 Plugin
Re: MiCasaVerde Vera UI5, UI6, UI7 Plugin
Post by kgschlosser » Fri Jul 28, 2017 3:30 pm
HA HA there was one other error i made... i fixed it and attached the file
TextControls.py
(15.96 KiB) Downloaded 16 times
holdestmade
Post by holdestmade » Sat Jul 29, 2017 6:40 am
Yes, I think I understand how you add categories, thanks.
All working great with that latest file.
Cheers
Post by kgschlosser » Sat Jul 29, 2017 2:11 pm
the categories are defined by UPNP and Vera uses their standard. so these will not change (hopefully) what the system i designed is a means to be able to add specific variable names to watch I am going to update this one more time i think to add a dialog to be able to add and remove variable names to monitor and what the user wants to generate for event names. any variable for any device/plugin that is able to be viewed inside of the Vera UI is able to b monitored. I will have to go diging again and find it. but there is also a means to be able to set any variable as well. I will add this functionality also. then it will expose all of the Vera to the user from within EventGhost
