Media Player Classic
Re: Media Player Classic
Post by Pako » Sat Mar 19, 2016 8:30 am
Why do you use a script when there is the action Media Player Classic - Retrieve various information - Get window state ?
However - this action also returns an incorrect result.
You can download the patched version (link is in the initial post).
Snowbird
Post by Snowbird » Sat Mar 19, 2016 4:07 pm
Thank you !! your bugfix worked !! :)
molitar
Post by molitar » Fri Mar 25, 2016 7:47 am
Is it possible to change the default volume up and down from 5%? I want to use 2% for my volume control changes.
Post by Pako » Fri Mar 25, 2016 8:20 am
molitar wrote:Is it possible to change the default volume up and down from 5%? I want to use 2% for my volume control changes.
Of course it is possible. It's easy.
xhunter
Post by xhunter » Sun Apr 17, 2016 12:36 am
hi,
I want to use the play button for "Play/Pause" which works fine,
but I also want it to do a "Reset Rate" (in case I used "Forward" button to "Increase Rate").
but when I add "Reset Rate" action under or above "Play/Pause", it messes up the play/pause action, it seems two actions get executed one play and one pause.
also, is it possible to execute download subtitle (File->Subtitle Database->Download), I can't find the action if it is there
Post by Pako » Sun Apr 17, 2016 7:12 am
xhunter wrote:but when I add "Reset Rate" action under or above "Play/Pause", it messes up the play/pause action, it seems two actions get executed one play and one pause.
This is not EventGhost/MPC-HC plugin bug.
This is MPC-HC property.
You can easily verify this by using these steps (MPC-HC control manually using keyboard shortcuts):
1) Start a movie and pause playback (Space)
2) Increase rate (Ctrl-Up)
3) Pause playback (Space)
4) Reset Rate (Ctrl-R)
xhunter wrote:also, is it possible to execute download subtitle (File->Subtitle Database->Download), I can't find the action if it is there
You can add it yourself. Use action "Send user's message."
xhunter
Post by xhunter » Sun Apr 17, 2016 2:00 pm
Pako wrote:This is not EventGhost/MPC-HC plugin bug.
I see, apparently mpc reset rate command executes its own play when triggered.
is there any ways to get the current rate status from the MPC so we can use that to decide the next action?
that would solve this problem.
also is it possible to disable "MPC-HC.NowPlaying..." logs without turning on "Log only assigned and activated events"
Pako wrote:You can add it yourself. Use action "Send user's message."
thank you, I didn't know about that.
Post by Pako » Sun Apr 17, 2016 5:20 pm
Please download a new version (the link is in the initial post).
xhunter wrote:also is it possible to disable "MPC-HC.NowPlaying..." logs without turning on "Log only assigned and activated events"
I've added a new option:
xhunter wrote:is there any ways to get the current rate status from the MPC so we can use that to decide the next action?
I have not found a simple way to get the rate-state. In contrast, get play-state is relatively simple (thanks to the events of "Playstate").
So I added a new action "Get play-state". This allows you to solve your problem.
This can be done like this:
Note: I do not know how it will be reliable. It must be tested in the long term.
xhunter
Post by xhunter » Sun Apr 17, 2016 10:14 pm
thank you very much, everything's working and it's a nice workaround.
nolse
Post by nolse » Tue Aug 09, 2016 8:34 am
Hello
I use MPC-be and I can not seem to communicate.
is what this plugin is compatible?
thank you
Post by Pako » Tue Aug 09, 2016 10:22 am
nolse wrote:I use MPC-be and I can not seem to communicate.
Unfortunately, it is not.
Post by blaher » Thu Aug 18, 2016 6:27 am
Pako wrote:Please download a new version (the link is in the initial post).
I don't get any events at all with the latest version, 2.12, whether I tick, or untick "NowPlaying" event, with EG .5 beta 3.
2.9 worked for me, with EG1722, but it seems incompatible with the beta.
patong
Post by patong » Fri Aug 19, 2016 7:35 pm
It would be super if this plugin also worked with mpc-be!
nolse
Post by nolse » Tue Aug 23, 2016 8:33 am
patong wrote:It would be super if this plugin also worked with mpc-be!
Foune
Post by Foune » Tue May 30, 2017 12:40 pm
Indeed, I miss the e.g / mpc plugin since I switched to mpc-be :'(
