VLC media player
Re: VLC media player
Post by kgschlosser » Mon Oct 07, 2019 12:10 am
OK I went through the plugin. did a bunch of code cleanup and formatting.. I believe I also found the problem that was occurring.
You need to start VLC using EventGhost. or you can optionally edit the VLC shortcut and add these command line parameters. replacing the IP and Port to match what you set in the plugin configuration.
--extraintf=oldrc
--rc-host=IP_SET_IN_THE_PLUGIN:PORT_SET_IN_THE_PLUGIN
--rc-quiet
--rc-show-pos
VLC-0.4.1500.egplugin
(8.67 KiB) Downloaded 62 times
stoffix
Post by stoffix » Sat Oct 12, 2019 7:31 pm
Thanks a lot! I'll try it when I get back home ;)
Post by kgschlosser » Sun Oct 13, 2019 6:37 pm
It also appears as tho on the latest version of VLC.. the one I tried to start the RC for. It is not working for some reason. I tried to start the RC module so that a console window can be used instead of a network connection for sending in commands.. and this would open the console but would not accept any input. I am not sure if the network connection is going to behave the same or not. The VLC plugin is extremely old and has not had a "facelift" since VLC version 1.1 I think the versions are up in the 3.x's now or possibly even higher. VLC does not have a fantastic API for remote control and there is not a whole lot of information on it..
Post by kgschlosser » Thu Oct 17, 2019 5:18 pm
OK I did want to let you know that I finally did manage to get this plugin working. I am going to have to redo the work I did because I simply started chopping pieces out and replacing them. so it doesn't trigger any events, I was only trying to see if I could get it to work.
I did find out something interesting tho. There is a dll file in VLC that offers a public API and it offers control over every single aspect of VLC and this would not use a socket connection. The up side is the level of control.. the down side is not being able to control a remote instance of VLC. I am not sure if I should rewrite the plugin to use the DLL file. or put the current version back into working order again. If making the current one work again the events could use a once over, unfortunately there is no information I am able to locate on what VLC spits out over that socket connection.
brunobf
Post by brunobf » Thu May 07, 2020 6:50 am
please send us a new version and thank you very much for your work
