OpenWeatherMap
Re: OpenWeatherMap
Post by Pako » Tue Dec 05, 2017 2:01 pm
Medy wrote:
Mon Dec 04, 2017 6:56 pm
Can someone explain how i can create events , lets say for example temperature with this ? Im not familiar with python.
I do not understand the question. What does "how i can create events" mean?
I think it's totally intuitive.
Only two things are essential:
1) Add your city to the list (the checkbox is automatically checked)
2) Check if the "Temperature" checkbox is checked.
The event is automatically triggered as soon as the temperature changes.
Medy
Re: OpenWeatherMap
Post by Medy » Tue Dec 05, 2017 9:39 pm
I see .
Though I would have liked a command to manually get the data.
I saw in a screenshot that u can use eg.print result after get current weather ... it returns a long string with all the data ...
I want to know how to output just the temperature for example / select which data to get.
My goal was tro press a button and display just the temperature via "Onscreendisplay" message for example.
Im aware of that window with a table. Im using that for now.
When I said that I dont know python , I meant im not able to extract specific info from that eg.result string.
Re: OpenWeatherMap
Post by Pako » Thu Dec 07, 2017 12:45 pm
Well, now I understand a little better what you need.
See the attached picture. This is one example of how you can do it.
HTPCanwender
Re: OpenWeatherMap
Post by HTPCanwender » Sat Jul 21, 2018 5:59 pm
When configuring the "Get current weather" command I geht the following error message. It is similar to the message I got with Nmap. Can anybody help?
19:45:30 Traceback (most recent call last) (WIP-2018.06.03-12.44.49):
19:45:30 File "wx\_core.pyc", line 16766, in <lambda>
19:45:30 File "C:\Program Files (x86)\EventGhost\plugins\OpenWeatherMap\__init__.py", line 1568, in AfterShow
19:45:30 autoCtrl.ctrl = autoCtrl.CreateCtrl(0)
19:45:30 File "C:\Program Files (x86)\EventGhost\eg\Classes\SmartSpinNumCtrl.py", line 72, in CreateCtrl
19:45:30 **self.kwargs
19:45:30 File "C:\Program Files (x86)\EventGhost\eg\Classes\SpinNumCtrl.py", line 115, in __init__
19:45:30 raise MaxValueError(value, max_val)
19:45:30 MaxValueError: The set value dummy is higher then the maximum of 9999
piert
Re: OpenWeatherMap
Post by piert » Tue Aug 07, 2018 7:03 am
I started using your plugin and I am, like yourself, still on the 'old Eventghost'. I would like to use the property 'wind direction', which in the Open Weather Map dictionary is 'deg', I believe. However there appears to be something wrong, because I can get temperatures from the plugin (I use an action to retrieve the weather data), but for the wind direction there are errors in the log.
Do you know where to look and how I can solve this?
08:45:27 Open Weather Map: Get current weather: 2747891
08:45:27 Error in Action: "Open Weather Map: Get current weather: 2747891"
08:45:27 Traceback (most recent call last) (1722):
08:45:27 File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionBase.py", line 170, in CallWrapper
08:45:27 return self(*args)
08:45:27 File "C:\Program Files (x86)\EventGhost\plugins\OpenWeatherMap\__init__.py", line 1497, in __call__
08:45:27 return self.plugin.GetShortData(data)
08:45:27 File "C:\Program Files (x86)\EventGhost\plugins\OpenWeatherMap\__init__.py", line 1024, in GetShortData
08:45:27 u'deg':self.WindDir(data[u'wind'][u'deg'])
08:45:27 KeyError: u'deg'
Re: OpenWeatherMap
Post by Pako » Tue Aug 14, 2018 6:59 am
You can try the test version. There, it seems that the bug is fixed.
The test version has extra "Get forecast" action.
That's incomplete. Only "Dictionary (umodified, full form)" version of the result is valid.
If anyone is interested in it, I can improve it somehow.
Test version 0.1a
(62.54 KiB) Downloaded 49 times
piert
Re: OpenWeatherMap
Post by piert » Tue Aug 14, 2018 9:34 pm
Many thanks, Pako!
Works great, I now have the wind direction as well.
Just out of curiosity I checked the weather forecast, but that gives a huge amount of information that is difficult to analyze.
Is there a way to print that information in a way that it is easier to see?
Thanks again,
Regards,
Perry
HTPCanwender
Re: OpenWeatherMap
Post by HTPCanwender » Wed Aug 15, 2018 7:57 pm
It's not possible to add the plugin to the egtree. Here is the log:
21:52:00 Traceback (most recent call last) (WIP-2018.06.03-12.44.49):
21:52:00 File "C:\Program Files (x86)\EventGhost\plugins\OpenWeatherMap\__init__.py", line 511, in Create
21:52:00 self.itemHeight = self.lb.GetItemHeight()
21:52:00 AttributeError: 'CheckListBox' object has no attribute 'GetItemHeight'
21:52:00 File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 162, in ProcessingTask
21:52:00 self.Configure(*args, **kwargs)
21:52:00 File "C:\Program Files (x86)\EventGhost\eg\Classes\ConfigDialog.py", line 106, in Configure
21:52:00 treeItem.Configure(*args)
21:52:00 File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionItem.py", line 80, in Configure
21:52:00 return self.executable.Configure(*args)
21:52:00 File "C:\Program Files (x86)\EventGhost\plugins\OpenWeatherMap\__init__.py", line 1374, in Configure
21:52:00 mainSizer.AddGrowableCol(1)
21:52:00 File "wx\_core.pyc", line 15368, in AddGrowableCol
21:52:00 PyAssertionError: C++ assertion "!m_cols || idx < (size_t)m_cols" failed at ..\..\src\common\sizer.cpp(1980) in wxFlexGridSizer::AddGrowableCol(): invalid column index
Re: OpenWeatherMap
Post by Pako » Fri Aug 17, 2018 6:36 am
@piert
Unfortunately, so far I have not tried to work with the forecast data.
Here are many options to do.
You can look for inspiration in the ClimateDataCalculation plugin.
If you want to make some charts, then you can use https://www.highcharts.com/ for example.
@HTPCanwender
It looks like you are using EG version 5.
Unfortunately, I can not help you in that case. I'm still using version 4.
I have not installed version 5 so far.
Medy
Re: OpenWeatherMap
Post by Medy » Sat Aug 18, 2018 1:43 am
Do you plan on updating for eventghost 0.5 ?
I just changed to this version because another plugin requires it.
Im using your plugin in a couple of makros & I like the the little UI.
this is the error in EG 5
File "C:\EventGhostNEW\plugins\Open Weather Map\__init__.py", line 509, in Create
File "C:\EventGhostNEW\eg\Classes\TaskletDialog.py", line 162, in ProcessingTask
File "C:\EventGhostNEW\eg\Classes\ConfigDialog.py", line 106, in Configure
File "C:\EventGhostNEW\eg\Classes\ActionItem.py", line 80, in Configure
File "C:\EventGhostNEW\plugins\Open Weather Map\__init__.py", line 1353, in Configure
topix
Re: OpenWeatherMap
Post by topix » Fri Feb 08, 2019 3:51 pm
Here is a version that works with 0.5 and 0.4.
OpenWeatherMap_0.2.egplugin
(18.16 KiB) Downloaded 53 times
gsaundry
Re: OpenWeatherMap
Post by gsaundry » Thu Jan 23, 2020 6:08 am
Does anyone have a copy of the recent versions of this plugin - one which contains the ability to pull forecasts? (The previous posts are missing their attachments due to the forum issues a while back).
Hoping to get OpenWeatherMap working as a functional replacement to the weather features in SunTracker, since weather.com appears to have made changes which have broken SunTracker's ability to pull data from that site.
Garrett
loveleejohn
Re: OpenWeatherMap
Post by loveleejohn » Fri Jan 24, 2020 8:53 pm
Garrett
Here's the copy of it that I have. Hope that helps.
(18.16 KiB) Downloaded 18 times
gsaundry
Re: OpenWeatherMap
Post by gsaundry » Thu Jan 30, 2020 3:37 am
Thanks very much - works great :D
omberski
Re: OpenWeatherMap
Post by omberski » Sun Mar 15, 2020 3:53 am
Garrett
It doesn't seem to work for me on 0.5.0-rc6 with the correct city name and city id.
I've been getting <Response [400]> since the first call (never worked). If I remove the API key, I get <Response [401]> which means it can communicate with the server.
Can anyone confirm if this plugin still works?
