AudioEndpoint
Re: AudioEndpoint
HI Pako,
yes, if EventGhost doesn't shut down correctly, the child processes aren't closed, I don't think that this can be changed (or I don't know how).
It should be possible to kill the old process if the plugin starts though.
I'll try to integrate that.
Re: AudioEndpoint
Hi Sem;colonSem;colon wrote:I'll try to integrate that.
I'm working on a Audio library for a plugin, it should have the same(and more) functionality that the programs your plugin uses but implemented fully (for now at least) in Python.
You would have more control and wouldn't have to manage external programs.
If you are interested I can post the beta version? The basic functionality that your plugin uses should work including endpoint notifications (events).
Re: AudioEndpoint
Yes, sounds great!If you are interested I can post the beta version?
Re: AudioEndpoint
OK, I have posted the initial version in the Coding corner here.Sem;colon wrote:Yes, sounds great!
It should be usable, but there are mostly no error checking and there are probably bugsa galore.
Re: AudioEndpoint
New Version!
v2.0:
-The plugin now uses the AudioEndpointControl library provided by jonib and not uses external tools any more.
-Replaced action "Get Default Audio Render" with "Get Default Audio Device" (you can now choose the role and flow direction of the default device you would like to get)
-Extended actions "Set Default Render", "Next Default Audio Render" and "Previous Default Audio Render" (It's now possible to select a role for the default render device you set (Console, Communication, Multimedia))
-Some responses may have changed, check your macros after updating!
v2.0:
Re: AudioEndpoint
Now that this plugin no longer depends on an external executable, I'd like to see it expanded and rolled into EventGhost as a replacement for VistaVolEvents and the "Sound Card" actions. Is that something you'd be willing to work on, Semi?
/bw
Re: AudioEndpoint
Thanks to both of you! It's a very handy plugin.Sem;colon wrote:New Version!
v2.0:
Yes, a quick 'ctrl+f' with 'audioendpoint' lets you find and reset them easily.-Some responses may have changed, check your macros after updating!
Re: AudioEndpoint
There are Pros and Cons to this.blackwind wrote:Now that this plugin no longer depends on an external executable, I'd like to see it expanded and rolled into EventGhost as a replacement for VistaVolEvents and the "Sound Card" actions. Is that something you'd be willing to work on, Semi?
On the one hand it increases out of the box functionality but on the other hand we may have:
-Problems with backwards compatibility
-More events that some people may not need (The system plugin, where the soundcard actions belong to, is always loaded)
Anyway, what's wrong with the VistaVolEvents? They work just fine, don't they?
Re: AudioEndpoint
VistaVolEvents has four main issues:
All that being said, I understand that this isn't a trivial undertaking, and I understand that not everyone has the time to invest that I do. If I wake up to a pull request one day over at GitHub, perfect; if not, know that your work on the plugin is appreciated either way.
- It only provides events for the default device.
- It can't differentiate between similarly named devices.
- Doing things via C/C++ rather than Python makes for a higher barrier to entry for new developers. There's a complete build environment on my system, sure, but what if Average Joe finds a bug and wants to contribute? If we replace VistaVolEvents, all he needs is a copy of EventGhost. Long-term, we hope to replace all the .pyds we bundle.
- Stackless Python doesn't support mixed-mode debugging, so VistaVolEvents can't be stepped through. Python code can.
/bw
Not being able to make it work, Please help.
I am new to Eventghost and infact I installed eventghost just to be able to reduces system volume when headphones is connected. But I just can't figure out how to make this work. Please bear with my novice questions.
I added a macro for : "Get default audio device". But plugging in or pulling out the headphones does not not reflect anything in logs. I even tried "Set default audio render" still nothing.
Even the logs in the screen shot only came because I clicked on the green button after selecting the macros.
Please help me out, I don't understand what I am missing here, is there anything else I should add, any events or something like that for the logs to reflect ?
PS: my machine is a Dell XPS L502x running Windows 10 and uses Realtek High Definition Audio. Further my system has two headphone ports, I tried both.
Re: AudioEndpoint
@Blackwind: I agree then, I wasn't aware of those limitations.
Anyway, let's first see how good the lib from jonib works and then integrate it into EventGhost.
@Raghu18:
you just need to load the plugin (basically what you did), that's all you need to receive those events.
However, the plugin didn't seem to load correctly.
If it does, you receive a message "Audio Entpoint plugin started" and also some events on startup. Can you try an older version of the plugin and tell us if it works better?
@Raghu18:
Re: AudioEndpoint
I use a receiver for my audio, but when I change inputs, the receiver disappears from Windows, so sometimes the 'set default to:' macro fires and gives this error. I mean, it should give an error, because the receiver doesn't exist then, but I was wondering does it affect anything by the plugin not accounting for a missing default?
Re: AudioEndpoint
No, but the error message should look better, I'll correct it in the next version.
Re: AudioEndpoint
Cheers. I had a freeze exiting EG, and this was the last line in the .log.Sem;colon wrote:No, but the error message should look better, I'll correct it in the next version.
10:14:03: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\AudioEndpoint
AudioEndpoint(control) version = "2.0"
EG 1722
Win 7 x64
Re: AudioEndpoint
Is there a way to reproduce this?blaher wrote:I had a freeze exiting EG, and this was the last line in the .log.
