Nmap
Re: Nmap
Post by Pako » Mon Jun 02, 2014 11:08 am
HTPCanwender wrote:May my german Windows Version cause the Problem? The Folder c:\Program Files (x86) is shown in the Explorer as c:\Programme (x86).
It looks like a very important information!
Please try to set the plugin as follows:
Thanks, Pako
HTPCanwender
Re: Nmap
Post by HTPCanwender » Mon Jun 02, 2014 12:05 pm
It did not help. I copied the Nmap program to the folder c:\Nmap without any result. Here is the log from 0.5a
13:58:21 repr(cmd) = [u'""C:\\Nmap\\nmap.exe""', u'-sn', u'-PE', u'-PO', u'-n', u'192.168.1.0/24']
13:58:21 Nmap.DataUnavailable
13:58:21 Main.OnInit
13:58:21 repr(data) = u'Der Befehl "\\"\\"C:\\Nmap\\nmap.exe\\"\\"" ist entweder falsch geschrieben oder\r\nkonnte nicht gefunden werden.\r\n'
13:58:21 Nmap.DataAvailable
and the log from 0.5b
14:01:38 Nmap.DataUnavailable
14:01:38 repr(self.myExe) = u'"C:\\Nmap\\nmap.exe"'
14:01:38 Main.OnInit
14:01:38 repr(data) = u'Der Befehl "\\"C:\\Nmap\\nmap.exe\\"" ist entweder falsch geschrieben oder\r\nkonnte nicht gefunden werden.\r\n'
14:01:38 Nmap.DataAvailable
Re: Nmap
Post by Pako » Mon Jun 02, 2014 12:12 pm
HTPCanwender wrote:repr(self.myExe) = u'"C:\\Nmap\\nmap.exe"'
It looks like a typo.
Log should look like this:
repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
HTPCanwender
Re: Nmap
Post by HTPCanwender » Mon Jun 02, 2014 1:10 pm
The answer is excactly as you wrote (Version 0.5b)
15:04:34 repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
But are the "\\" at the beginning of the path before the c: ok?
15:04:35 repr(data) = u'Der Befehl "\\"C:\\Programme (x86)\\Nmap\\nmap.exe\\"" ist entweder falsch geschrieben oder\r\nkonnte nicht gefunden werden.\r\n'
Re: Nmap
Post by Pako » Mon Jun 02, 2014 4:42 pm
HTPCanwender wrote:But are the "\\" at the beginning of the path before the c: ok?
This is not correct and this is really weird. I have no explanation for it.
I created the same directory on my C drive and I get this log:
18:32:45   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
18:32:49   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 18:32 ...
18:33:15   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
18:33:17   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 18:33 ...
18:33:45   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
18:33:57   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 18:33 ...
18:34:15   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
18:34:25   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 18:34 ...
18:34:45   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
18:34:50   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 18:34 ...
It is quite obvious that everything works properly.
I do not know what to do at this moment, I'll think about it.
HTPCanwender
Re: Nmap
Post by HTPCanwender » Mon Jun 02, 2014 6:19 pm
I wrote the path for the Nmap.exe directly into the plugin.
def worker(self, oldT):
        #print "Nmap worker thread"
        print "repr(self.myExe) =",repr(self.myExe)
        res = self.popen("c:\\Program Files (x86)\\Nmap\\Nmap.exe", "-sn -PE -PO  -n %s" % self.ipRng)
Here is the result:
20:05:02   Autostart
20:05:02   Main.OnInit
20:05:08   Nmap.DataUnavailable
20:05:08   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
20:05:11   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 20:05 Mitteleurop\xe4ische Sommerzeit\r\nNmap scan report for 192.168.1.1\r\nHost is up (0.0040s latency).\r\nMAC Address: 00:1F:3F:4D:67:95 (AVM GmbH)\r\nNmap scan report for 192.168.1.10\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:11:E5:00:78:20 (KCodes)\r\nNmap scan report for 192.168.1.20\r\nHost is up (0.0020s latency).\r\nMAC Address: 00:80:92:4E:AB:8D (Silex Technology)\r\nNmap scan report for 192.168.1.103\r\nHost is up (0.23s latency).\r\nMAC Address: 24:77:03:8A:45:88 (Intel Corporate)\r\nNmap scan report for 192.168.1.245\r\nHost is up (0.00s latency).\r\nMAC Address: 00:1C:10:66:7C:57 (Cisco-Linksys)\r\nNmap scan report for 192.168.1.50\r\nHost is up.\r\nNmap done: 256 IP addresses (6 hosts up) scanned in 3.02 seconds\r\n'
20:05:11   Nmap.DataAvailable
20:05:15   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
20:05:18   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 20:05 Mitteleurop\xe4ische Sommerzeit\r\nNmap scan report for 192.168.1.1\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:1F:3F:4D:67:95 (AVM GmbH)\r\nNmap scan report for 192.168.1.10\r\nHost is up (0.00088s latency).\r\nMAC Address: 00:11:E5:00:78:20 (KCodes)\r\nNmap scan report for 192.168.1.20\r\nHost is up (0.0030s latency).\r\nMAC Address: 00:80:92:4E:AB:8D (Silex Technology)\r\nNmap scan report for 192.168.1.103\r\nHost is up (0.27s latency).\r\nMAC Address: 24:77:03:8A:45:88 (Intel Corporate)\r\nNmap scan report for 192.168.1.245\r\nHost is up (0.0030s latency).\r\nMAC Address: 00:1C:10:66:7C:57 (Cisco-Linksys)\r\nNmap scan report for 192.168.1.50\r\nHost is up.\r\nNmap done: 256 IP addresses (6 hosts up) scanned in 3.27 seconds\r\n'
20:05:45   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
20:05:47   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 20:05 Mitteleurop\xe4ische Sommerzeit\r\nNmap scan report for 192.168.1.1\r\nHost is up (0.0020s latency).\r\nMAC Address: 00:1F:3F:4D:67:95 (AVM GmbH)\r\nNmap scan report for 192.168.1.10\r\nHost is up (0.0044s latency).\r\nMAC Address: 00:11:E5:00:78:20 (KCodes)\r\nNmap scan report for 192.168.1.20\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:80:92:4E:AB:8D (Silex Technology)\r\nNmap scan report for 192.168.1.245\r\nHost is up (0.0050s latency).\r\nMAC Address: 00:1C:10:66:7C:57 (Cisco-Linksys)\r\nNmap scan report for 192.168.1.50\r\nHost is up.\r\nNmap done: 256 IP addresses (5 hosts up) scanned in 2.68 seconds\r\n'
20:05:47   Nmap.Away.lenovo T530 '24:77:03:8A:45:88'
20:06:15   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
20:06:17   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 20:06 Mitteleurop\xe4ische Sommerzeit\r\nNmap scan report for 192.168.1.1\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:1F:3F:4D:67:95 (AVM GmbH)\r\nNmap scan report for 192.168.1.10\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:11:E5:00:78:20 (KCodes)\r\nNmap scan report for 192.168.1.20\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:80:92:4E:AB:8D (Silex Technology)\r\nNmap scan report for 192.168.1.245\r\nHost is up (0.0020s latency).\r\nMAC Address: 00:1C:10:66:7C:57 (Cisco-Linksys)\r\nNmap scan report for 192.168.1.50\r\nHost is up.\r\nNmap done: 256 IP addresses (5 hosts up) scanned in 2.69 seconds\r\n'
20:06:45   repr(self.myExe) = u'"C:\\Programme (x86)\\Nmap\\nmap.exe"'
20:06:47   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-02 20:06 Mitteleurop\xe4ische Sommerzeit\r\nNmap scan report for 192.168.1.1\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:1F:3F:4D:67:95 (AVM GmbH)\r\nNmap scan report for 192.168.1.10\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:11:E5:00:78:20 (KCodes)\r\nNmap scan report for 192.168.1.20\r\nHost is up (0.0020s latency).\r\nMAC Address: 00:80:92:4E:AB:8D (Silex Technology)\r\nNmap scan report for 192.168.1.103\r\nHost is up (0.011s latency).\r\nMAC Address: 24:77:03:8A:45:88 (Intel Corporate)\r\nNmap scan report for 192.168.1.107\r\nHost is up (0.0020s latency).\r\nMAC Address: 54:42:49:D9:CE:75 (Sony)\r\nNmap scan report for 192.168.1.245\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:1C:10:66:7C:57 (Cisco-Linksys)\r\nNmap scan report for 192.168.1.50\r\nHost is up.\r\nNmap done: 256 IP addresses (7 hosts up) scanned in 2.26 seconds\r\n'
20:06:47   Nmap.Present.Sony ('54:42:49:D9:CE:75', u'192.168.1.107')
20:06:47   Nmap.Present.lenovo T530 ('24:77:03:8A:45:88', u'192.168.1.103')
The modifyed plugin is working. I hope this will help you to find the reason for this behaviour.
Yours
Re: Nmap
Post by Pako » Mon Jun 02, 2014 6:37 pm
HTPCanwender wrote:The modifyed plugin is working. I hope this will help you to find the reason for this behaviour.
I do not know, we'll see.
In any case, I'm glad you can use this plugin now.
I suppose you suppress unwanted print using the comment.
One more question:
What operating system do you have?
HTPCanwender
Re: Nmap
Post by HTPCanwender » Mon Jun 02, 2014 6:58 pm
Windows 7 Professional SP1 German
HTPCanwender
Re: Nmap
Post by HTPCanwender » Mon Jun 02, 2014 7:02 pm
... and Windows 7 Home Premium SP1 German. Both show the same behaviour.
Re: Nmap
Post by Pako » Tue Jun 03, 2014 2:51 pm
Can you please try version 0.5c?
Please pay attention to the parameter setting "Nmap install folder".
It appears that in your case is properly: C:\Program Files (x86)\Nmap.
Test version 0.5c
(75.78 KiB) Downloaded 181 times
HTPCanwender
Re: Nmap
Post by HTPCanwender » Tue Jun 03, 2014 8:04 pm
Yes, you did it. The plugin works now.
I selected the Nmap install Folder
with the browser opened with the directory Icon.
Here is the log:
21:53:53   ---> Willkommen beim EventGhost <---
21:53:55   Autostart
21:53:55   Nmap.DataUnavailable
21:53:55   Main.OnInit
21:53:55   repr(self.myExe) = u'"C:\\Program Files (x86)\\Nmap\\nmap.exe"'
21:53:55   repr(cmd) = u'"C:\\Program Files (x86)\\Nmap\\nmap.exe" -sn -PE -PO -n 192.168.1.0/24'
21:53:57   repr(data) = u'\r\nStarting Nmap 6.46 ( http://nmap.org ) at 2014-06-03 21:53 Mitteleurop\xe4ische Sommerzeit\r\nNmap scan report for 192.168.1.1\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:1F:3F:4D:67:95 (AVM GmbH)\r\nNmap scan report for 192.168.1.10\r\nHost is up (0.0010s latency).\r\nMAC Address: 00:11:E5:00:78:20 (KCodes)\r\nNmap scan report for 192.168.1.20\r\nHost is up (0.0020s latency).\r\nMAC Address: 00:80:92:4E:AB:8D (Silex Technology)\r\nNmap scan report for 192.168.1.60\r\nHost is up (0.0010s latency).\r\nMAC Address: 48:5B:39:75:76:D0 (Asustek Computer)\r\nNmap scan report for 192.168.1.103\r\nHost is up (0.053s latency).\r\nMAC Address: 24:77:03:8A:45:88 (Intel Corporate)\r\nNmap scan report for 192.168.1.107\r\nHost is up (0.00s latency).\r\nMAC Address: 54:42:49:D9:CE:75 (Sony)\r\nNmap scan report for 192.168.1.245\r\nHost is up (0.0020s latency).\r\nMAC Address: 00:1C:10:66:7C:57 (Cisco-Linksys)\r\nNmap scan report for 192.168.1.50\r\nHost is up.\r\nNmap done: 256 IP addresses (8 hosts up) scanned in 2.03 seconds\r\n'
21:53:57   Nmap.DataAvailable
Thank you
Re: Nmap
Post by Pako » Wed Jun 04, 2014 4:17 am
HTPCanwender wrote:Thank you
I thank you for your patience.
In the opening post is a new fixed version 0.5 (without unnecessary print).
Is possible that the problem had more people, but nobody reported it.
I believe that the plugin will be useful for you.
Please write here your experiences (after some time of use) !
HTPCanwender
Re: Nmap
Post by HTPCanwender » Wed Jun 04, 2014 4:07 pm
could you please add a field at the configuration window to set the time between the Nmap scans? As you supposed, it is not easy to get a stable result due to the power saving modes of the devices in the network.
Yours
Arnd
tnt
Re: Nmap
Post by tnt » Wed Jun 04, 2014 9:31 pm
I am a little newbie in EventGhost, but Thanks a lot for you plugin development! When I was thinking about a way to integrate nmap and EventGhost, you already made a plugin!
I would like to ask for a new feature: the possibility to trigger a event when a unknown host is online, not with the MAC Address,but with a generic name. I want to make a intrusion detector, so I want to send a alert every time a unknown device is online in my network.
Re: Nmap
Post by Pako » Thu Jun 05, 2014 7:57 am
HTPCanwender wrote:Hi Pako,
I can - of course - the option to add.
However - I'm not sure that will do what you expect.
When I tested it, I found that from time to time the duration of scanning was much longer than usual (also up to 40 seconds).
You can test different periods.
Use a test version 0.6a and change the period (line 1160) as needed.
If you find that it's really useful, I will add that option.
The question is, what should be the step of changes (say 10 seconds would be enough)?
tnt wrote:I would like to ask for a new feature: the possibility to trigger a event when a unknown host is online, not with the MAC Address,but with a generic name. I want to make a intrusion detector, so I want to send a alert every time a unknown device is online in my network.
I'm not sure if I understand it.
If you assign names to all your (authorized) devices, then every event as Nmap.Connected [some MAC address] will mean, that in the network has connected some new device.
That's not enough for you?
Test version 0.6a
(75.78 KiB) Downloaded 184 times
