Simple SSH Client
Simple SSH Client
Post by Sem;colon » Sun Feb 09, 2014 9:14 pm
Hello everyone,
I recently checked out the Raspberry Pi plugin which communicates with an raspberry Pi by using SSH - But I also have some (other) linux PCs I'd like EventGhost to interface with but suprisingly I couldn't find an exiting SSH plugin for EventGhost.
So, inspired by the Raspberry Pi plugin, I created one.
This plugin is a SSH (Secure Shell) client plugin for EventGhost - It can handle multiple SSH hosts by invoking a shell which is "displayed" in the EventGhost Log.
This enables you to send any SSH command to your host(s) and use the response to trigger macros.
If you find any bugs, please report them here.
Change-log:
v1.79:
-Category changed form external to other
-Added option "Additional Suffix" to the Send Command event, to specify a custom suffix for the "Data" event.
-Some minor improvements
v1.77:
-Added compatibillity with EventGhost 0.5.0 (should also work with old versions of EG again)
-The plugin is now in the .egplugin format, you can import it by doing a dobble-click on it (make sure EventGhost IS running when you do it!)
v1.76:
-Improved Error logging.
-An event is now triggered if connecting to a host fails.
v1.75:
-Added option to turn off the "automatic disconnect" feature if the host becomes inactive on a per host basis (as it appears to make problems with some devices).
-Increased the stability of the connection.
-Bug fixes.
v1.7:
-Bug fixed: Wasn't working with OpenELEC.
-Removed console color codes (by regex) as I don't think they make sense when using SSH via this plugin.
It might be that some responses (events) look different from before - if you use the response to trigger macros, check if those are still working!
v1.6:
This version requires EventGhost 0.4.1.r1669 or later!
-Removed paramiko files, as paramiko is now integrated in EventGhost.
-Added option "replace host if it already exists" to the "Add Host" function.
v1.5:
-Bug fixes
-New Event "UnknownData" for data that comes via ssh to the client without a command being executed (e.g. Broadcast messages)
The response handler has been more or less rewritten, so it might be that some responses (events) look different from before - if you use the response to trigger macros, check if those are still working!
v1.4:
-Bug fixes
-Added option to the "send command" function to not discard this command if host is not connected (otherwise it discards commands when it's not possible to send them immediately).
v1.3:
-Bug fixes
-New function "Send Text"
-Added option to the "send command" function to add the executed command as an additional suffix to the "Data" event.
-Added option to the "send command" function to trigger the "Data" event only if the result is different from the last time this command was executed.
SSH.egplugin
Simple SSH Client (v1.79)
(211.24 KiB) Downloaded 328 times
SSH.zip
Simple SSH Client (v1.77)
(207.97 KiB) Downloaded 260 times
Simple SSH Client (v1.76)
(19.46 KiB) Downloaded 336 times
Re: Simple SSH Client
Post by Sem;colon » Sat Mar 01, 2014 8:52 pm
New Version! (1.3)
Changes:
-Bug fixes
You can download it from the first post.
Post by Sem;colon » Thu Apr 03, 2014 8:54 pm
New version! (1.4)
HTPCanwender
Post by HTPCanwender » Thu Apr 03, 2014 9:29 pm
I am just searching for a plugin that does such a communication, not with SSH but with Telnet. It would be nice if it is possible to choose between a SSH or Telnet connection.
Post by Sem;colon » Fri Apr 04, 2014 8:52 am
Hello HTPCanwender,
I agree, a telnet plugin would be nice as well.
Unfortunately the library used by this plugin (paramiko) doesn't support telnet.
Maybe I or someone else will create a separate plugin for that in the future, but I won't do it at the moment as I don't need it...
Since telnet can be controlled via cmd.exe you could try to archive your target by using cmd.exe with Eventghost (just an idea)
zian
Post by zian » Fri Apr 04, 2014 7:03 pm
I found a bug...
Why didn't you create this plugin SOONER!?!
lol
Just kidding.
Just found this,
Downloaded it, extracted it and set it up easy.
Now I can fire off Gpodder on my Pi whenever I wish twice as well.
Thanks Semi... You did it again.
eventghost.net
Be there or be square.
Post by Pako » Sat Apr 05, 2014 11:47 am
zian wrote:I found a bug...
But he could not write it sooner.
First, it was necessary, that I wrote RaspberryPi plugin. :D
zian
Post by zian » Sat Apr 05, 2014 3:21 pm
As always Pako... we are ALL always in your debt.
Thanks both much.
I am doing SSH as we speak. ;)
Be well.
eventghost.net
Post by Sem;colon » Sat Apr 05, 2014 7:58 pm
That's true! ;)
AndyB588
Post by AndyB588 » Sat Apr 19, 2014 6:51 pm
Nice. This might be just what I've been looking for.. I've got a remote seedbox that provides my TV shows on XMBC and I'm trying to automate the whole thing..
Post by Sem;colon » Tue Apr 22, 2014 9:28 pm
AndyB588 wrote:Nice.
You're welcome :D
btw. New Version! (v1.5)
Changes:
-Bug fixes
DarkCinema
Post by DarkCinema » Sun May 11, 2014 4:42 pm
Thanks a Lot for this excellent plugin.
Just what I needed to send commands to my Ubiquiti mFi and Unifi equipment.
Post by Sem;colon » Fri Jul 25, 2014 9:42 pm
New Version! (v1.6):
Post by Sem;colon » Fri Aug 01, 2014 2:32 pm
New Version! (v1.7):
kalia
Post by kalia » Thu Apr 16, 2015 9:19 pm
Could you make the password text box hidden (masked with asterisks)?
Kalia
