MQTT Client
Re: MQTT Client
Post by kgschlosser » Thu Jun 06, 2019 1:46 am
we just had an issue with out host. and we lost our forum attachments. I am sorry for this. I am doing my best to locate a set of them and make repairs to solve this issue.
holdestmade
Re: MQTT Client
Post by holdestmade » Mon Jun 10, 2019 8:06 am
Not sure if this is of use but this is the file I am currently using, think it was the latest on the forum
MQTT Client.zip
(45.4 KiB) Downloaded 135 times
HTPCanwender
Re: MQTT Client
Post by HTPCanwender » Sun Oct 20, 2019 8:56 pm
I would like to use an EG variable in the topic field of the publish command. This field seems not to support variables. Could someone add this feature please?
Thank you.
rmiles7721
Client ID
Post by rmiles7721 » Mon Nov 04, 2019 3:02 am
I've got EG running on two separate machines on my network with the plugin running on both. Both also apparently have the same client ID. Is there some way to change this?
Snowbird
Re: MQTT Client
Post by Snowbird » Mon Nov 04, 2019 7:13 am
you need to change it in the XML config file manually, just put anything, there is now way to do it with the GUI...
rmiles7721
Re: MQTT Client
Post by rmiles7721 » Mon Nov 04, 2019 7:46 pm
That did it. Thanks.
RiseUp
Re: MQTT Client
Post by RiseUp » Wed Nov 06, 2019 2:07 pm
Thank you.
What have you tried that leads you to conclude that the topic field does not support variables? I'm not quite sure I understand the problem.
