MQTT Client
Snowbird
Re: MQTT Client
Post by Snowbird » Fri Jul 13, 2018 5:12 pm
this is something missing in EG for such a long time ;) the only way I've found to do this is with WMI, but the WMI lib needs to be loaded.
you can download the wmi zip file here : https://pypi.org/project/WMI/#files
then open the zip file and place the wmi.py file here : %programfiles(x86)%\EventGhost\lib27\site-packages
for example to get the current brightness you can run this code :
import wmi
c = wmi.WMI(namespace='wmi')
GetBrightness = c.WmiMonitorBrightness()[0]
print "Brightness " + str(GetBrightness.CurrentBrightness) +"%"
Here's an example to set the brightness to 60% :
import wmi
BrightLevel = 60
methods = c.WmiMonitorBrightnessMethods()[0]
methods.WmiSetBrightness(BrightLevel, 0)
I always thought that WMI should be embedded to Evenghost, since you can do so much with WMI, but there must be a valid reason why it has never been done.
Re: MQTT Client
Post by kgschlosser » Sat Jul 14, 2018 4:04 am
you don't have to worry about adding the wmi module.
read HERE
@Snowbird
I have not forgotten the XMPP Plus plugin, My eyes were going cross eyed looking at that disaster called sleekxmpp. I really do hate voodoo magic code. i needed a break from it.
Re: MQTT Client
Post by kgschlosser » Sat Jul 14, 2018 4:50 am
The reason why is because i do not believe the WMI module is being supported anymore. Plus WMI is horrendously slow, woven all about in a really screwed up manner, and everything that you can do with it can be done without the need for using COM. (which is what the wmi library uses)
as an example. to get all drive letters using WMI
import pythoncom
import win32com.client
pythoncom.CoInitialize()
wmi = win32com.client.GetObject("winmgmts:\\root\\cimv2")
drive_letters = []
logical_disks = wmi.ExecQuery("Select * from Win32_LogicalDisk")
for disk in logical_disks:
    drive_types = (
        None,
        None,
        'DiskDrive',
        'DiskDrive',
        'MappedLogicalDisk',
        'CDROMDrive',
        'DiskDrive',
    drive_type = drive_types[disk.DriveType]
    if drive_type is not None:
        drives =wmi.ExecQuery(
            'Select * from Win32_' + drive_type
        for drive in drives:
            if drive_type == 'CDROMDrive':
                drive_letters += [drive.Drive[:-1]]
            elif drive_type == 'MappedLogicalDisk':
                drive_letters += [drive.Name[:-1]]
                partitionQuery = (
                    'ASSOCIATORS OF {Win32_DiskDrive.DeviceID="%s"} '
                    'WHERE AssocClass=Win32_DiskDriveToDiskPartition' %
                    drive.DeviceID.replace('\\', '\\\\')
                for partition in wmi.ExecQuery(partitionQuery):
                    diskQuery = (
                        'ASSOCIATORS OF {Win32_DiskPartition.DeviceID="%s"} '
                        'WHERE AssocClass=Win32_LogicalDiskToPartition' %
                        partition.DeviceID
                    for logical_disc in wmi.ExecQuery(diskQuery):
                        drive_letters += [logical_disc.DeviceID[:-1]]
print drive_letters
and to do the same using ctypes and a single API function call.
import ctypes
from ctypes.wintypes import DWORD
GetLogicalDrives = ctypes.windll.kernel32.GetLogicalDrives
GetLogicalDrives.restype = DWORD
drive_letters = []
uDriveMask = GetLogicalDrives()
for i in range(27):
    if uDriveMask & 1:
        drive_letters += [chr(i + 65)]
    uDriveMask >>= 1
    if not uDriveMask:
        break
print drive_letters
so as you can see based on sheer amount of code. WMI loses
the nested layers of SQL database access just to obtain the drive letters is BONKERS with WMI. so as far as the code complexity WMI loses
The readability of the code WMI loses
and using WMI is horribly slow. SQL queries take time and having to do 3 or 4 of them just to get a drive letter is COO COO
so goes the reason for not using WMI in the core. It can be added to EG if a user wants and that i think is good enough :-D if you disagree the complaint department is HERE :D JK
Terr
Re: MQTT Client
Post by Terr » Sat Jul 14, 2018 6:56 am
import wmi
eventghost 0.5
try add code to python script
log errors
Python Script
     Python script "24", line 3, in <module>
     File "C:\Program Files (x86)\EventGhost\lib27\site-packages\wmi.py", line 819, in query
       handle_com_error ()
     File "C:\Program Files (x86)\EventGhost\lib27\site-packages\wmi.py", line 241, in handle_com_error
       raise klass (com_error=err)
   x_wmi: <x_wmi: Unexpected COM Error (-2147217396, 'OLE error 0x8004100c', None, None)>
lol )
Snowbird
Re: MQTT Client
Post by Snowbird » Sat Jul 14, 2018 7:04 am
thanks Kevin for this complete explanation, I knew there was a good reason behind it, now I know what it is ! ;) the only drawback for me is that WMI has been around for so many years, and seems "easier" to use, I'm not very familiar with ctypes and API function calls, but that's something I can learn. If the same things can be achieved with less code and faster, then it's a good reason not to use WMI anymore :)
Snowbird
Re: MQTT Client
Post by Snowbird » Sat Jul 14, 2018 7:11 am
read HERE
Seems to be promising ! :) Can't wait to see it n action ! thanks for all your efforts, really appreciated !
@Snowbird
I want you to be a Voodoo specialist ! :D you'll thank me later :) all kidding aside, I'm struggling everyday with this, so the sooner you'll fix this and the more chances you'll get to continue talking to a sane person : me ! :) you are warned LOL
Snowbird
Re: MQTT Client
Post by Snowbird » Sat Jul 14, 2018 7:24 am
Python Script
       handle_com_error ()
that's strange...
try to change this line :
with this one :
c = wmi.WMI(namespace='cimv2')
Terr
Re: MQTT Client
Post by Terr » Sat Jul 14, 2018 7:41 am
with this one :
     Python script "52", line 3, in <module>
     File "C:\Program Files (x86)\EventGhost\lib27\site-packages\wmi.py", line 1147, in __getattr__
       return getattr (self._namespace, attribute)
     File "win32com\client\dynamic.pyc", line 527, in __getattr__
   AttributeError: winmgmts:root/cimv2.WmiMonitorBrightness
Re: MQTT Client
Post by kgschlosser » Sat Jul 14, 2018 9:01 am
woooo
Follow the instructions at the top of the script
# Set the 2 values below,
# the monitor number is the number you see in Display Properties
# Brightness is from 0 - 100
MONITOR_NUMBER = 1
BRIGHTNESS = 100
import ctypes
from ctypes.wintypes import HMONITOR, BOOL, DWORD, HDC, RECT, LPARAM, WCHAR
NULL = None
PHYSICAL_MONITOR_DESCRIPTION_SIZE = 128
dxva2 = ctypes.windll.dxva2
user32 = ctypes.windll.user32
MONITORENUMPROC = ctypes.WINFUNCTYPE(
    BOOL,
    HMONITOR,
    HDC,
    ctypes.POINTER(RECT),
    LPARAM
class _PHYSICAL_MONITOR(ctypes.Structure):
    _fields_ = [
        ('hPhysicalMonitor', HMONITOR),
            'szPhysicalMonitorDescription',
            WCHAR * PHYSICAL_MONITOR_DESCRIPTION_SIZE
PHYSICAL_MONITOR = _PHYSICAL_MONITOR
GetNumberOfPhysicalMonitorsFromHMONITOR = (
    dxva2.GetNumberOfPhysicalMonitorsFromHMONITOR
GetNumberOfPhysicalMonitorsFromHMONITOR.restype = BOOL
SetMonitorBrightness = dxva2.SetMonitorBrightness
SetMonitorBrightness.restype = BOOL
GetPhysicalMonitorsFromHMONITOR = (
    dxva2.GetPhysicalMonitorsFromHMONITOR
GetPhysicalMonitorsFromHMONITOR.restype = BOOL
EnumDisplayMonitors = user32.EnumDisplayMonitors
EnumDisplayMonitors.restype = BOOL
def get_displays():
    """Get a list of the available displays"""
    def MonitorEnumProc(hMonitor, *_):
        hMonitors.append(hMonitor)
        return True
    hMonitors = []
    pPhysicalMonitors = []
    # get display monitors
    if not EnumDisplayMonitors(
        NULL,
        NULL,
        MONITORENUMPROC(MonitorEnumProc),
        NULL
        raise ctypes.WinError()
    # get physical monitors for each display monitor
    for hMonitor in hMonitors:
        pdwNumberOfPhysicalMonitors = DWORD()
        if not GetNumberOfPhysicalMonitorsFromHMONITOR(
            hMonitor,
            ctypes.byref(pdwNumberOfPhysicalMonitors)
        pPhysicalMonitorArray = (
            PHYSICAL_MONITOR * pdwNumberOfPhysicalMonitors.value
        if not GetPhysicalMonitorsFromHMONITOR(
            hMonitor,
            pdwNumberOfPhysicalMonitors,
        for pPhysicalMonitor in pPhysicalMonitorArray:
            pPhysicalMonitors.append(pPhysicalMonitor.hPhysicalMonitor)
    return pPhysicalMonitors
SetMonitorBrightness(get_displays()[MONITOR_NUMBER - 1], DWORD(BRIGHTNESS))
Snowbird
Re: MQTT Client
Post by Snowbird » Sat Jul 14, 2018 9:14 am
no errors but nothing happens LOL tried different values, is there anything special to to on a laptop ?
Re: MQTT Client
Post by kgschlosser » Sat Jul 14, 2018 5:20 pm
give this a try
BRIGHTNESS = 100
import ctypes
NULL = None
    BOOL,
    HMONITOR,
    HDC,
    LPARAM
    _fields_ = [
CapabilitiesRequestAndCapabilitiesReply = (
    dxva2.CapabilitiesRequestAndCapabilitiesReply
CapabilitiesRequestAndCapabilitiesReply.restype = BOOL
GetCapabilitiesStringLength = dxva2.GetCapabilitiesStringLength
GetCapabilitiesStringLength.restype = BOOL
def get_displays():
            hMonitor,
            hMonitor,
        return True
        NULL,
        NULL,
        NULL
for hMonitor in get_displays():
    SetMonitorBrightness(hMonitor, DWORD(BRIGHTNESS))
Now this may or may not work This is all dependant on the monitor it's self.
Snowbird
Re: MQTT Client
Post by Snowbird » Sat Jul 14, 2018 5:37 pm
same result :) no errors, but nothing happens no matter what value I set.
Re: MQTT Client
Post by kgschlosser » Sat Jul 14, 2018 6:31 pm
could be that the brightness cannot be set.
let me add some error reporting on the last function call
BRIGHTNESS = 100
import ctypes
NULL = None
    BOOL,
    HMONITOR,
    HDC,
    LPARAM
    _fields_ = [
def get_displays():
            hMonitor,
            hMonitor,
        return True
        NULL,
        NULL,
        NULL
    if not SetMonitorBrightness(hMonitor, DWORD(BRIGHTNESS)):
Oh one other thing. This is ging to be a nice thing. This whole thing I am working on with the VESA MCCS coms there is the ability to blank the screen. I am hoping this is also going to turn off the back light.
The other cool thing is if it works is the ability to turn off a single display. the windows API only has monitor off and monitor on which is for all monitors. this is a nice thing for those of us who have dual monitors one for the PC and the other is a TV for watching movies. now we will be able to turn off the monitor and leave the TV on or possibly even black out the monitor if powering it off does something funky with the desktop.
Snowbird
Re: MQTT Client
Post by Snowbird » Sat Jul 14, 2018 6:48 pm
here's the error I get now :
14/07  20:47:31      Traceback (most recent call last):
14/07  20:47:31        Python script "175", line 104, in <module>
14/07  20:47:31          raise ctypes.WinError()
14/07  20:47:31      WindowsError: [Error -1071241854] An error occurred while transmitting data to the device on the I2C bus.
Re: MQTT Client
Post by kgschlosser » Sat Jul 14, 2018 9:40 pm
OK so it is working. I am thinking that your screen does not support it directly.
Are you using a Laptop?
If it is a laptop it could be something the laptop designer made in a way that the brightness is not controlled by the screen but instead by some other mechanism.
You have to remember that these controls need to be implemented by the screen manufacturer if it is not then it will not work. we can test another thing if you want to see if your screen even supports the VESA MCCS control standard.
But lets jump that conversation on over to the thread I made for the plugin instead of here. it is going off topic from this thread.
