PushBullet plugin (Pako)
Re: PushBullet plugin (Pako)
Post by kgschlosser » Sat Mar 02, 2019 3:18 pm
took me a minute there to figure out what you are trying to say.. You mean you are not getting an event (not action).
what you have logging turned on you can see a log for the data coming in from the pushbullet servers but no event is getting triggered.
Give me a bit to check into it.
and this is the information that is getting logged yes?
17:26:42   ---> Welcome to EventGhost <---
17:26:51   PushBullet.WebSocketClosed
17:26:53   PushBullet: Email address obtained
17:26:53   PushBullet: Devices received: [{u'iden': u'ujAEc0DdCp2sjAaILdXEiq', u'icon': u'system', u'created': 1549230967.3364449, u'nickname': u'EventGhost-MediaKam', u'modified': 1549230967.3364489, u'active': True, u'model': u'plugin by Pako', u'app_version': 220, u'type': u'stream', u'kind': u'stream', u'pushable': True, u'manufacturer': u'EventGhost'}, {u'iden': u'ujAEc0DdCp2sjz9quKN0eW', u'icon': u'desktop', u'created': 1549219791.460644, u'nickname': u'KAMPC', u'modified': 1549219791.460649, u'fingerprint': u'{"cpu":"AMD64 Family 23 Model 1 Stepping 1, AuthenticAMD","computer_name":"KAMPC"}', u'active': True, u'remote_files': u'disabled', u'model': u'Windows 10 Home', u'app_version': 396, u'type': u'windows', u'kind': u'windows', u'pushable': True, u'manufacturer': u'Microsoft'}]
17:26:54   PushBullet: Friends received: []
17:26:54   PushBullet: Channels received: []
17:26:54   PushBullet: Targets derived: [(u'EventGhost-MediaKam', u'ujAEc0DdCp2sjAaILdXEiq', 'pc'), (u'KAMPC', u'ujAEc0DdCp2sjz9quKN0eW', 'pc')]
17:26:54   PushBullet: Adding push messaging listener
17:26:54   PushBullet.WebSocketOpened
17:26:54   PushBullet.InternetConnection.Restored
17:26:54   PushBullet: modified_after updated: 1549232285.1083930
17:26:54   PushBullet: WebSocket message: {u'type': u'nop'}
17:27:08   PushBullet: WebSocket message: {u'subtype': u'push', u'type': u'tickle'}
17:27:08   PushBullet: Getting pushes, modified_after = 1549232285.1083930
17:27:08   PushBullet: Response = {u'chats': [], u'blocks': [], u'pushes': [{u'body': u'Start', u'iden': u'ujAEc0DdCp2sjz1Mck4hbg', u'created': 1549232829.275233, u'sender_name': u'[b][size=150]IFTTT[/size][/b]', u'awake_app_guids': [u'web-tbmc1og9qgog3jkneht6g4'], u'title': u'Google Voice Simple Commands', u'direction': u'incoming', u'modified': 1549232829.2962189, u'dismissed': True, u'client_iden': u'udprOCjAgjoR6nAG', u'receiver_email': u'EMAILREMOVED', u'active': True, u'receiver_iden': u'ujAEc0DdCp2', u'type': u'note', u'receiver_email_normalized': u'EMAILREMOVED'}], u'contacts': [], u'clients': [], u'devices': [], u'channels': [], u'texts': [], u'grants': [], u'accounts': [], u'profiles': [], u'subscriptions': []}
Post by kgschlosser » Sat Mar 02, 2019 3:22 pm
Kameleau wrote:
Mon Feb 04, 2019 1:54 am
I see that EG receive the Pushbullet note when I put log level to 5, but no action.
I do not see this in the logs you posted.
I need to see the logs of the actual data that is being received by the plugin in order to be able to determine what the cause of the problem is.
Kameleau
Post by Kameleau » Sun Mar 03, 2019 3:34 am
Hi, here is some image of what doesnt work. Hope it help
This time, I was able to get an Event when testing sending a note with Pushbullet and IFTTT. But I received it and worked only once??!
On the second try, as you can see on the image, no Event is associate with the Pushbullet note. I didnt change anything between the two test.
For the logs, is there a file somewhere with the Pusbullet plugings log? Because I though the log in the Eventghost main windows was what you needed and I posted it. Please let me know what I need to do to get you the log
I put the log from Evenghost main windows attached in a text file
LOG.txt
(4.91 KiB) Downloaded 48 times
Post by kgschlosser » Sun Mar 03, 2019 7:05 pm
ok cool so this is the actual response you are getting.
lets break down the data that is coming in and see if we can isolate the cause.
I am going to need one of these log entries for when it works. and then we can compare the data and see what the difference is. There has to be something there.
so this is what the data is going to look like after I break it down
	u'chats': [],
	u'blocks': [],
	u'pushes': [
			u'body': u'Start',
			 u'dismissed': True,
			 u'active': True,
			 u'type': u'note',
	u'contacts': [],
	u'clients': [],
	u'devices': [],
	u'channels': [],
	u'texts': [],
	u'grants': [],
	u'accounts': [],
	u'profiles': [],
Now I can tell you this from what I see in the screen shots VS what you posted for incoming data. the sender name is off. In one of the screen shots the one where the event gets triggered.
PushBullet.Note.Teest [u'test\n', None, u'ujAEc0DdCp2sjCMlqyMDca', u'IFTTT', '2016-03-02 22:18:32']
you can see the senders name in the payload for the event.
and this is from thee data you posted from the log.
the name in the payload
 u'IFTTT'
is not the same as this
I am not sure if that would be the cause. But I would assume there has to be some kind of filtering somewhere in the plugin. I am not the one that wrote the plugin so I am not going to be able to know if that is what is done right off the top of my head. I would have to read the code to be able to find out.
But we can start off with you checking how things are being transmitted using IFTTT and make sure that everything is correct. Until i get the log entry for the response data I am not going to know 100%
Failip
Post by Failip » Sun Jun 30, 2019 5:00 am
download link gone
Failip
Post by Failip » Sun Jun 30, 2019 5:15 am
dl link down
zogg
Post by zogg » Fri Jul 05, 2019 12:50 pm
As noted, none of the downloads are there anymore.
Please add the plugin back as I really want to use this one. Thanks!
syntesys
Post by syntesys » Tue Jul 16, 2019 5:25 pm
can you reupload the plugin please? Thank you.
Post by kgschlosser » Wed Jul 17, 2019 7:25 am
here you go.
PushBullet-0.2.22.egplugin
(241.61 KiB) Downloaded 126 times
mans
Post by mans » Wed Jul 17, 2019 10:54 pm
Greatday kgschlosser,
With .22 i'm gettig back again the cert error as earlier and i can't get the pugin back to work:
Exception in thread Thread-7:
File "C:\ProgramData\EventGhost\plugins\PushBullet\__init__.py", line 3841, in updateDevices
self.getAccount()
File "C:\ProgramData\EventGhost\plugins\PushBullet\__init__.py", line 3724, in getAccount
account, flag = self.request("GET", API + 'users/me')
File "C:\ProgramData\EventGhost\plugins\PushBullet\__init__.py", line 3685, in request
resp = s.send(prepped, proxies=proxies)
File "C:\Program Files (x86)\EventGhost\lib27\site-packages\requests\sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "C:\Program Files (x86)\EventGhost\lib27\site-packages\requests\adapters.py", line 416, in send
self.cert_verify(conn, request.url, verify, cert)
File "C:\Program Files (x86)\EventGhost\lib27\site-packages\requests\adapters.py", line 228, in cert_verify
"invalid path: {}".format(cert_loc))
IOError: Could not find a suitable TLS CA certificate bundle, invalid path: C:\Program Files (x86)\EventGhost\lib27\python27.zip\certifi\cacert.pem
syntesys
Post by syntesys » Sun Jul 21, 2019 6:15 pm
i have the following error:
Exception in thread Thread-4:
self.getAccount()
File "C:\Program Files (x86)\EventGhost\lib26\site-packages\requests\sessions.py", line 559, in send
File "C:\Program Files (x86)\EventGhost\lib26\site-packages\requests\adapters.py", line 382, in send
raise SSLError(e, request=request)
SSLError: [Errno 1] _ssl.c:493: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
Can someone help me?
Post by kgschlosser » Mon Jul 22, 2019 6:55 am
You guys are going to have to give me a little bit of time to look into this..
If someone possibly has a newer version of the plugin please send me a PM and also attach the plugin in the PM so i can verify if it is newer or not. That would make my life a whole lot easier.
mans
Post by mans » Mon Jul 22, 2019 7:05 am
Appreciated sir, no newer version of this plugin with me, sorry.
Thanks for your help.
LordXilos
Post by LordXilos » Wed Jul 24, 2019 8:26 pm
Hey guys. I am new to eventghost and push bullet. I seem to now have an option to download __init__.py as all the links in this threat seem to be expired. Is this forum the best place to get the latest file or should I look somewhere else?
Post by kgschlosser » Wed Jul 24, 2019 10:59 pm
We had an issue with our last server provider and some data was lost.. I am sorry for the inconvenience. I am hoping that someone will upload the last version. otherwise I am going to have to go back over and modify the plugin again.. It may be a few days until i get it done.
