I will send you all an excuse in advance but I'm kind of a newbie at this.
I run eventghost with dvbviewer and I can't figure out how to solve this.
If i assign the button "OSD-UP" in dvbviewer to a button on my remote it works like it should when I'm in Dvbiviewer.
But if I quit dvbviewer and go to windows and press the assigned "UP" button it will automatically start the DVBviewer software again.
I only want the OSD-UP to be triggered if dvbviewer is already running, it should not trigger the start of dvbviewer when I press it.
any ideas?
dvbviewer + osd up+left+down etfc.
Re: dvbviewer + osd up+left+down etfc.
I think you could solve it using "Enabling Exclusives" ¶
You could find the description the chapter "Enabling Exclusives" of following documentation:
http://www.eventghost.net/docs/controll ... index.html
I hope this helps!
Prinz
I hope this helps!
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
CPU: Intel E5200
OS: WinXP SP3
