MediaMonkey
GBWebmaster
Re: MediaMonkey
Post by GBWebmaster » Wed Feb 01, 2012 8:32 am
Hello Pako,
sorry for my bad english. Close MM four times means, I start it and close it, start it and close it, ... all through EG and the event "MediaMonkey: Exit/Disconnect MediaMonkey: True"
Anytime after this action I get the loginfo (see my last post) and MM works one time as it should.
But with the next start I had the same problem ...
P.S.: To emulate keystrokes with EG is no problem for MM. Only the events "Play", "Next", "Album Jukebox" don't work ...
My OS is Win7 ultimate x86 - is this the problem??
Für den, der nie das Rudel anführt,
Re: MediaMonkey
Post by Pako » Wed Feb 01, 2012 8:50 am
GBWebmaster wrote:My OS is Win7 ultimate x86 - is this the problem??
I do not think it is a problem. My OS is Windows 7 Professional (x86).
Unfortunately I still can not evoke the same state as yours.
Most likely it will be a collision with what you have and I do not.
GBWebmaster
Re: MediaMonkey
Post by GBWebmaster » Wed Feb 01, 2012 8:55 am
But there are only 4 programs installed: MM, XBMC, PowerDVD and dvbviewer (TV-Software).
Then I must work with keystrokes in MM or downgrade to MM3 ... :cry:
GBWebmaster
EDIT:
I found a solution:
When I start MM with the event "MediaMonkey: Start MediaMonkey", then I get a lot of problems,
when I start MM with the event "Start Program: MediaMonkey.exe", then everything looks great - as yet.
jitterjames
Re: MediaMonkey
Post by jitterjames » Wed Feb 01, 2012 1:32 pm
I assume he means "open and then close" four times. I don't know why someone would do that, but I guess he's trying to force the error.
Re: MediaMonkey
Post by Pako » Wed Feb 01, 2012 1:52 pm
jitterjames wrote:I assume he means "open and then close" four times.
Sure, I've understood it from his answers.
However, I try the same way, but no error occurs.
RURon
Re: MediaMonkey
Post by RURon » Sat Feb 04, 2012 11:13 am
Hello all,
I am trying to set up Eventghost with pako's Plugin (V 0.2.12) and MM3 so that when I press a button on my remote when a song is playing, that the current playlist would be emptied and then all songs by the currently playing artist are added to the playlist. I often have a pretty random big playlist running and then I hear a song by some artist and think "hey, more songs of this band please".
I have no clue about python and wonder how the functions that pako's plugin provides can be used. In my idea I have to use the get basic song info function together with the Load playlist by filter function - but just how can I make use of the get basic song info in another function?
Any help greatly appreciated,
have a nice weekend,
Ernie
jitterjames
Re: MediaMonkey
Post by jitterjames » Sat Feb 04, 2012 11:28 pm
you will want to do something with {eg.result}
here's a reference that is very handy: http://www.eventghost.org/docs/scripting.html
depending on what you get back in {eg.result} and how the mm plugin works you might not even need to use scripting, you might just be able to put {eg.result} directly in the macro that requests music.
jitterjames
Re: MediaMonkey
Post by jitterjames » Sat Feb 04, 2012 11:43 pm
When I try to use "get basic song info" with just artist selected (or combination of checkboxes selected) I get this error:
I haven't really used this plugin for a while so I don't know when this might have started happening.
I am using MediaMonkey 4.0.2.1462
using EventGhost 0.4.1.r1544, Oct 31 2011
I tried with the mediamonkey plugin that comes preinstalled in eventghost, and also with the one at the beginning of this post and I get an error in both cases:
edit: this only happens on my laptop, it works fine on my htpc which is running EG r1540 :?: I have no idea why.
MediaMonkey: ___X_____________
   Error in Action: "MediaMonkey: ___X_____________"
   Traceback (most recent call last) (1544):
     File "C:\Program Files\EventGhost\eg\Classes\ActionBase.py", line 170, in CallWrapper
       return self(*args)
     File "C:\Program Files\EventGhost\plugins\MediaMonkey\__init__.py", line 1620, in __call__
       SongData,ix = self.plugin.GetSongData(self.value)
     File "C:\Program Files\EventGhost\plugins\MediaMonkey\__init__.py", line 943, in GetSongData
       return self.workerThread.CallWait(partial(self.workerThread.GetSongData, index),1000)
     File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 234, in CallWait
       return self.Func(func, timeout)()
     File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 62, in __call__
     File "C:\Program Files\EventGhost\plugins\MediaMonkey\__init__.py", line 270, in GetSongData
       SongDataDict[item] = str(itm)
   ValueError: can't format dates this early
jitterjames
Re: MediaMonkey
Post by jitterjames » Sun Feb 05, 2012 1:16 am
This should do it. Paste the following into your tree and assign an event for you remote button:
<EventGhost Version="1540">
    <Macro Name="play more from same artist" Expanded="True">
        <Event Name="add your event here" />
            MediaMonkey.GetBasicSongInfo([False, False, False, True, False, False, False, False, False, False, False, False, False, False, False, False, False], u'')
            EventGhost.PythonScript(u'strWhere = "Artist=\'"+eg.result+"\'"\nprint strWhere\neg.plugins.MediaMonkey.LoadPlaylistBySql(u\'\', strWhere, 2, 2, 2, True)\n  ')
            Speech.TextToSpeech(u'Microsoft Anna - English (United States)', 0, u'Now Playing song by {eg.result}', 0, 100)
RURon
Re: MediaMonkey
Post by RURon » Sun Feb 05, 2012 7:23 pm
Wow, thank you very much jitterjames! Works fantastic! Only the Text to speech doesnt work - when I load the XML into EG, I immediately get errors in the log, so I think EG or the python engine or something maybe doesnt "know" about text to speech?
But it is awesome as it is and again, thank you for the great help - my girlfriend is gonna be impressed ;-)
Unhandled exception in WorkerThread <EventThread>:
Callers stack:
  File "wx\_core.pyc", line 8007, in MainLoop
  File "wx\_core.pyc", line 7303, in MainLoop
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\MainFrame\__init__.py", line 344, in FuncWrapper
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\MainFrame\__init__.py", line 757, in OnCmdOpen
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\Document.py", line 373, in Open
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\Document.py", line 176, in StartSession
Traceback (most recent call last) (1486):
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\ThreadWorker.py", line 201, in __DoOneEvent
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\ThreadWorker.py", line 224, in HandleAction
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\ThreadWorker.py", line 72, in __call__
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\EventThread.py", line 127, in StartSession
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\ActionThread.py", line 44, in StartSession
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\Document.py", line 162, in Load
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\RootItem.py", line 51, in __init__
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\ContainerItem.py", line 41, in __init__
  File "C:\Program Files (x86)\tools\EventGhost\eg\Classes\ActionItem.py", line 75, in __init__
AttributeError: 'Bunch' object has no attribute 'Speech'
jitterjames
Re: MediaMonkey
Post by jitterjames » Sun Feb 05, 2012 8:21 pm
you probably just need to install the "speech" plugin. :) You are most welcome. I already had done something similar, which google searches for guitar tabs for the current song. I can post that too if anyone is interested.
RURon
Re: MediaMonkey
Post by RURon » Mon Feb 06, 2012 4:04 pm
jitterjames wrote:you probably just need to install the "speech" plugin.
right on...now she talks to me ;-) Thanks again!
poleguy
Re: MediaMonkey
Post by poleguy » Wed May 16, 2012 11:08 am
I'm running EventGhost 0.4.1.r1568.
I noticed a bug causing errors to be spewed to the EventGhost screen when MediaMonkey was not running.
I added three lines to MediaMonkey\__init__.py fix this. Without this fix, the error flag is left set, and EventGhost apparently doesn't like this.
I also had a problem where every time I got a play event it would trigger a Keyboard Space command, which would then stop the track, so I had to disable that event. I'm not sure why that happened, but if that is the default way this plugin comes up, that could be improved.
One at Line 45:
from win32api import GetLastError
Two near line 1328:
def isRunning(self): # the fastest way I found ...
hwnd = None
while hwnd != 0:
hwnd = FindWindowEx(None, hwnd, "Winamp v1.x", None)
if hwnd:
if GetModuleFrom_hWnd(hwnd).find("MediaMonkey") >= 0:
junk = GetLastError() # clear error
return True
return False
nonob
Re: MediaMonkey
Post by nonob » Wed Jun 06, 2012 7:22 am
All was working fine until i change my mediamonkey setup type: it was first a standart setup, then i change it to portable setup.
Since i did that, my mediamonkey plugin didn't work anymore:
At evenghost startup i have this window:
Do i really need to change my setup to standart installation ?
nonob
Re: MediaMonkey
Post by nonob » Thu Jun 07, 2012 2:11 pm
Finally i reinstalled mediamonkey (4.0.5.1496) in standart mode (not portable) and the eg mediamonkey plugin works now :)
But, i have another issue, if i close mediamonkey, i have a looping red errors lines in evenghost log, which doens't stop until i restart mediamonkey.., but so remote control doesn't work anymore, i have to retsart evenghost if i want it works again!
Here is the log :
Task.ClosedWindow.MediaMonkey
Traceback (most recent call last) (1568):
  File "C:\Program Files\EventGhost\eg\Classes\Scheduler.py", line 137, in MainLoop
    func(*args, **kwargs)
  File "C:\Program Files\EventGhost\plugins\MediaMonkey\__init__.py", line 1339, in checkIsRunning
    if not self.isRunning():
  File "C:\Program Files\EventGhost\plugins\MediaMonkey\__init__.py", line 1330, in isRunning
error: (2, 'FindWindowEx', 'Le fichier sp\xe9cifi\xe9 est introuvable.')
Task.Deactivated.EventGhost
Task.Activated.Desktop
Task.NewWindow.MediaMonkey
Task.Deactivated.Desktop
Task.Activated.MediaMonkey
   Switch to mode: Mediamonkey
      Activation exclusive: MediaMonkey
Task.Deactivated.MediaMonkey
Task.Activated.EventGhost
IgorPlugUSB.Unknown.289F87EBD4
   Toggle Play
      MediaMonkey: Toggle Play
I have evenghost 0.4.1.r1568 and mediamonkey plugin 0.3.3.
