StandbyControl Plugin - revamped
Re: StandbyControl Plugin - revamped
Post by kgschlosser » Tue Jun 20, 2017 11:50 am
that error is not from the fix i supplied. i corrected that issue
line 80 in the plugin i fixed is no longer the line that is in that error
when using the egplugin file it puts the new plugin in cL\programdata\eventghost\plugins.
your error is coming from c:\program files (x86)\eventghost\plugins
i would go into the c:\program files (x86)\eventghost\plugins folder and delete the folder StandbyControl
Luca Brasi
Post by Luca Brasi » Tue Jun 20, 2017 12:27 pm
Ah ok, sure this makes sense... I'll get rid of the old plugin now
Post by kgschlosser » Tue Jun 20, 2017 3:38 pm
let me know if that did the trick
Luca Brasi
Post by Luca Brasi » Wed Jun 21, 2017 7:11 am
Looking good!
I still get some errors on startup but they are not related to this.
Thank you!
Post by kgschlosser » Wed Jun 21, 2017 8:20 am
well if ya need help with the other errors post a question for them in the General Support
Luca Brasi
Post by Luca Brasi » Sat Jun 24, 2017 11:22 am
I will. Thank you
Kagor
Standby Control 0.5.0-rc6 cannot configured
Post by Kagor » Thu Dec 05, 2019 12:34 pm
Hi, there is a problem with the plugin StandbyControl in RC6. The plugin cannot be configured because the dialog does not appear. An error message is in the LOG that an error occurred when opening the help file due to mode="rtb".
Please check and correct it.
Many thanks in advance.
Mfg
Klaus
Post by kgschlosser » Thu Dec 05, 2019 5:43 pm
This problem has been fixed. check here. I also moved your post into the relevant support topic for the plugin.
viewtopic.php?p=46653#p46653
Kagor
Post by Kagor » Fri Dec 06, 2019 2:39 pm
Sorry, I assumed that the latest version of StandbyControl (1.14)
would also be updated with the installation of RC6.
Thanks again ...
Klaus
