Growl
Growl
Post by Pako » Fri Oct 21, 2011 10:37 am
I created a new plugin - Growl (Growl for Windows of course).
With this plugin you can send a notifications to Growl.
This allows you to use a lot of nice OSD to display your information.
Growl_003.zip
Plugin Growl - version 0.0.3
(12.17 KiB) Downloaded 348 times
Growl_002.zip
Plugin Growl - version 0.0.2
(11.6 KiB) Downloaded 786 times
Growl.zip
Plugin Growl - version 0.0.1
(11.33 KiB) Downloaded 374 times
Re: Growl
Post by Pako » Sat Oct 22, 2011 10:41 am
New version - 0.0.2.
I added a new option - it is now possible to coalesce notes.
Unfortunately, I have found so far only one display that supports coalescing.
It's a display that is called Meter.
maurilloh
Re: Growl
Post by maurilloh » Wed Nov 02, 2011 2:30 pm
I think that this Plugin is great, thank you.
I've had also an idea, but i don't have the ability to do it... :cry:
is possible to create a plugin in order to receive the messages from growl and transform them as event?
In this way it would be possible to use growl as bridge between its plugin and eventghost.
One example would be:
1. send a message from my phone to pidgin (with msn)
2. pidgin has a plugin to visualize the message in growl
3. growl send the message to eventghost
4. eventghost create an event an something happen
...with specific words we can control the pc.
Maurilloh
Re: Growl
Post by Pako » Thu Nov 03, 2011 7:01 am
But such a plugin already does exist. Even two.
One is the EventGhost display and the second EventGhost forwarder.
These plugins are installed (I think it's logical) in the program Growl.
Display installation:
1. Create the folder:
XP: "C:\Documents and Settings\{USER}\Local Settings\Application Data\Growl\2.0.0.0\Displays\EventGhost"
Vista or higher: "C:\Users\{USER}\AppData\Local\Growl\2.0.0.0\Displays\EventGhost"
2. Copy the files from this package there.
Forwarder installation:
XP: "C:\Documents and Settings\{USER}\Local Settings\Application Data\Growl\2.0.0.0\Forwarders\EventGhost Forwarder"
Vista or higher: "C:\Users\{USER}\AppData\Local\Growl\2.0.0.0\Forwarders\EventGhost Forwarder"
Assumed {USER} is your username.
There is even another similar plugin. Its name is EventGhost Snarl style.
Snarl is a program similar to Growl (I think better).
For less experienced users may be that he will see its setup too complicated.
Currently I am working on a Snarl plugin for EventGhost.
maurilloh
Re: Growl
Post by maurilloh » Tue Nov 15, 2011 12:59 pm
Thank you very much Pako!!
I'll try both immediately.
maurilloh
maurilloh
Re: Growl
Post by maurilloh » Wed Nov 16, 2011 9:25 am
Hi Pako, I've tried EventGhost Snarl style and it woks fine but i have an error when i try to send the notification to Evenghost: (simple,basic,etc.) from PidginSnarl plugin, incoming message.
If I press "test" it works but if i really receive a message i have an error like this (see attachement).
Can you help me? I've made something wrong?
Thanks.
Error
Immagine 1.png (12.48 KiB) Viewed 10614 times
Re: Growl
Post by Pako » Wed Nov 16, 2011 10:22 am
Maybe it is some incompatibility (I assume so on the basis of a string name that is displayed in bold).
Maybe there is some character, with whom EG style has problems.
Can you please to determine (using a different style than EG) what Pidgin plugin sends?
And can you please try a different (than Pidgin) plugin with EG style?
I do not use Pidgin, so I can not try it.
Re: Growl
Post by Pako » Thu Nov 17, 2011 6:34 am
Nevertheless, I managed to find out what the problem is.
Please download the new version.
maurilloh
Re: Growl
Post by maurilloh » Thu Nov 17, 2011 8:26 pm
Now it's perfect!
You are a genius :shock: !
Thank you Pako..again
knobblywobbly
Re: Growl
Post by knobblywobbly » Wed Sep 26, 2012 7:39 pm
I've installed this plugin, but what format do I use for notification types? Can you give me an example please?
Re: Growl
Post by Pako » Sun Sep 30, 2012 6:31 am
knobblywobbly wrote:I've installed this plugin, but what format do I use for notification types? Can you give me an example please?
Unfortunately I can not understand what format you have in mind.
Please can you explain in more detail what is not clear to you?
It is good to use screenshots or attach a configuration file and write what you want to achieve.
Although, I might already understand.
You do not need any format. It's just a name that you can design (which describes how it uses).
cariba
Re: Growl
Post by cariba » Mon Oct 22, 2012 12:48 pm
Hi there,
I get the error's: When sending a notification:
Growl: Notify: EventGhost: bla: bla
Sending notification [EventGhost] to localhost:23053
Invalid response ('400', 'Missing key hash')
Error "('400', 'Missing key hash')" during sending notification
How can I solve this?
Re: Growl
Post by Pako » Mon Oct 22, 2012 1:13 pm
In your environment (probably ), something is wrong.
I can not say anything more when I do not have any information at all.
I have never seen such an error.
cariba
Re: Growl
Post by cariba » Mon Oct 22, 2012 1:58 pm
One one of my PC's it's working, on the other one it's not. I can't figure out the differences, what can I do to diagnose the problem more?
cariba
Re: Growl
Post by cariba » Mon Oct 22, 2012 3:18 pm
I'm not sure what the cause of the problem was, but I reinstalled Growl for Windows and now it works.
