TellStick Duo
TellStick Duo
Post by krambriw » Tue Oct 18, 2011 7:33 am
This is a plugin for the TellStick Duo RF transceiver. More product information can be found here:
http://telldus.com/products/tellstick_duo
The plugin supports receiving of events as well as transmission of commands.
Latest version always here:
http://sto.hopto.org/Release/TellStickDuo/
Upgrade from earlier versions which might not be compatible:
Preferred way:
- disable the TellStickDuo plugin in EG, save and exit EG
- replace the files with the content of the zip-file
- restart EG
- open the configuration dialog for the TellStickDuo plugin
- make any modifications to the settings
- click OK, enable the plugin and it should start
- save EG
Brutal way:
- restart EG
- you will see an error message that the plugin cannot start
- click OK and it should start
- save EG
Setting up the filtering:
This is the sample default content that will accept messages from the listed sensor brands:
def sensors_supported():
    list = [
        "mandolyn",
        "oregon",
        "fineoffset"
    return list
If you prefer, you can for instance filter down to types and even id level.This example would set the filtering to accept only Oregon sensors of type 1A2D:
    list = [
        "oregon|1A2D"
    return list
This filter would do the same for Oregon and UPM/ESIC sensors and in addition, only accept specified id's:
    list = [
        "oregon|1A2D|21",
        "oregon|1A2D|11",
        "oregon|1A2D|32",
        "mandolyn|temperaturehumidity|11",
        "mandolyn|temperaturehumidity|81"
    return list
bongolf
Re: Plugin: TellStick Duo
Post by bongolf » Wed Oct 19, 2011 6:09 pm
I'm having problems activating this plugin. When I try the log says:
19:58:09 Traceback (most recent call last) (1540):
19:58:09 File "C:\Program Files\EventGhost\eg\Classes\PluginInstanceInfo.py", line 153, in CreateInstance
19:58:09 plugin.__init__()
19:58:09 File "C:\Program Files\EventGhost\plugins\TellStickDuo\__init__.py", line 158, in __init__
19:58:09 self.callbackId_1 = self.dll.tdRegisterDeviceChangeEvent(
19:58:09 File "ctypes\__init__.pyc", line 366, in __getattr__
19:58:09 File "ctypes\__init__.pyc", line 371, in __getitem__
19:58:09 AttributeError: function 'tdRegisterDeviceChangeEvent' not found
Software
Program Version: 0.4.1.r1540
Build Time: on, 24 aug 2011 07:20:58
Python Version: Stackless Python 2.6.5 final 0
wxPython Version: 2.8.12.0
System
Operating System: Microsoft Windows 7 Professional, 32-bit (build 7600)
CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
RAM: 2046 MB
USB-Devices
USB-UIRT Device: USB\VID_0403&PID_F850
USB Composite Device: USB\VID_05A4&PID_1000
USB Input Device: USB\VID_05A4&PID_1000&MI_00
USB Input Device: USB\VID_05A4&PID_1000&MI_01
Telldus TellStick: USB\VID_1781&PID_0C30
Generic USB Hub: USB\VID_1A40&PID_0101
Any suggestions of what I can do to fix this?
Post by krambriw » Wed Oct 19, 2011 7:35 pm
Do you have a TellStick Duo or the old TellSTick? What version of Telldus Center are you using? I am using 2.1.0
bongolf
Post by bongolf » Wed Oct 19, 2011 8:47 pm
I have the TellStick Duo (well I have the old TellStick as well, but it is not connected now) and I am also using TelldusCenter 2.1.0.
And it works just fine controlling the switches from TelldusCenter.
Post by krambriw » Thu Oct 20, 2011 8:19 am
Strange, it works fine here. What is happening is that the plugin fails when getting the entry point to the function in the dll.
Old dll?
You have not manually copied the TelldusCore.dll to some EventGhost folder, have you?
You can try this test version where I have disabled the change event callback so we can see if the rest is working
(22.05 KiB) Downloaded 685 times
bongolf
Post by bongolf » Thu Oct 20, 2011 3:54 pm
Thank you for trying to help me here!
I have tried with the attached .py-file but it looks exactly the same...
I haven't moved any DLLs manually.
The TelldusCore.dll-file is only located in c:/Program Files/Telldus
Under properties/details for the file it says that the version is 2.1.0.0
Post by krambriw » Thu Oct 20, 2011 4:04 pm
It cant be that it is exactly the same problem, I guess it fails on the next entry point in the dll or what?
It works however for me (and several other users).
I have the same version of EG as you but only XP and Vista
I'm sorry, don't know what this could be...
bongolf
Post by bongolf » Thu Oct 20, 2011 7:53 pm
Sorry, I wasn't looking close enough...
This is what it says now:
17:38:24 Traceback (most recent call last) (1540):
17:38:24 File "C:\Program Files\EventGhost\eg\Classes\PluginInstanceInfo.py", line 153, in CreateInstance
17:38:24 plugin.__init__()
17:38:24 File "C:\Program Files\EventGhost\plugins\TellStickDuo\__init__.py", line 166, in __init__
17:38:24 self.callbackId_3 = self.dll.tdRegisterSensorEvent(
17:38:24 File "ctypes\__init__.pyc", line 366, in __getattr__
17:38:24 File "ctypes\__init__.pyc", line 371, in __getitem__
17:38:24 AttributeError: function 'tdRegisterSensorEvent' not found
Post by krambriw » Thu Oct 20, 2011 8:34 pm
Yes, for some strange reason, the plugin fails in getting the entry point functions in the TelldusCore.dll
Try the script below and check what response you get
(New macro, eventghost, python scrript, copy & paste the script below, apply, ok, save and then run)
import time, winsound, logging, os
from ctypes import(
	windll, WINFUNCTYPE, POINTER, string_at,
	wstring_at, c_char_p, c_int, c_ubyte, c_void_p,
from datetime import datetime
try:
    dll = windll.LoadLibrary("TelldusCore.dll")
except:
    raise eg.Exception("Error loading TelldusCore.dll")
dll.tdInit()
try:
    numDevices = dll.tdGetNumberOfDevices()
except:
    numDevices = 0
selected = 0
for i in range(numDevices):
    id = dll.tdGetDeviceId(i)
    name = (c_char_p(dll.tdGetName(id))).value
    print i, id, name
#dll.tdClose()
bongolf
Post by bongolf » Fri Oct 21, 2011 12:32 pm
14:25:30 Python Script
14:25:30 0 1 Vardagsrum Orange
14:25:30 1 2 Matsalen
14:25:30 2 4 Vardagsrum
14:25:30 3 5 Vardagsrum Green
14:25:30 4 6 Gillestuga
And that's the 5 switches I currently have installed.
Post by krambriw » Sat Oct 22, 2011 12:16 pm
OK, try now this extended script.
Only start it once, otherwise EG will crash. After the test you need to restart EG
If it starts with "success", try to generate the various events and you should see them in the EG log window
from ctypes import(
try:
except:
dll.tdInit()
try:
except:
    numDevices = 0
selected = 0
    print i, id, name
DEVICEEVENTPROC = WINFUNCTYPE(
                                        c_void_p,
                                        c_int,
                                        c_int,
                                        POINTER(c_ubyte),
                                        c_int,
                                        c_void_p
SENSOREVENTPROC = WINFUNCTYPE(
                                        c_void_p,
                                        POINTER(c_ubyte),
                                        POINTER(c_ubyte),
                                        c_int,
                                        c_int,
                                        POINTER(c_ubyte),
                                        c_int,
                                        c_int,
                                        c_void_p
DEVICECHANGEEVENTPROC = WINFUNCTYPE(
                                        c_void_p,
                                        c_int,
                                        c_int,
                                        c_int,
                                        c_int,
                                        c_void_p
RAWDEVICEEVENTPROC = WINFUNCTYPE(
                                        c_void_p,
                                        POINTER(c_ubyte),
                                        c_int,
                                        c_int,
                                        c_void_p
def deviceEventCallback(deviceId, method, p1, i3, p2):
    deviceName = (c_char_p(dll.tdGetName(deviceId))).value
    deviceType = (c_char_p(dll.tdGetModel(deviceId))).value
    print(
        "EventCallback from script: "
        + deviceName
        + deviceType
def sensorEventCallback(
    protocol,
    model,
    id,
    dataType,
    value,
    timestamp,
    callbackId,
    context
    TELLSTICK_TEMPERATURE = 1
    TELLSTICK_HUMIDITY = 2
    strProtocol = string_at(protocol)
    strModel = string_at(model)
    strValue = string_at(value)
    dType = ''
    if(dataType == TELLSTICK_TEMPERATURE):
        dType = "Temperature:"
    elif(dataType == TELLSTICK_HUMIDITY):
        dType = "Humidity:"
    print(
        "SensorEventCallback from script: "
        +strProtocol
        +strModel
        +str(id)
        +dType
        +strValue
        +str(datetime.fromtimestamp(timestamp))
def deviceChangeEventCallback(deviceId, changeEvent, i3, i4, p1):
    print(
        "ChangeEvent from script: "
        + deviceName
        + deviceType
def deviceRawEventCallback(p1, i1, i2, p3):
    strData = string_at(p1)
    if (strData == ""):
        return
    print(
        "RawEvent from script: "
        + strData
        + "Duo_ID:"
        + str(i2)
deviceEventProc = DEVICEEVENTPROC(
                                deviceEventCallback
deviceChangeEventProc = DEVICECHANGEEVENTPROC(
deviceRawEventProc = RAWDEVICEEVENTPROC(
sensorEventProc = SENSOREVENTPROC(
                                sensorEventCallback
try:
    callbackId_0 = dll.tdRegisterDeviceEvent(
                                deviceEventProc,
                                0
    print "Success", callbackId_0
except:
    print "Failed"
try:
    callbackId_1 = dll.tdRegisterDeviceChangeEvent(
                                    deviceChangeEventProc,
                                    0
    print "Success", callbackId_1
except:
    print "Failed"
try:
    callbackId_2 = dll.tdRegisterRawDeviceEvent(
                                    deviceRawEventProc,
                                    0
    print "Success", callbackId_2
except:
    print "Failed"
try:
    callbackId_3 = dll.tdRegisterSensorEvent(
                                    sensorEventProc,
                                    0
    print "Success", callbackId_3
except:
    print "Failed"
#dll.tdClose()
bongolf
Post by bongolf » Sun Oct 23, 2011 8:57 am
Here comes the result:
10:54:23 Python Script
10:54:23 0 1 Vardagsrum Orange
10:54:23 1 2 Matsalen
10:54:23 2 4 Vardagsrum
10:54:23 3 5 Vardagsrum Green
10:54:23 4 6 Gillestuga
10:54:23 Success 3
10:54:23 Failed
10:54:23 Success 4
10:54:23 Failed
10:56:01 TellStickDuo: Turn on Vardagsrum Orange
10:56:01 Retry nbr: 1
10:56:02 Retry nbr: 2
10:56:02 Retry nbr: 3
10:56:02 Retry nbr: 4
10:56:02 An error occurred while trying to transmit
Post by krambriw » Sun Oct 23, 2011 11:10 am
This is very odd, partly working, it must be a version problem of some kind.
- Have you downloaded the latest plugin (note I made a change later the same day I first published it)?
- Have you tried the TS2 plugin for EG (It should work with Duo for transmissions) and do you get the same problem?
- Have you tried re-install Telldus Center?
- Have you possibility to try in another PC or in a virtual machine like VMWare?
Post by krambriw » Wed Oct 26, 2011 5:13 am
New version uploaded in first post.
"# 2011-10-26 Blocking repeated events within 0.3 seconds"
bjca
Post by bjca » Thu Oct 27, 2011 8:15 am
Think it would be good if this "blocking" period was configurable.
The Nexa motion sensors, magnet sensors and even wall senders create bursts of events during up to 3 sec... at least according to the log in EG.
