Spotify (api is partially broken)
Re: Spotify
Post by krambriw » Fri Nov 14, 2014 6:19 am
how to send it
Depends highly on what your control system is expecting? Like what it supports and what format the message must have. You have to more specific.
There are several plugins available for network communication.
What is your use case? Is this private use or commercial. I do not support commercial projects in this forum.
sveflo
Re: Spotify
Post by sveflo » Fri Nov 14, 2014 10:20 am
This is for home use
The format i want is plain text, the control system accepts plain text via TCP/ip /Telnet
i only need to send the song title as plain text via TCP/IP - Telnet to my control prosessor and from there i know what to do, it is a Crestron control prosessor
Thankyou for the help
EDIT - Got it working and can now send the track and artist information :)
Are there a function to exctract the Album cover art URL ? :)
Re: Spotify
Post by krambriw » Fri Nov 14, 2014 2:13 pm
Try to add this plugin to your configuration
http://eventghost.net/forum/viewtopic.p ... 105#p32851
Then try this script instead (modify it so it fits with the port and ip etc of your target machine
pl = eg.event.payload
artist = pl[0]
track = pl[1]
#Add code to send artist/track to your control system...
eg.plugins.BroadcastListener.Broadcast(
    artist+' - '+track,
    u'payload',
    u'192.168.10.11',
    33334
When a track is changed in Spotify, the event triggers the macro with the script and the message is sent out via TCP/IP. As example I get this
15:09:14   Broadcast.Sting - Practical Arrangement 'payload'
sveflo
Re: Spotify
Post by sveflo » Mon Nov 17, 2014 7:15 am
Hi, thanks for the help! got it working just fine now, but is there a possibility to extract the URL for the album cover image?
Thanks again!
Re: Spotify
Post by krambriw » Mon Nov 17, 2014 1:29 pm
There is unfortunately no support to get the images from the current api I'm using for the Spotify plugin. The closest I have found is described in this topic.
http://eventghost.net/forum/viewtopic.p ... over#p8734
If you can find where the images are stored by Spotify (I think they are downloaded locally somewhere when the track is played) you could eventually create a similar script that triggers and sends it.
Best regards
leothlon
Re: Spotify
Post by leothlon » Mon Nov 24, 2014 11:38 am
I was just browsing the spotify api pages and it seems they have added alot of functionalities nowdays.
So i was woundering if it still not possible to play spesific playlist and such without having to emulate a load of keypresses and stuff?
Re: Spotify
Post by krambriw » Wed Nov 26, 2014 5:28 am
Sure, the Spotify api is providing much more then the library I am using for this Spotify plugin. Unfortunately, I have not seen that one updated with new functions. As mentioned before, the python support for Windows seems not to be the highest priority, at least I have not found a way to make alternative libraries work. So instead, I jumped on the Mopidy track.
Mopidy is an excellent player that also handles Spotify and supports more features. Mopidy runs under Linux, for instance in a virtual machine or on a Raspberry Pi. Check out the plugin I wrote here
http://eventghost.net/forum/viewtopic.php?f=9&t=6360
niccoc1603
Re: Spotify
Post by niccoc1603 » Sun Dec 21, 2014 6:00 pm
Hello, I got a problem when trying to open spotify : "directory name not valid"
Running latest plugin version
Re: Spotify
Post by krambriw » Mon Dec 22, 2014 7:28 am
Yes, this is a known problem if you run windows 7 64 bit or later. There is an updated version where this should be fixed and I would be interested if you can try it. Also, run EG as 'Administrator' to give EG necessary control of the Spotify application.
You find the current latest version here:
http://sto.hopto.org/Release/Spotify/Current%20version/
niccoc1603
Re: Spotify
Post by niccoc1603 » Mon Dec 22, 2014 11:49 am
Hmm I get this error at EG startup with this version
Error starting plugin: Spotify
Traceback (most recent call last) (1669):
File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginInstanceInfo.py", line 177, in Start
TypeError: __start__() takes exactly 2 arguments (1 given)
Re: Spotify
Post by krambriw » Mon Dec 22, 2014 1:41 pm
1) Open the configuration dialog of the plugin
2) Check that the proposed path to Spotify application looks ok
3) Click OK, now the plugin should start correctly
4) Save the EG config
niccoc1603
Re: Spotify
Post by niccoc1603 » Wed Dec 24, 2014 10:54 am
Thanks, well actually I managed to launch Spotify with standard App Launch action.
Is it possible to remotely perform searches?
Re: Spotify
Post by krambriw » Thu Dec 25, 2014 11:27 am
No, is not supported and not possible to add with current library
opitmalt
Re: Spotify
Post by opitmalt » Sat Mar 14, 2015 8:49 am
The latest version of the desktop Spotify client seems to have broken the plugin. Do you think a fix is possible?
Telorast
Re: Spotify
Post by Telorast » Sat Mar 14, 2015 11:30 am
It's an easy fix. If you don't want to wait for a new version you can open "\EventGhost\plugins\Spotify\__init__.py" then scroll down to row 205. You'll see this code:
    def findSpotifyWindow(self):
        try:
            self._hwnd = win32gui.FindWindow("SpotifyShadow", None)
            if self._hwnd > 0:
                self.bFound = True
                self.bFound = False
        except:
       	    self.bFound = False
Replace the SpotifyShadow with SpotifyMainWindow so it looks like this:
        try:
            self._hwnd = win32gui.FindWindow("SpotifyMainWindow", None)
            if self._hwnd > 0:
                self.bFound = True
                self.bFound = False
        except:
       	    self.bFound = False
Restart EventGhost and it should be working again. It won't report what's playing but at least you can control the player.
