Webserver
davidmark
Re: Webserver
Post by davidmark » Fri Nov 18, 2016 1:09 pm
kgschlosser wrote:i believe this issue needs to be fixed at the core for triggered events. i will make the repair and send the information over to the powers that be and see if it will get added... the reason why i think it needs to be fixed at the core is because it's really an issue related to the TriggerEvent and also having to go through all of the plugins to correct it a much larger undertaking and it will also take care of any possible problems that can arise from this issue...
but now others know what the issue is and how to fix it..
TY
I assume you mean the Broadcaster issue, not the patch for the Web server. There's no ambiguity about the Web server issue; needs to be fixed in the Web server plug-in as using "latin1" to decode query string parameters is incorrect. Still no response on the GitHub pull request. :(
Not sure I agree on the Broadcaster issue either. Should be the responsibility of the plug-in to pass properly decoded strings to TriggerEvent. In this case, the characters are coming from UDP and should clearly be decoded with UTF-8. No idea what other plug-ins may pass to TriggerEvent and a central change may break some of them.
Thanks and good luck!
Re: Webserver
Post by Sem;colon » Thu Dec 08, 2016 2:55 pm
Hello all,
just a quick update with all the latest changes:
- bugfix (Added "self.protocol_version = 'HTTP/1.1'" for ws connections)
- bugfix (Fixed incorrect "latin1" decoding)
- some other fixes and cleanup
(229.53 KiB) Downloaded 254 times
m19brandon
Re: Webserver
Post by m19brandon » Sat Dec 31, 2016 2:50 am
Thanks for 3.13.1, no issues.
yokel22
Re: Webserver
Post by yokel22 » Wed Feb 01, 2017 1:23 am
I'm getting this error on start with the last couple of versions of this plugin(3.13.1, 3.13.3). Most recent one that doesn't give this error for me is v3.12.1 that Pako posted. I'm running EG 0.4.1.r1172.
Foune
Re: Webserver
Post by Foune » Sat Feb 18, 2017 8:56 pm
Same problem here
topix
Re: Webserver
Post by topix » Mon Feb 20, 2017 4:29 pm
EG 0.4.x has no function eg.Utils.IsVista (only EG 0.5.x). I replaced it in the plugin with the code of the function. Please try the attached file.
webserver 3.13.4
(229.67 KiB) Downloaded 248 times
yokel22
Re: Webserver
Post by yokel22 » Fri Feb 24, 2017 1:48 pm
Thanks, working without error now on 4.xx
eddiex666
Re: Webserver
Post by eddiex666 » Thu Apr 13, 2017 1:52 pm
just asking..
is it possible to receive json into this webserver plugin?
I am trying to receive a trap from a SMS provider and i useing webserver plugin.
When i receive a trap i see:
Webserver: Exception on handle_one_request: 'method'
Eddie
Re: Webserver
Post by blaher » Tue Apr 18, 2017 4:44 am
topix wrote:EG 0.4.x has no function eg.Utils.IsVista (only EG 0.5.x). I replaced it in the plugin with the code of the function. Please try the attached file.
Thank you, version 3.13.3 that comes with rc1 didn't work for me with just a simple call like: http://192.168.0.17:8083/?test
3.13.4 works well.
topix
Re: Webserver
Post by topix » Thu Apr 20, 2017 6:54 pm
please try again with 0.5.0-rc2. We made a mistake when replacing the windows version check.
Re: Webserver
Post by kgschlosser » Thu May 18, 2017 8:22 am
OK here is one for ya..
I am not sure what the webserver is doing when this happens. but.. if you create a firewall rule on any port doesn't matter what port it is and set it to block eventghost. the webserver plugin tries to access it. and this is causing me some grief. I figured I would try to save some time and maybe someone who knows the code would take a look see at what is going on.
george tirebuyer
Re: Webserver
Post by george tirebuyer » Fri May 19, 2017 10:18 am
The webserver works ok until I restart Eventghost. It stops responding and I have to reboot to get it working again. Running on Win7 .o4 r1722. I'm guessing the port is not shutting down on EG exit. Is there something I need to configure? Any help is appreciated.
wysocki
Re: Webserver
Post by wysocki » Sat Jun 10, 2017 12:33 am
george tirebuyer wrote:The webserver works ok until I restart Eventghost. It stops responding and I have to reboot to get it working again. Running on Win7 .o4 r1722.
Same problem here since I installed 3.13.4!
Foune
Re: Webserver
Post by Foune » Tue Aug 01, 2017 3:58 pm
I have exactly the same problem and it is really annoying as I'm tuning some plugins and I need to restart Eg several times a week.
To be more precise the port used until the reboot gets freezed, changing the port "solve" the problem. Switching back to the port don't solve it. I tried to kill all processes linked to the port using netstat kill pid blabla with no success.I tried a lot of things, the only way to get it back to normal is to restart the machine.
wysocki
Re: Webserver
Post by wysocki » Wed Aug 02, 2017 7:19 pm
Really would be great if someone could figure this out. I've tried reinstalling versions from 0.4.1.r1710 through 0.5.0-rc4 and webserver versions 3.8 through 3.13 and somehow they all now have the same problem: Restarting EG breaks webserver - have to then restart computer. LITTLE HELP PLEASE! :cry:
