Webserver
Re: Webserver
Post by Pako » Thu Feb 18, 2016 7:57 am
I do not know where the problem is.
For me, it works as expected.
Note:
This can be a problem when there are identically named variables (persistent and temporary).
yokel22
Re: Webserver
Post by yokel22 » Fri Feb 19, 2016 7:34 am
That is likely what it is. I'm using the same #id's for setting temp & persistent variables. I'll try a different tag selector & see what happens. Thanks.
wysocki
Re: Webserver
Post by wysocki » Fri Feb 19, 2016 11:46 pm
Think I found a bug in the Periodic broadcast. If you run the Periodically Broadcast Data several times consecutively, then do a Stop Periodic Tasks, it doesn't stop them all. Try this example, run the first macro a few times then run the second once. Webserver still broadcasts regularly until you run the second macro again. There's not a one for one relationship (I ran the first macro 10 times then had to run the second macro 4 times to stop all broadcasts).
Re: Webserver
Post by Pako » Sat Feb 20, 2016 8:12 am
Yes, it looks like a bug. I try to make it more stupid-resistant.
What's the point of run one the same task "Periodically Broadcast" multiple times?
wysocki
Re: Webserver
Post by wysocki » Mon Feb 22, 2016 4:41 pm
I created a mailbox monitor. I put a magnetic sensor switch on the mailbox door, and when the mailman (or someone else) opens the door, it was wired to an X10 module which runs a macro broadcasting the event every 5 minutes until someone resets it. Sometimes the door gets opened a couple times before it gets reset. One STOP command did not silence all the events.
Re: Webserver
Post by Pako » Mon Feb 22, 2016 5:29 pm
It is not desirable to unnecessarily start tasks running in the background.
This can be solved in different ways. For example:
Solution 1:
You can introduce (temporary) variable "Running". This variable can be boolean. Before you want to start periodic broadcasting, first you will test the value of the variable. If Running == True, you will not re-run the same task. If Running == False, you can normally start your task and change the value to True.
Once you stop task, you change the state of variable Running to False.
Solution 2:
Before start of each periodic tasks, you can preemptively stop tasks that were perhaps previously running (it can be a hindrance in some cases).
Note:
Appropriate actions to test the state of variables not yet exist.
For example you can use the method as shown in attached picture.
yokel22
Re: Webserver
Post by yokel22 » Tue Mar 08, 2016 9:23 pm
Pako, i was wondering if you'd consider adding a delete persistent/temporary variable action to the plugin? FYI: your advise on the persisent/temp variables a few posts back was spot on.
Re: Webserver
Post by Pako » Fri Mar 18, 2016 9:53 am
yokel22 wrote:Pako, i was wondering if you'd consider adding a delete persistent/temporary variable action to the plugin?
I'll think about it.
V_J
Re: Webserver
Post by V_J » Sat Apr 30, 2016 3:12 pm
Im trying to send an event to another webserver and get the message "the authentication line is badly formed"
The webserver is on a Loxone Miniserver (some home automation thing), and I want to send an http command that looks like this:
http://user:password@ipaddress/dev/sps/ ... able/value
This works in a browser. The value field should be an eg value from the payload. In the send event to another webserver, I set the following:
event: value
utl: http://ipaddress/dev/sps/io/variable/
username: user
password: password
But I get the message "the authentication line is badly formed.
Any thoughts?
Jorg
Re: Webserver
Post by Sem;colon » Sun May 01, 2016 9:12 am
Try to not fill event, username and password in the action and use the url you used on the browser
V_J
Re: Webserver
Post by V_J » Mon May 02, 2016 8:12 am
I tried that, but it gave a different error. I will be able to post it in a few days.
V_J
Re: Webserver
Post by V_J » Mon May 02, 2016 5:21 pm
If I do not put an event, username or password, and put the url as in the previous post, I get the following errors:
Error in Action: "Webserver: Send event to another webserver: "
Traceback (most recent call last) (1700):
return self(*args)
File "C:\Program Files (x86)\EventGhost\plugins\Webserver\__init__.py", line 3530, in __call__
handle = urlopen(req)
File "urllib2.pyc", line 126, in urlopen
File "urllib2.pyc", line 391, in open
File "urllib2.pyc", line 409, in _open
File "urllib2.pyc", line 369, in _call_chain
File "urllib2.pyc", line 1161, in http_open
File "urllib2.pyc", line 1107, in do_open
File "httplib.pyc", line 657, in __init__
File "httplib.pyc", line 682, in _set_hostport
InvalidURL: nonnumeric port: 'admin@192.168.2.3'
In the url, I used admin for both username and password (temporary change).
Re: Webserver
Post by Sem;colon » Mon May 02, 2016 9:23 pm
I'm sorry, you're right...
You Need to use the Username and Password field.
But leave the Event blank.
Like: http://ipaddress:80/dev/sps/io/variable/value
For testing you could also deactivate the Password on your Loxone Server.
V_J
Re: Webserver
Post by V_J » Fri May 06, 2016 8:15 am
If I do not put an event, but just the website, and a username (I removed the password on the server), I get
The authentication line is badly formed.
Not sure if it is related, but it is the same error message I get when I put a non-existing username.
Jörg
V_J
Re: Webserver
Post by V_J » Fri May 06, 2016 4:59 pm
Ok, I made a mistake... I had '/' in the url in stead of '\'... However, it does not work with '\' either; it gives the following:
This page isn't protected by authentication.
But we failed for another reason.
return self(*args)
File "C:\Program Files (x86)\EventGhost\plugins\Webserver\__init__.py", line 3537, in __call__
print "ERROR "+str(e.code)
AttributeError: 'URLError' object has no attribute 'code'
I cannot disable authentication to the server to check, but the behaviour is the same with our without password (I can disable password).
Jörg
