E-mail
VADIM
E-mail
Post by VADIM » Wed Dec 11, 2013 11:58 am
Hello
I am trying to activate E-mail plugin with Gmail but get this error
SMTP Protocol Error: Cannot connect to SMTP server "smpt.gmail.com:465"
1. My FireWall disabled ,
2. i tried port 25 instead of 465
3.I tried connect with Telnet and it looks connected.
Please help
Re: E-mail
Post by Pako » Wed Dec 11, 2013 12:38 pm
I opened a new file in EventGhost, I added E-mail plugin and I configured it as follows:
It worked on the first try.
I think that the problem must be elsewhere than in EventGhost or plugin.
VADIM
Re: E-mail
Post by VADIM » Wed Dec 11, 2013 2:50 pm
Hi Pako
Thank for answer .
May be you can send me plugin " E-mail " you are using .
I also see that you using IMAP instead of POP.
Thanks Vadim
Re: E-mail
Post by Pako » Wed Dec 11, 2013 3:27 pm
VADIM wrote:Hi Pako
Thank for answer .
May be you can send me plugin " E-mail " you are using.
I use the last version that was published here (post from 2013 4 24 Wed, 09:37).
VADIM wrote:I also see that you using IMAP instead of POP.
Yes, I prefer to use IMAP if possible.
VADIM
Re: E-mail
Post by VADIM » Wed Dec 11, 2013 4:43 pm
Hi Pako
I tried the newest plugin , but without the success.
My be problem in my Email Action configuration , can you please send me example .
Many thanks Vadim
Re: E-mail
Post by Pako » Wed Dec 11, 2013 5:00 pm
VADIM wrote:My be problem in my Email Action configuration , can you please send me example.
I highly doubt it.
However - here is an example of an action that sends an e-mail.
VADIM
Re: E-mail
Post by VADIM » Wed Dec 11, 2013 7:37 pm
Hi Pako
You are right the problem in the other place , the last i think is maybe my gmail account configurations .
If you know something about the requirements please tell me .
I am working with Eventghost tcp from/to my own Home Automation system , some plugins working very well but some require a lot of tuning .
Any way many many thanks and Best Regards .
dacari
Re: E-mail
Post by dacari » Sun Feb 02, 2014 3:06 am
Hello All,
can anyone advise if this plugin is working??..I have downloaded it from the link and added it. I have read through all the posts and but can not get it working. I install and configure using imap for gmail, when I try to setup a send email action, the "ok" box is always not clickable although I filled in all required fields. This is also the case for start observation...thanks for any help that can be offered.
Re: E-mail
Post by Pako » Sat Feb 08, 2014 9:46 am
dacari wrote:when I try to setup a send email action, the "ok" box is always not clickable although I filled in all required fields
This means that you have it configured incorrectly.
But we do not know why.
You can put screenshot?
dacari
Re: E-mail
Post by dacari » Sun Feb 09, 2014 3:50 am
Screencaps:
Thanks for the help
Re: E-mail
Post by Pako » Sun Feb 09, 2014 6:55 am
You have filled recipient's name, but the address is empty.
dacari
Re: E-mail
Post by dacari » Sun Feb 09, 2014 2:32 pm
AAhhh...silly me!!..it works!!..thank you very much
wuffzack
Re: E-mail
Post by wuffzack » Sat Aug 23, 2014 1:19 pm
Dear Pako,
I found a bug in your E-Mail plugin. Sending to multiple recipients doesn't work, because you pass the recipients as a string with comma delimited items, but smtp.sendmail expects a python list.
Instead of writing
                if Copy is None:
                    smtp.sendmail(account[3], To, msg.as_string())
you can change it to
                if Copy is None:
                    rcpnt = To.split(',')
                    smtp.sendmail(account[3], rcpnt, msg.as_string())
Same is true for the "else" case (which I can't test, I have no idea, when this code is reached).
Thank you!
Re: E-mail
Post by Pako » Sat Aug 23, 2014 1:41 pm
wuffzack wrote:I found a bug in your E-Mail plugin.
There is certainly a lot of bugs.
I made ​​this plugin a long time ago and my Python skills were very weak.
I thank you for reporting.
shaggy79
Re: E-mail
Post by shaggy79 » Thu Jan 28, 2016 8:24 pm
Hi all,
Can anyone tell me what I am doing wrong as I cant seem to send Emails :?:
I get this Error:-
SMTP Protocol Error: Your message may not have been sent!
I am trying to get it to work with my gmail account :oops:
Paul.
