E-mail
cfull1
Re: E-mail
Post by cfull1 » Fri Sep 10, 2010 3:01 pm
Hey I'm having some problems setting up my gmail account with your email plugin.
Whenever I try to send a email eventghost gives me this
Exception in thread SendMailThread:
File "threading.pyc", line 525, in __bootstrap_inner
File "C:\Program Files (x86)\EventGhost\plugins\Email\__init__.py", line 2278, in run
NameError: global name 'text' is not defined
I've matched google's email set up instructions, but still nothing.
It's weird because I had it working at one point and now its not.
This is a really cool plugin I would like to implement, any help you could give me I would appreciate.
Re: E-mail
Post by Pako » Sat Sep 11, 2010 6:11 am
You can download a corrected version.
The problem was that the plugin was trying to write an error message SMTP Protocol Error: Cannot connect to SMTP server "XXXXX".
cfull1
Re: E-mail
Post by cfull1 » Sat Sep 11, 2010 6:06 pm
Ah. Where can I find a corrected version to download?
I've tried your original link, but it doesn't fix the error. I've looked everywhere
The version I have right now is 0.1.6
Thanks Pako
Re: E-mail
Post by Pako » Sat Sep 11, 2010 8:45 pm
cfull1 wrote:Ah. Where can I find a corrected version to download ?
Here.
cfull1
Re: E-mail
Post by cfull1 » Sun Sep 12, 2010 6:13 pm
Ok I downloaded the updated version 0.1.7, but now it won't connect to google's servers
IMAP Protocol Error: Cannot connect to IMAP server "imap.gmail.com:993"
SMTP Protocol Error: Cannot connect to SMTP server "smtp.gmail.com:587"
I've checked all the settings and restarted my computer and eventghost.
Any thoughts?
Re: E-mail
Post by Pako » Mon Sep 13, 2010 7:59 am
If it worked before, look for an problem somewhere outside the plugin (eg firewall).
Inside of the plugin is done no change except that the former plugin
could not write error message xxxx Protocol Error: Cannot connect to xxxx server "XXXXX" and now he can.
cfull1
Re: E-mail
Post by cfull1 » Mon Sep 13, 2010 3:31 pm
Ah you know what I bet my school blocks the port.
dang that sucks
Thanks for your help though pako
skrantz71
Re: E-mail
Post by skrantz71 » Fri Sep 24, 2010 8:16 pm
Problem..
When I try to add a account I never could press the OK button?
Every feild is filled out?
any ideas?
Re: E-mail
Post by Pako » Sat Sep 25, 2010 10:07 am
I can advise is difficult, if not see it.
Maybe missing outgoing SMTP server.
jofan
Re: E-mail
Post by jofan » Thu Oct 14, 2010 1:36 pm
I have just discovered Eventghost and still finding my way around, but so far it is amazing.
I could really make use of the email plugin (a great idea also) but i cannot get it to connect to my server.
POP3 Protocol Error: Cannot connect to POP server "pop3.live.com:995"
I am using a hotmail account, pop3.live.com, and as far as i am aware i have copied all my settings correctly from my outlook account but the plugin will not connect?
Any help with this appreciated.
J
Re: E-mail
Post by Pako » Thu Oct 14, 2010 3:56 pm
I was forced to create a hotmail account so I can try.
I have not seen any problem. This way account setup (as in the following pictures) is operating normally.
If you did not work, look for a problem such as a firewall.
jofan
Re: E-mail
Post by jofan » Thu Oct 14, 2010 9:16 pm
Thanks for the quick reply.
I have tried your settings and unfortunately i still get the same connection error.
As far as i am aware, my settings are correct as they work ok in other mail apps.
I have also tried disabling my firewall and this makes no difference.
My hotmail account is a co.uk rather than .com if this makes any difference also?
Would be great to know if anyone else has had success using an hotmail.co.uk account?
Regards, J
jofan
Re: E-mail
Post by jofan » Fri Oct 15, 2010 7:26 am
Hi Pako, success at last.
Not sure what i've done different but it is now working - thank you.
Just a couple of questions...
I would like to be notified about how many unread emails i have however it appears that i am being notified of all the emails in my inbox? is this correct?
Also, can this notification then be passed to the text to speech plugin so that i can then be told that i have 'x' emails for example?
Please note that i am intending to learn up on the python script but at this stage i am very limited with it!
J
Re: E-mail
Post by Pako » Fri Oct 15, 2010 10:11 am
Unfortunately, POP protocol does not distinguish whether the messages are seen or unseen, if left on the server.
Set your e-mail client so that messages on server after downloading deleted.
For example, in Mozilla Thunderbird is setup as follows:
jofan
Re: E-mail
Post by jofan » Fri Oct 15, 2010 12:43 pm
Thats a shame about the limitation of hotmail, otherwise that would have been a nice feature for me.
Just a thought, I saw on previous posts about a possible Windows Messenger plug in?
Is this something you are likely to develop at all?
I know on the main messenger window this shows the number of unread emails, could this be 'tapped into' in any way?
Regards, J
