Dresden Electronics - deConZ Plugin
Medy
Post by Medy » Thu Oct 22, 2020 4:47 pm
deConZ Plugin v 0.1
This Plugin connects to the deconz Api via websocket.
What is deconZ ? :
You have acces to a wide range of Zigbee devices locally.
Combine that with Eventghost ... and you have an easy to use Home Automation
Requirements
-deConZ
-Conbee II Stick
v.0.1 - Sensor Events
- for now the Plugin only generates events for changes
- the plugin has no actions as of now
tested with sensors : Xiomi Aqara Multisensor , Door Windows Sensor , Xiaomi Cube
Info:
These devices occasionally send updates on idle as well ...
Planned Update
- Plugin Query Action - to request data yourself
Install
- Setup your devices in the deconz App
> Download plugin file from my Google Drive link
> install via the .egplugin file ... Done ... Events will be generated on changes
NOTE : For now you need to adjust the ip and port yourself ... I hardcoded ws://192.168.1.112:443/ in the plugin :D
I will later make this automatic ...
