Webserver plugin: put something in payload?
V_J
Post by V_J » Fri May 08, 2020 4:00 pm
Small question... Is it possible to put something in the payload on an url?
I can post to the website something like this:
http://192.168.2.60/control.html?test=8
which triggers an event
HTTP.test=8 []
Is there a way to get e.g the value 8 in the payload from some formatting in the URL?
(not an issue if not, I can always parse to get the value...)
Re: Webserver plugin: put something in payload?
Post by Sem;colon » Fri May 08, 2020 5:56 pm
Hi Jörg,
try this:
http://192.168.2.60/control.html?test&8
:wink:
V_J
Post by V_J » Fri May 08, 2020 7:54 pm
What was I thinking... :oops: :roll: :?
Thanks! :)
