Chrome Browser Events
Medy
Post by Medy » Sun Dec 15, 2019 1:25 pm
What is this Plugin? :
This Plugin together with the companion Chrome Extension
allows you to control your Browser Tabs and receive Browser Tab Events.
== What is the Eventghost functionality ? ==
-> You can create , update , reload,close and move tabs from the Eventghost plugin.
== What is the Chrome Extension functionality ? ==
-> connecting with eventghost and forwarding / recieving events + do tab actions via the chrome API
Install Steps :
1. Download the Chrome Extension
https://chrome.google.com/webstore/deta ... authuser=1
2. Download the Eventghost companion plugin from attachment of this post and install it ..
3.DONE
GoogleChrome.egplugin
(9.04 KiB) Downloaded 28 times
Re: Chrome Browser Control Plugin + Chrome Extension.
Post by kgschlosser » Sun Dec 15, 2019 4:45 pm
Is this chrome only extension? or will it work on any chromium based browser?
Medy
Post by Medy » Mon Dec 16, 2019 8:27 am
In general it works with chromium based ones yes ...
You cant just copy paste across the board from my experience though ...
for opera there is a extension that supports installing chrome plugins ... which works perfectly.
Firefox you most likely have to tweak things. Though I havent tested it .. might just work
Medy
Post by Medy » Sun Dec 22, 2019 7:59 am
The chrome extension is now available in the chrome webstore :) ...
https://chrome.google.com/webstore/deta ... 2&hl=en-GB
This should make the install very easy.
1. Install extension from webstore
2- install the eventghost plugin from attachment
3, DONE ;)
Re: Chrome Browser Control + Events
Post by kgschlosser » Sun Dec 22, 2019 10:32 am
if you install visual studio code there are extensions for bug testing chrome extensions as well as firefox extensions.. I wanted to let you know that.
Medy
Post by Medy » Sun Dec 22, 2019 12:52 pm
https://code.visualstudio.com/blogs/201 ... or-vs-code
you mean this ?
haven't used the debugger yet(even though I indeed have it installed )... but in case I develop for both ... this would be useful for testing.. maybe ill get there
Post by kgschlosser » Sun Dec 22, 2019 6:24 pm
I came across that last night and thought about your project. figured it might be useful to have/use
Medy
Post by Medy » Sat Dec 28, 2019 2:27 pm
Yes it will be useful in case I ever go that route. Apriciated
dan Edens
Re: Chrome Browser Events
Post by dan Edens » Mon Feb 03, 2020 4:54 pm
I'm having issues getting the extension to install.
You seen this before?
add to chrome is greyed out x-x
Medy
Post by Medy » Wed Mar 04, 2020 4:44 pm
Sry for late reply ... not checking often
I have updated the link.
The previous one was from developer dashboard I think... Not the actuual store link
Edit : You can find the extension now if you search Browser Remote for Eventghost
its fully public ;)
