Auvisio Plugin
alex_m
Auvisio Plugin
Post by alex_m » Sat Aug 03, 2019 10:53 pm
Hi, I'm trying to install the Auvisio VRC-1100 RO plugin, but the programm report "download failed.
Can you help me?
it is essential that I install the plugin.
Alex
Re: Auvisio Plugin
Post by kgschlosser » Sun Aug 04, 2019 3:17 am
alex_m
Re: Auvisio Plugin
Post by alex_m » Sun Aug 04, 2019 8:21 am
viewtopic.php?p=53484#p53484
I have installed both USB and Win USB Addon, how can i use them to intercept remote control commands?
Re: Auvisio Plugin
Post by kgschlosser » Sun Aug 04, 2019 8:40 am
you then need to add the Auvisio plugin to your tree and it should then install the needed drivers.
Re: Auvisio Plugin
all the automatic download does is install those packages you manually downloaded and installed.
alex_m
Re: Auvisio Plugin
Post by alex_m » Sun Aug 04, 2019 10:51 am
I tried to download the Auvisio Driver, the download failed...
The log:
Error starting plugin: auvisio VRC-1100 Ro
Driver not found!
Exception in thread Thread-20:
File "C:\Program Files (x86)\EventGhost\eg\Classes\TransferDialog.py", line 281, in ThreadRun
todo = self.CreateActions()
File "C:\Program Files (x86)\EventGhost\eg\Classes\TransferDialog.py", line 152, in CreateActions
size = self.HttpGetSize(src)
File "C:\Program Files (x86)\EventGhost\eg\Classes\TransferDialog.py", line 175, in HttpGetSize
testFile = urllib2.urlopen(path)
File "urllib2.pyc", line 154, in urlopen
File "urllib2.pyc", line 435, in open
File "urllib2.pyc", line 548, in http_response
File "urllib2.pyc", line 473, in error
File "urllib2.pyc", line 407, in _call_chain
File "urllib2.pyc", line 556, in http_error_default
HTTPError: HTTP Error 404: Not Found
My OS is Windows 7 Home Premium 64bit.
alex_m
Re: Auvisio Plugin
Post by alex_m » Mon Aug 05, 2019 9:24 am
Can anyone post the 64bit driver for the Auvisio VRC-1100 RO PC-Remote?
I would try to install it manually.
hairyonion
Re: Auvisio Plugin
Post by hairyonion » Sat Aug 31, 2019 6:52 pm
Alex I have the driver at least I think i do, I am having the same issue as you after a fresh windows install.
When installing the driver I have via method detailed here viewtopic.php?p=45688#p45688 it will install and the install window looks good but eventghost still thinks the driver is not installed.
I fear I will send you down the wrong path with this file but on the off chance you get it working here it is https://www.dropbox.com/s/474bg346swri4 ... 0.zip?dl=0
I am considering either a new remote or a new raspberry pi, my pi no longer works grrrr. I can not figure out what to do next regarding the driver.
Re: Auvisio Plugin
Post by kgschlosser » Sun Sep 01, 2019 3:59 am
follow the directions in this post. It will solve your issue.
download this file and install it.
http://www.eventghost.net/downloads/Eve ... Add-on.zip
then follow the directions in this forum post.
viewtopic.php?p=53503#p53503
this will solve your problem.
hairyonion
Re: Auvisio Plugin
Post by hairyonion » Sun Sep 01, 2019 6:52 am
kgschlosser I could kiss you, thank you this fixed the problem
Re: Auvisio Plugin
Post by kgschlosser » Sun Sep 01, 2019 8:39 am
:shock:
No worries m8. This is the reason why I do what I do. Is because of the joy it brings people.
