ATI Remote Wonder II Driver Installation Error
Re: ATI Remote Wonder II Driver Installation Error
Post by kgschlosser » Thu Jun 27, 2019 5:59 am
I am not getting an error.... That is what is strange..
I am not sure as to why you are getting the HTTP error if you installed the WinUSB addon. because the program is set up so it looks for that first. and if it is not able to locate it then it tries the download.
use this link and see if a download box pops up.. I am curious to know if it does.
http://www.eventghost.net/downloads/win ... dpinst.exe
when i use that link it asks me if i want to download the file and when i click on save. it does indeed download it.
Each time you get an error please post a screen shot of it. I need to see if it is a different error message in the log. The first error you posted a screen shot of and the last one you posted a screen shot of are not the same error so progress has been made. I do not understand as to why you are getting a permissions related problem... I reset the permissions and I am able to download the file without issue. The code in the file uses the same path and filenames. so there should not be an issue there either.
Post by kgschlosser » Thu Jun 27, 2019 6:18 am
also. paste the code below into a python screip and then run the python script. this is going to duplicate the downloading portion of the drivers. It is not going to install them. I used this and it worked perfectly to download them.
import wx
from eg.Classes import WinUsb
import hashlib
import os
import threading
stopEvent = threading.Event()
neededFiles = []
for name, md5hash in WinUsb.NEEDED_FILES:
    path = os.path.join(WinUsb.INSTALLATION_ROOT, name)
    if not os.path.exists(path):
        neededFiles.append((WinUsb.DOWNLOAD_ROOT + name, path))
        continue
    md5 = hashlib.md5()
    md5.update(open(path, "rb").read())
    if md5.hexdigest() != md5hash:
wx.CallAfter(eg.TransferDialog, None, neededFiles, stopEvent)
Spross
Post by Spross » Sat Oct 12, 2019 7:16 am
Spross
Post by Spross » Sat Oct 12, 2019 7:19 am
Spross
Post by Spross » Sat Oct 12, 2019 8:31 am
Hi kgschlosser,
I have been away for a while and now ready to get back to troubleshooting this plugin. I started following your instructions from your last post.
The link you sent me is for a 64 bit system. I am not sure if I mentioned but I am using an older 32 bit system. Could this be an issue?
Also, I am not too sure how to run a python script as you mentioned below. Can this be done through Eventghost and if 'yes' can you please give me a brief explanation.
Spross
Post by kgschlosser » Sat Oct 12, 2019 4:54 pm
OK so scratch everything I said previously
download this file and install it.
http://www.eventghost.net/downloads/Eve ... Add-on.zip
then follow the directions in this forum post.
viewtopic.php?p=53503#p53503
this will solve your problem.
Spross
Post by Spross » Sat Oct 12, 2019 6:09 pm
Hi kgschlosser,
I am excited to try what you suggested but the download link you sent me is not working. Can you please report the link.
Thank you.
Spross
Post by kgschlosser » Sun Oct 13, 2019 2:35 am
I fixed the link.
Sorry about that..
Spross
Post by Spross » Fri Oct 25, 2019 5:47 am
Hi there,
I followed the instructions and am still getting the same error. I have attached a png file showing the error.
Not sure if you have any other tricks up your sleeve. Please let me know.
Spross
Post by kgschlosser » Sat Oct 26, 2019 1:18 am
what exactly did you do? This is a working solution. several other people have done it and it has been successful. so lets walk through the steps maybe you missed one.
