ATI Remote Wonder II Driver Installation Error
Spross
Post by Spross » Thu Jun 20, 2019 6:29 am
When the ATI Remote Wonder II (WinUSB) plugin is installed is request the driver installation which now fails.
I get an error which states: "The download failed! Please try again later."
Something tells me the web address for this driver has changed or the specific driver is no longer available. I am not well versed in troubleshooting but I appears that the ATI remote cannot access the Eventghost program.
Is there anyone that can shed some light on a fix fix this. It would be greatly appreciated.
Thank you.
Re: ATI Remote Wonder II Driver Installation Error
Post by kgschlosser » Sat Jun 22, 2019 12:04 pm
we had an issue with out previous host and the host disappeared. as well as our data. our backups had some kind of a glitch and there was data loss. unfortunately the drivers were included in the data loss.
Spross
Post by Spross » Sun Jun 23, 2019 6:24 am
Does this mean there is no hope for the ATI Remote Wonder II?
Please let me know cuz if this is the case I will have to find an alternative.
Spross
Post by Spross » Sun Jun 23, 2019 7:48 am
ALSO if I wanted to find this driver where would I look OR was is specially created for Eventghost?
Sorry, but my knowledge if fairly limited with respect to 'drivers' etc.
Thank you.
Spross
Post by kgschlosser » Mon Jun 24, 2019 8:59 am
The driver was made for EventGhost.
I am sure there is someone out there that has the driver. they might be willing to pull it from their windows installation and post it. then I can add it back into the website.
Post by kgschlosser » Mon Jun 24, 2019 9:11 am
scratch that last post.
I believe I located the drivers. try the download again and see if it works.
Post by kgschlosser » Mon Jun 24, 2019 9:16 am
If you are running Windows 10 and the drivers downloads and installs properly but the remote does not function then follow the instructions below.
you will need to uninstall the driver using hardware manager.
click the link below and follow the instructions exactly.
viewtopic.php?f=10&t=9658
once you are done with that run EventGhost and it should reinstall the driver again.
Spross
Post by Spross » Tue Jun 25, 2019 5:35 am
Hi kgschlosser,
I attempted to install the ATI driver from the Eventghost program and once again it says the installation failed. I believe the download driver link was not functioning (as it appeared no data at all was transferred).
Nonetheless, I have attached a JPG of the Eventghost screen and the 'log' comment area just in case this sheds some light on the issue.
Perhaps, you can send me the driver and I can attempt to install it myself.
Thanks again for looking into this.
Spross
Post by kgschlosser » Tue Jun 25, 2019 3:32 pm
you need to upgrade your version of EventGhost to 0.5. the links contained within 0.4 are no longer functioning.
Or you can go into EventGhost\classes\WinUsb.py edit the file a text editor (sublime text or notepad++) DO NOT USE Wordpad or Notepad. search the file for eventghost.org. not case sensitive. change the .org to .net
Spross
Post by Spross » Wed Jun 26, 2019 2:35 am
Hi kgschlosser,
I installed the current version of Eventghost 0.5.0 RC6 and attempted to install the ATI Remote Wonder driver and as before it fails to install.
Not sure why this keeps happening but I appreciate you assisting me. Were you able to get the driver to load on your machine?
Spross
Post by kgschlosser » Wed Jun 26, 2019 5:14 am
i have to set the permissions on the folder. I forgot to.. sorry.. :shock:
Post by kgschlosser » Wed Jun 26, 2019 5:17 am
ok i set the permissions on the folder. give it a try again and see how goes.
Spross
Post by Spross » Wed Jun 26, 2019 7:54 am
Sorry to say but I get the same "The download failed!" error.
Anything else you can suggest?
Post by kgschlosser » Wed Jun 26, 2019 3:01 pm
strange. I am going to set up a test rig. I need to see if i can get the thing to produce the error.
here is an alternate way to install the drivers.
download and install this. it will install the drivers.
http://eventghost.net/downloads/EventGh ... Add-on.zip
then restart EventGhost and see if it works.
Spross
Post by Spross » Thu Jun 27, 2019 4:02 am
Hi kgschlosser,
I tried your alternative driver installation and unfortunately that did not make a difference. I even tried installing the program (and driver) on a different Windows 10 machine and it did not work and once again received the same 'driver installation failed' message.
Perhaps if you have time you can give it a test to see if you get an error. Not sure why this is so troublesome.
Thanks again for your efforts.
Spross
