ESP-SENSOR
ESP-SENSOR
Post by Pako » Sun Jun 24, 2018 7:45 am
I have continued to work with ESP8266.
This time, I actually just upgraded my previous project (ESP-SOCKET).
I realized that the capabilities of ESP8266 were very little used there. That's why I added the HTU-21D sensor to the design.
Now the whole device can be used (for example) as a thermostat.
You can find all the material on my GitHub again.
Re: ESP-SENSOR
Post by kgschlosser » Sun Jun 24, 2018 3:03 pm
hey Pako. You like those esp things huh??? they can do a whole lot of cool things for extremely cheap.
Re: ESP-SENSOR
Post by Pako » Mon Jun 25, 2018 9:29 am
Yes it is true.
We have such a proverb - "Za málo peněz hodně muziky" ("A lot of music for just a pittance") and that is very relevant in this case.
I like the fact that it is enough to add just a few components (and some coding) and unexpectedly smart and powerful devices can be created.
Re: ESP-SENSOR
Post by kgschlosser » Mon Jun 25, 2018 4:36 pm
my only gripe with them is the power consumption at 500ma on the high side it makes using a battery and keeping a small form factor impossible. I guess it's because of the trade off for transmitting distance. I know with micropython you have the ability to sleep and wake the esp's from code. I do not know about doing it from c code. but with a 80 mhz RISC processor overclockable to 160 mhz and a lot of ram for it with ample storage in such a small footprint really opens up a world of possibilities
