Google Drive
Google Drive
Post by kgschlosser » Sun Mar 11, 2018 9:02 am
Google Drive Plugin
Version: 0.2.2b
Allows you to access the cloud based storage by Google.
There is a single limitation at the moment. It will only allow access to the root of the storage.
There are no events as of yet generated by this plugin. they will be added in the near future.
Actions:
Delete File (permanent)
Trash File
Upload Fie
Download File
List Files
Open File
Double click to install.
There are no configuration settings. Once the plugin is added to your tree it will run and your web browser will open with a request to access your google drive. this is standard practice with google in order for this plugin to access the cloud storage you need to tell google this is OK. at any point you have the ability to remove access by managing your 3rd party applications in your google account settings.
I have added some code to automatically forward a port that is needed to do the authentication. if this does not succeed you will be told that you need to do it manually. you will be given the port in a log entry in EG
UPDATES:
0.2.0b Initial release
0.2.2b Makes plugin able to work with EventGhost 0.4 and 0.5
GoogleDrive-0.2.2b.egplugin
version: 0.2.2b - EventGhost 0.4/0.5 compatibility fix
(349.56 KiB) Downloaded 56 times
GoogleDrive-0.2.0b.egplugin
version: 0.2.0b - Initial Release
(348.71 KiB) Downloaded 38 times
z3us
Re: Google Drive
Post by z3us » Sun Mar 11, 2018 5:03 pm
I get this after adding the plugin
  File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginInstanceInfo.py", line 153, in CreateInstance
    plugin.__init__()
  File "C:\ProgramData\EventGhost\plugins\GoogleDrive2\__init__.py", line 88, in __init__
    eg.folderPath.configDir,
  File "C:\Program Files (x86)\EventGhost\eg\Classes\FolderPath.py", line 90, in __getattr__
    csidl = CSIDL[name]
KeyError: 'configDir'
Plugin: Google Drive
   Exception in thread Thread-10:
  File "C:\ProgramData\EventGhost\plugins\GoogleDrive2\__init__.py", line 120, in do
    os.chdir(self.google_drive_path)
AttributeError: 'GoogleDrive' object has no attribute 'google_drive_path'
Re: Google Drive
Post by kgschlosser » Sun Mar 11, 2018 5:08 pm
AHHH I should have said this is only compatible with EG 0.5. I am sorry about that.
Re: Google Drive
Post by kgschlosser » Mon Mar 12, 2018 2:58 pm
I have made it so that the plugin should now be compatible with EG 0.4 also.
The new version is attached to the first post.
