Expand/Collapse all/children
topix
Post by topix » Wed Dec 27, 2017 6:40 pm
Is it okay to have those menus in a submenu, or should they be right in the context menu? (Wouldn't it get to big?)
Anyone who has better icons or can draw something more distinguishable?
Re: Expand/Collapse all/children
Post by kgschlosser » Thu Dec 28, 2017 10:54 pm
I think that we need to refine the context menu more. it needs to display the correct options when clicking on the various elements.
here are the current menu items
Undo
Redo
Cut
Copy
Copy as Python
Paste
Delete
Add Plugin
Add Folder
Add Macro
Add Event
Add Action
Configure Item
Rename Item
Execute Item
Disable Item
This is what i think should take place..
right click on Folder.
Undo
Redo
Cut
Copy
Paste
Delete
Add Folder
Add Macro
Rename Item
Disable Item
Right click on macro
Undo
Redo
Cut
Copy
Paste
Delete
Add Event
Add Action
Rename Item
Execute Item
Disable Item
Right click on Action
Undo
Redo
Cut
Copy
Copy as Python
Paste
Delete
Configure Item
Rename Item
Execute Item
Disable Item
Right click on Event
Undo
Redo
Cut
Copy
Paste
Delete
Configure Item
Rename Item
Disable Item
Right click on AutoStart
Undo
Redo
Paste
Add Plugin
Add Action
Right click on the root
Undo
Redo
Paste
Add Plugin
Add Folder
Add Macro
Add the expand all children and collapse all children to the folder items.
Add the expand all and collapse all to the root item
If the option is not available for a specific item then remove it from the menu. if it is available but unusable, examples are undo and redo or delete if a dialog for an item is open. then gray it out.
This is how most software works and EG should function the same way as well.right now it is set up to display a message dialog if ya do something you shouldn't be. if there is no option to do something they shouldn't be no need for the dialog. This can be done very simply by adding a CreateContextMenu method to each of the specific items. and have the item handle what it is supposed to display.
