Hello, does some one want to start with this plugin?
https://github.com/ggravlingen/pytradfri
*Request* Support for IKEA trådfri
Re: *Request* Support for IKEA trådfri
Have you tried using the hue plugin with the Ikea bridge? viewtopic.php?f=9. I suspect it may work. If not, only slight modifications should make it possible.
EDIT, after looking at some code here https://learn.pimoroni.com/tutorial/san ... om-your-pi. It's probably not gonna work out of the box, but it's close. I'll see if I can't get a command or two for you to test.
My Philips Hue plugin will not work with the IKEA Trådfri bridge. The API is diffrent. But I've seen on the web people using the Philips Hue Bridge with Trådfri lights (without the IKEA bridge). I currently don't have IKEA Trådfri so its hard to make a plugin. If I get my hands on one I will try.
