Better notification of PythonScript error
Add better identification of erroring PythonScript
Leave it the way it is.
0
No votes
Prompt to open the script.
0
No votes
Just open the script.
0
No votes
Prompt to open script and mark the line that has the fault.
5
100%
Just open the script and mark the line that has the fault.
0
No votes
I have not a clue what you are mumbling about.
0
No votes
Total votes: 5
Post by kgschlosser » Tue May 09, 2017 6:56 pm
in EG 0.5-rc2 there was a fix that was put into place. it corrected an issue where you would get a very illusive error message saying "NoneType object has no attribute PrintError". That has been fixed. But I know there are quite a few folks out there with more then one or 2 PythonScripts so trying to locate the one that has the error can be very daunting. So I had EG select the actual script that has the error. I am thinking this may not be enough for the newer users of EG. and I would like to put it to a vote on possibly adding better identification of the erroring script.
