Changes to System.DeviceAttached/System.DeviceRemoved
Add device names and other device data to System.DeviceAttached/System.DeviceRemoved
Yes
14
100%
No
0
No votes
Have no clue what I am talking about
0
No votes
Don't care
0
No votes
Total votes: 14
Re: Changes to System.DeviceAttached/System.DeviceRemoved
Post by kgschlosser » Fri Jun 23, 2017 8:38 pm
and I also wanted to specifically test to see if events get generated when you connect and disconnect a Bluetooth device
Snowbird
Post by Snowbird » Sat Jun 24, 2017 8:27 am
Here's for the one with 5 times in a row :
When Attached (TV ON)
10:21:34   System.Device.Attached.USBDevice.Home TV <dynamic-device 'USBDevice'>
10:21:34      Attached
10:21:34         Python Script
10:21:34            Name: Home TV, Description: Generic software device, Caption: Home TV, DeviceId: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, DeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, ClassGuid: {62f9c741-b25a-46ce-b54c-9bccce08b6f2}, PNPDeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB,
10:21:36   System.Device.Attached.USBDevice.Home TV <dynamic-device 'USBDevice'>
10:21:36      Attached
10:21:36         Python Script
10:21:36            Name: Home TV, Description: Generic software device, Caption: Home TV, DeviceId: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, DeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, ClassGuid: {62f9c741-b25a-46ce-b54c-9bccce08b6f2}, PNPDeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB,
10:21:38   System.Device.Attached.USBDevice.Home TV <dynamic-device 'USBDevice'>
10:21:38      Attached
10:21:38         Python Script
10:21:38            Name: Home TV, Description: Generic software device, Caption: Home TV, DeviceId: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, DeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, ClassGuid: {62f9c741-b25a-46ce-b54c-9bccce08b6f2}, PNPDeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB,
10:21:40   System.Device.Attached.USBDevice.Home TV <dynamic-device 'USBDevice'>
10:21:40      Attached
10:21:40         Python Script
10:21:40            Name: Home TV, Description: Generic software device, Caption: Home TV, DeviceId: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, DeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, ClassGuid: {62f9c741-b25a-46ce-b54c-9bccce08b6f2}, PNPDeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB,
10:21:43   System.Device.Attached.USBDevice.Home TV <dynamic-device 'USBDevice'>
10:21:43      Attached
10:21:43         Python Script
10:21:43            Name: Home TV, Description: Generic software device, Caption: Home TV, DeviceId: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, DeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, ClassGuid: {62f9c741-b25a-46ce-b54c-9bccce08b6f2}, PNPDeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB,
When Removed (TV OFF)
10:18:09   System.Device.Removed.USBDevice.Home TV <dynamic-device 'USBDevice'>
10:18:09      Removed
10:18:09         Python Script
10:18:09            Name: Home TV, Description: Generic software device, Caption: Home TV, DeviceId: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, DeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB, ClassGuid: {62f9c741-b25a-46ce-b54c-9bccce08b6f2}, PNPDeviceID: SWD\DAFUPNPPROVIDER\UUID:23810C68-DDAD-67E6-770F-8A07E1366CFB,
10:18:09      Removed
10:18:09      Removed
10:18:09      Removed
10:18:09      Removed
Regarding the error I was getting, it's not there anymore since you modified the plugin, did you fix something ?
Snowbird
Post by Snowbird » Sat Jun 24, 2017 8:52 am
kgschlosser wrote:and I also wanted to specifically test to see if events get generated when you connect and disconnect a Bluetooth device
This the feature that interests me the most as you you know :P unfortunately it doesn't work as I would like it, let me explain a bit.
1/ when I disable Bluetooth on my computer I get tons of events, and when I say tons I really mean it :) I'm pretty sure most of them appear multiple times (just like with my TV)
2/ when I re-enable Bluetooth, the same thing goes, tons of events
3/ the part that interests me, when a paired device connects or disconnects it doesn't generate any event... For example my phone is already paired with my computer, and everything is fine with its connectivity, when I disable my phone's bluetooth to simulate I left home, no events are fired ! the same goes the other way around, when I enable my phone's bluetooth to simulate I arrived home, no events are fired !
4/ is there a way to detect a non-paired bluetooth device and generate an event for it with its MAC Address as a payload ?
Post by kgschlosser » Sat Jun 24, 2017 1:19 pm
yes there is. this is why I am having you test it out. But with BT there has to be a specific things I have to code into the plugin to look for as the devices get added removed in a different manner.. Now if you delete the pairing completely and then remake it does it then show a connection for the device?
because if it does then i will have to monitor BT devices for being enabled or not.
Post by kgschlosser » Sat Jun 24, 2017 1:20 pm
and i see those tons of events but not a single one of them has tripped that script i told you to run... i need that information
Post by kgschlosser » Sat Jun 24, 2017 1:22 pm
and also. how is your TV connected to your computer? because it is coming up as a Generic software device do you have some kind of software on your computer for using your TV?
Post by kgschlosser » Sat Jun 24, 2017 1:24 pm
also what about all of these items? These are the ones that triggered as the name being None. I am going to modify the script to print out more information for me on this.
07:37:58   cls_name:  PNPEntity display_name: USB Device
07:37:59   cls_name:  PNPEntity display_name: Video Device
07:38:00   cls_name:  PNPEntity display_name: I2C Device
07:38:01   cls_name:  PNPEntity display_name: BlueTeeth Device
07:38:01   cls_name:  PNPEntity display_name: TV Tuner
07:38:01   cls_name:  PNPEntity display_name: HID Device
07:38:01   cls_name:  PNPEntity display_name: Still Capture
07:38:02   cls_name:  PNPEntity display_name: Portable
07:38:02   cls_name:  PNPEntity display_name: Imaging Device
07:38:02   cls_name:  PNPEntity display_name: EPG
07:38:02   cls_name:  PNPEntity display_name: Video Capture
07:38:03   cls_name:  PNPEntity display_name: Network Tuner
Post by kgschlosser » Sat Jun 24, 2017 10:49 pm
ok with this version it's probably not going to function 100%. the only thing i need from it is what happens with EG at startup..
this is what i am going to need you to do.
close EG if you have it open
open windows explorer (file explorer) and in the address bar type in %appdata%\EventGhost and press enter.
if you see a Log.txt file i am going to need you to delete it.
double click the attached System plugin.
then use file explorer and navigate to where you installed EG. where EventGhost.exe is located.
left click on some empty space in the right panel of the file explorer.
then hold down your left shift key and right click on that empty space and click on open command window here.
type in eventghost -debug and simply wait. in a few moments you will see all kinds of crap go flying by. when it's done close EG
then go to where that Log.txt file was there should be a new one created. attach that file to a post. or PM it to me if ya want.
System-1.2.0.egplugin
(180.19 KiB) Downloaded 105 times
Snowbird
Post by Snowbird » Sun Jun 25, 2017 9:08 am
kgschlosser wrote:and i see those tons of events but not a single one of them has tripped that script i told you to run... i need that information
I gave you a sample here :
viewtopic.php?f=5&t=9588&p=46746#p46742
the list is too long to make a screenshot or even a copy/paste, I don't want to spam the forum :)
Post by kgschlosser » Sun Jun 25, 2017 9:15 am
@Snowbird. you missed my previous post
Snowbird
Post by Snowbird » Sun Jun 25, 2017 9:16 am
kgschlosser wrote:and also. how is your TV connected to your computer? because it is coming up as a Generic software device do you have some kind of software on your computer for using your TV?
Have you ever heard of the SSDP protocol ? I think the information is gathered with the help of the Windows service called SSDP Discovery. Browse your network and you will see many network devices such as TV, Router, NAS, etc. (not necessarily computers).
Service name: SSDPSRV
Display name: SSDP Discovery
Description:
Discovers networked devices and services that use the SSDP discovery protocol, such as UPnP devices. Also
announces SSDP devices and services running on the local computer. If this service is stopped, SSDP-based
devices will not be discovered. If this service is disabled, any services that explicitly depend on it will fail to
start.
Path to executable:
C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation
https://en.wikipedia.org/wiki/Simple_Se ... y_Protocol
Post by kgschlosser » Sun Jun 25, 2017 2:09 pm
yup I know what SSDP is. but I am pretty sure I already have the duplicate events thing fixed.
I would like you to install the above attached plugin and follow the instructions i laid out in that post. this way I can get the issue with the None type in the name field sorted out.
Snowbird
Post by Snowbird » Sun Jun 25, 2017 2:26 pm
ok, here's what I get :
11:34:12: 0 MainThread: ----------------------------------------
11:34:12: 0 MainThread:         EventGhost started
11:34:12: 0 MainThread: EventGhost Version: 0.5.0-rc2
11:34:12: 0 MainThread: Machine type: AMD64
11:34:12: 0 MainThread: Processor: Intel64 Family 6 Model 37 Stepping 5, GenuineIntel
11:34:12: 0 MainThread: Architecture: ('32bit', 'WindowsPE')
11:34:12: 0 MainThread: Python:  2.7.12 CPython ('default', 'Oct 31 2016 18:42:08') [MSC v.1500 32 bit (Intel)]
Traceback (most recent call last) (0.5.0-rc2):
  File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginModuleInfo.py", line 64, in __init__
    __import__(moduleName, None, None, [''])
  File "C:\ProgramData\EventGhost\plugins\System\__init__.py", line 23, in <module>
    import Device
  File "C:\ProgramData\EventGhost\plugins\System\Device\__init__.py", line 31, in <module>
    import Devices
  File "C:\ProgramData\EventGhost\plugins\System\Device\Devices.py", line 26, in <module>
    from Notifier import DEVICES
  File "C:\ProgramData\EventGhost\plugins\System\Device\Notifier.py", line 28, in <module>
    import beautifultable
  File "C:\ProgramData\EventGhost\plugins\System\Device\beautifultable\__init__.py", line 1, in <module>
    from .beautifultable import BeautifulTable
  File "C:\ProgramData\EventGhost\plugins\System\Device\beautifultable\beautifultable.py", line 33, in <module>
    from .rows import RowData, HeaderData
  File "C:\ProgramData\EventGhost\plugins\System\Device\beautifultable\rows.py", line 4, in <module>
    from .enums import WidthExceedPolicy
  File "C:\ProgramData\EventGhost\plugins\System\Device\beautifultable\enums.py", line 1, in <module>
    import enum
ImportError: No module named enum
11:34:13: 0 MainThread: PluginManager.ScanAllPlugins :0.4790667611618597
11:34:13: 0 MainThread: SendKeysParser.__init__()
11:34:13: 0 MainMessageReceiver: MainMessageReceiver.__MainLoop()
11:34:13: 0 MainMessageReceiver: MainMessageReceiver.Setup()
11:34:13: 0 MainThread: Document.ShowFrame()
11:34:13: 0 MainThread: Log.GetData()
11:34:13: 0 MainThread: Document.ShowFrame => None
11:34:13: 0 ActionThread: ActionThread.__MainLoop()
11:34:13: 0 EventThread: EventThread.__MainLoop()
11:34:14: 0 EventThread: EventThread.StartSession(filename=u'C:\\Users\\snowbird\\Documents\\Backup\\EventGhost\\test.egtree')
11:34:14: 0 ActionThread: ActionThread.StartSession(filename=u'C:\\Users\\snowbird\\Documents\\Backup\\EventGhost\\test.egtree')
  File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionThread.py", line 79, in StartSession
    pluginInfo = eg.pluginManager.OpenPlugin(guid, None, ())
  File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginManager.py", line 52, in OpenPlugin
    clsInfo = NonexistentPluginInfo(ident, evalName)
  File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginManager.py", line 140, in __init__
    Plugin.__name__ = name
TypeError: can only assign string to Plugin.__name__, not 'NoneType'
11:34:14: 0 ActionThread: Document.Load(filePath=u'C:\\Users\\snowbird\\Documents\\Backup\\EventGhost\\test.egtree')
11:34:14: 0 MouseThread: MouseThread.run()
11:34:14: 1 MainThread: OSDFrame.__init__(parent=None)
11:34:14: 0 ActionThread: StartLoad(cls=<class 'eg.Classes.TreeLink.TreeLink'>)
11:34:14: 0 ActionThread: Document.SetExpandState(expanded=set([0, 1, 2]))
11:34:14: 0 ActionThread: XML loaded in 0.005597 seconds.
11:34:14: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
11:34:14: 0 ActionThread: ActionThread.StartSession => None
11:34:21: 1 MainThread: MainFrame.OnClose(dummyEvent=<wx.CloseEvent>)
11:34:21: 1 MainThread: App.Exit()
11:34:21: 1 MainThread: Document.CheckFileNeedsSave()
11:34:21: 1 MainThread: Document.CheckFileNeedsSave => 5100
11:34:21: 1 MainThread: Document.Close()
11:34:21: 1 MainThread: MainFrame.Destroy()
11:34:21: 1 MainThread: LogCtrl.Destroy()
11:34:21: 1 MainThread: TreeCtrl.Destroy()
11:34:21: 1 MainThread: StatusBar.Destroy()
11:34:21: 1 MainThread: StatusBar.__del__()
11:34:21: 1 MainThread: MainFrame.Destroy => True
11:34:21: 1 MainThread: Document.GetExpandState()
11:34:21: 1 MainThread: Document.Close => None
11:34:21: 1 MainThread: MainFrame.Iconize(flag=False)
11:34:21: 1 MainThread: Triggering OnClose
11:34:21: 1 MainThread: App.OnExit()
11:34:21: 1 MainThread: Calling exit functions
11:34:21: 1 MainThread: <function CloseOSD at 0x087EAEF0>
11:34:21: 1 MainThread: Calling eg.DeInit()
11:34:21: 1 MainThread: stopping threads
11:34:21: 0 ActionThread: ActionThread.StopSession()
11:34:21: 0 ActionThread: UnloadPlugins()
11:34:21: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\EventGhost
11:34:21: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Window
11:34:21: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Mouse
11:34:21: 0 ActionThread: Mouse.__stop__()
11:34:21: 0 ActionThread: Mouse.__close__()
11:34:21: 1 MainThread: shutting down
11:34:21: 0 EventThread: EventThread.__MainLoop => None
11:34:21: 0 ActionThread: ActionThread.__MainLoop => None
11:34:21: 1 MainThread: MainMessageReceiver.Stop()
11:34:21: 0 MainMessageReceiver: MainMessageReceiver.__MainLoop => None
11:34:21: 0 MouseThread: MouseThread.run => None
11:34:21: 1 MainThread: Waited for threads shutdown: 0.050914 s
11:34:21: 1 MainThread: Done!
Post by kgschlosser » Sun Jun 25, 2017 4:39 pm
Ok I see the Traceback. Don't know why it's there tho. I will have to check the file
Post by kgschlosser » Sun Jun 25, 2017 5:03 pm
Ok you will have to extract this file into your c:\program files (x86)\eventghost\lib27\site-packages folder then it should work
enum.zip
(26.43 KiB) Downloaded 73 times
