Hide tray icon
rebirth24
Re: Hide tray icon
Post by rebirth24 » Sun Jul 16, 2017 3:48 am
kgschlosser wrote:ok you can always create a script and install the keyboard plugin so you can set a specific key combination to bring it back up
so install the keyboard plugin. press the key combination you want to use to open EG back up. create a macro with a Python Command action put the code below into the action grab the event for the key combo put it into the macro.. and Viola! instant key combo shows EG again..
eg.document.ShowFrame()
and the only thing you should have to do to hide the icon is the code below. you shouldn't have to do any of that other stuff it's not necessary and could be causing the issue
 eg.taskBarIcon.Hide()
Cool thanks!
Re: Hide tray icon
Post by kgschlosser » Tue Jul 18, 2017 12:04 pm
let me know if that works for ya.
There is also an action called open EventGhost that will show EventGhost for you as well. i forgot about that
