Growl for Windows
knobblywobbly
Growl for Windows
Post by knobblywobbly » Sat Sep 17, 2011 11:51 am
Hi everyone,
Would it be possible to link EventGhost with Growl for Windows (www.growlforwindows.com). This would then allow EventGhost to send a visual message to a users PC, which could be used for confirmation of events, etc.
Unfortunately, although I love messing around with this kind of stuff, I´m not clever enough to do this kind of integration or write plugins :D
jv41
Re: Growl for Windows
Post by jv41 » Thu Sep 22, 2011 6:45 pm
There may be a more integrated solution I'm unaware of, but I use the command line to make them talk. EventGhost can make calls to executables, and growl can receive event via executable/command line with the built-in "growlnotify" command.
http://www.growlforwindows.com/gfw/help ... otify.aspx
Post by Pako » Wed Oct 19, 2011 1:40 pm
I created a display that trigger events in the program EventGhost.
Currently, I am also working on a plugin for EventGhost, which will send notifications to the Growl.
EventGhost_Display.zip
EventGhost_Display version 1.0
(28.62 KiB) Downloaded 582 times
Post by Pako » Fri Oct 21, 2011 10:45 am
I created a new plugin - Growl (Growl for Windows of course).
With this plugin you can send a notifications to Growl.
This allows you to use a lot of nice OSD to display your information.
nating
Post by nating » Sat Oct 22, 2011 8:20 pm
I have been using growl for a mac client for quite some time now and it really is working great. I am not sure if the same easy implementation can be boasted of on windows but I think it would be just the same.
Creating a display trigger would really be at the base level, if you let me. That way, it will be able to send the notifications to the growl and have it multicasted.
ralfna
Post by ralfna » Tue Dec 20, 2011 12:15 pm
Wow, a plugin for Growl, great. I´m using Growl on my Mac too, and it´s one of theese programs i missed on Windows. Growl+EventGhost...nice;)
hanspettersson
Post by hanspettersson » Wed May 14, 2014 12:30 pm
Can I Put URL links thats open when i read the message or similar from Prowl?
And Can I open a specific APP in iPhone when I read the messege from Prowl?
Post by Pako » Sat May 17, 2014 11:04 am
I'm sorry, but I have no idea how Prowl works.
I have no opportunity using it, since Apple products are unavailable to me.
BrayDavis
Post by BrayDavis » Wed Feb 03, 2016 8:53 pm
I also have no idea on Growl works. Is it a new application in Windows? Is it available on Windows 10? Or is it downloadable as an independent program?
