Shortcut to Macros/Actions on desktop please?
farbox
Post by farbox » Fri Jan 12, 2018 2:22 am
As per the discussion in this thread viewtopic.php?f=2&t=9535, it would be great if we could just have a function (drag/drop, or a right-click menu item) to create a shortcut to be placed on desktop/quick launch etc that when double clicked would simply execute that macro or action.
I'm having lots of difficulties and errors (_init.py_ etc ) using bat files, which seems a bit of a pain for something that would be so simple to implement.
Something even better would be to be able to create a desktop file/shortcut from within EG, which when clicked would act as a trigger event (just like a IR receiver event. And you could add this event as the initiator for any macro that you wish....
Perhaps a " Create desktop Event/Trigger" plugin, or add to existing EG plugins?
Would go something like this..
1- Add the "Create desktop Event/Trigger"plugin to EG
2- Double click plugin
3- In the plugin screen, enter a file name, optionally select a different icon (if you want to persoonalise it), the file location desired, and an event identifier name(which is what will show up in the EG log window)
4-A file is saved with the above characteristics (might need a new .extension???), which when clicked registers that event in EG.
Im not a coder, but I would imagine the above functions wouldn't need more than a few lines of code? The only problem I can foresee of is linking the .ext of the new file to the plugin within EG. If there is a way to do it without needing alternate file extensions, all the above would be easily achievable.
Or thinking out loud and coming back full circle, what if the plugin would just automate the creation of the .bat file (with the added facilities above?). :D :D
Re: Shortcut to Macros/Actions on desktop please?
Post by kgschlosser » Sat Jan 13, 2018 4:24 am
"c:\program files (x86)\eventghost\eventghost" -event Some.Event
that will work if you create a shortcut
farbox
Post by farbox » Sat Jan 13, 2018 5:56 am
Thanks for your reply!
I keep getting syntax errors.
This is my shortcut line
"C:\Program Files (x86)\EventGhost\EventGhost.exe" -event Start Winamp
And this is the error:
File "EventGhost.pyw", line 53, in <module>
File "C:\Program Files (x86)\EventGhost\eg\__init__.py", line 31, in <module>
import Cli
File "C:\Program Files (x86)\EventGhost\eg\Cli.py", line 172, in <module>
'eg.TriggerEvent, %s' % str(args.startupEvent)
File "C:\Program Files (x86)\EventGhost\eg\NamedPipe.py", line 253, in send_message
return eval(data)
File "<string>", line 1
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x04F4AAD0>
SyntaxError: invalid syntax
Post by kgschlosser » Sat Jan 13, 2018 9:22 am
You are missing something...
Some.Event
see the "." it has to be a single string with no spaces.
farbox
Post by farbox » Sat Jan 13, 2018 10:17 am
Tried it with the "." also, and I get this error:
import Cli
return eval(data)
import Cli
return eval(data)
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x04F4A250>
import Cli
return eval(data)
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x04DE79D0>
import Cli
return eval(data)
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x04B76B10>
import Cli
return eval(data)
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x04959AB0>
import Cli
return eval(data)
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x04DDABB0>
import Cli
return eval(data)
import Cli
return eval(data)
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x04DDACB0>
import Cli
return eval(data)
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x04F13990>
import Cli
return eval(data)
import Cli
return eval(data)
<eg.Classes.EventGhostEvent.EventGhostEvent object at 0x05021C10>
import Cli
return eval(data)
Even changed the name of my macro to Start.Winamp, still getting errors...
Im on 5.0rc3 maybe thats got something to do with it??
Post by kgschlosser » Sat Jan 13, 2018 10:49 am
yeah that problem was fixed in RC 4
farbox
Post by farbox » Sun Jan 14, 2018 12:00 am
Upgraded to RC 4, seems fine so far.
Thanks for your help!
farbox
Post by farbox » Sun Mar 17, 2019 2:10 am
Me again!
The batch files as above were working fine, but I think after upgrading to 0.5.0rc6, running the batch file launched a second instance of EG.
After a bit of research realised its a Admin/user clash, so by running EG as admin, its kind of solved.
Moved the EG shortcut to the ALL USERS startup folder, and it works fine also.
Question is, how come this behavior suddenly changed?
Post by kgschlosser » Sun Mar 17, 2019 7:27 am
ok there are several places in which you can run various portions of EG as a different user. (As administrator)
so double check the startup icon and make sure that the run as administrator is not checked off.
also check your action for running the batch file. and make sure that run as administrator is not checked off.
Nothing has changed in EEG that would warrant this behavior. II think it has to be something that changed with your setup somewhere
zian
Post by zian » Sun Mar 17, 2019 5:12 pm
(((Kevin))) again.
eventghost.net
Be there or be square.
