Z-Way Extension
Addons for the O-MEGA Project
Z-Way Extension
Post by Sem;colon » Wed Dec 30, 2020 9:22 pm
Hello all,
here is my Z-Way interface extension for the O-MEGA System.
It enables you to easily add and control Z-WAVE devices that are connected to your Z-Way gateway (RaZberry or UZB) via the O-MEGA web UI without the need to configure the devices in EventGhost.
It also has some feedback events prefiled, so you should see the feedback for your switches pretty much out of the box.
It currently supports:
- switches
- dimmers
- thermostats
- shutters
- light bulbs (multicolor)
- sensors
Requirements:
- Z-Way Webserver plugin (viewtopic.php?f=9&t=6867)
zwayweb_1_10.zip
v1.10
(4.29 KiB) Downloaded 55 times
zwayweb_1_9.zip
v1.9
(3.59 KiB) Downloaded 75 times
zwayweb_1_8.zip
v1.8
(3.52 KiB) Downloaded 84 times
Re: Z-Way Extension
Post by Sem;colon » Fri Mar 19, 2021 8:07 am
New version!
v1.9:
- bug fixes
- small improvements
Get it from the first post!
This version requires at least v1.1.3 of the Z-Way (webserver) plugin to work correctly
Re: Z-Way Extension
Post by Sem;colon » Sun May 09, 2021 7:37 pm
New version!
v1.10:
- bug fixes
- many improvements
This version requires at least O-MEGA v0.6 to work properly!
