"Show Message Box" action, possible bug ?
Snowbird
Post by Snowbird » Fri Sep 08, 2017 7:44 am
I recently found out that when you have a message box that is currently displayed, and if another instance displays a second message box, both message boxes are displayed correctly but EG freezes and throw this error :
10:47:26  ERROR: Traceback (most recent call last) (0.5.0-rc4):
10:47:26  ERROR: File "C:\Program Files (x86)\EventGhost\plugins\EventGhost\ShowMessageBox.py", line 521, in onClose
10:47:26  ERROR: self.Destroy()
10:47:26  ERROR: File "wx\_core.pyc", line 9182, in Destroy
10:47:26  ERROR: PyAssertionError: C++ assertion "IsRunning()" failed at ..\..\src\common\evtloopcmn.cpp(83) in wxEventLoopBase::Exit(): Use ScheduleExit() on not running loop
This error is easy to reproduce, just create 2 instances of "show message box" action, manually run the first one with 20 seconds timeout, then run the second one with a trigger while the first one is still running, they will both show but you will see the error.
I know it's not something very common to want to display 2 message boxes at the same time, and most people can live with it, but for the sake of perfectness I'm reporting it :)
Have a good day !
topix
Re: "Show Message Box" action, possible bug ?
Post by topix » Fri Sep 08, 2017 7:06 pm
Hmm, can't reproduce it. Can you copy and paste your test script here please.
Snowbird
Post by Snowbird » Sat Sep 09, 2017 6:58 am
Hi topix,
here's how I did it :
there is a workaround, if you press on OK on the second message box, the error won't happen, but if you let both message boxes timeout (10 seconds), you will see the error, and EG will freeze.
As I said earlier it's not a big deal, I'm not sure it is a bug, I think it's not supposed to be used the way I'm trying to.
topix
Post by topix » Sat Sep 09, 2017 8:06 pm
Well i'm interested if i can reproduce it, but wasn't able. As said, can you please copy and paste your macros here (put in a Code block), because i want to have the exact same settings for the message boxes and that makes it easier than a screenshot.
Snowbird
Post by Snowbird » Sun Sep 10, 2017 7:08 am
sure, here it is :
    <Folder Name="Testing" XML_Guid="{8928B215-3001-44B5-9343-A6633080E732}" Expanded="True">
        <Macro Name="Triggers" XML_Guid="{B3A5D930-27AD-4CAF-9A3C-79ECE7DA80B3}" Expanded="True">
            <Action XML_Guid="{B3DCB770-D161-455D-8F75-D5B360286C17}">
                EventGhost.TriggerEvent(u'box1', 0.0)
                EventGhost.TriggerEvent(u'box2', 3.0)
        <Macro Name="Display Message Box 1" XML_Guid="{D7C4886C-4682-4466-80A0-F788FA846F7A}" Expanded="True">
            <Event Name="Main.box1" XML_Guid="{D537D24F-0629-496F-8C4D-B020F56E2783}" />
            <Action XML_Guid="{47740D0B-DFF4-48F3-9AC8-2EC9975404FD}">
                EventGhost.ShowMessageBox(u'MESSAGE BOX 1', u'BOX 1', u'msg.box.1', u'{eg.Utils.time.strftime("%d/%m/%Y %H:%M:%S")}', False, 28736, 1, 10)
        <Macro Name="Display Message Box 2" XML_Guid="{43E533EA-4637-4E45-A8C3-786D2D523044}" Expanded="True">
            <Event Name="Main.box2" XML_Guid="{3F9678E2-26E6-422B-BC5D-9B190DADF7C5}" />
                EventGhost.ShowMessageBox(u'MESSAGE BOX 2', u'BOX 2', u'msg.box.2', u'{eg.Utils.time.strftime("%d/%m/%Y %H:%M:%S")}', False, 28736, 1, 10)
topix
Post by topix » Sun Sep 10, 2017 5:51 pm
Thanks. Now i'm able to reproduce it. It has something to do with both MessageBoxes being modal and that the first displayed box should be closed before the second one. If the last one is closed before the previous one, it works.
the wx widgets subsystem works with an EventLoop. A modal dialog creates a new temp eventloop. Only one can be active, so the main eventloop is deactivated. Now the second dialog again creates a new temp eventloop which deactivates the first temp eventloop. If now the first dialog should be closed, the event can't be processed, because the eventloop for this dialog is deactivated.
I've spent some time, but wasn't able to find a solution other then to make the dialog not modal.
Snowbird
Post by Snowbird » Sun Sep 10, 2017 6:29 pm
Thank you for looking into it, but honestly don't waste your time on this, it's not something very disturbing, I just wanted to report it in case there was an "easy" fix.
Post by kgschlosser » Sun Sep 10, 2017 7:16 pm
How you would fix this i think is to make the second modal a child of the first modal. Or you would have to create a new frame that you would set the style so it would not show in the task bar and call Set Transparent(0) and use that "invisible frame" as the parent for the modal.
Or use ctypes to make the dialog.
