RC3 EG freeze
RC3 EG freeze
Post by blaher » Tue Jul 11, 2017 3:35 am
This is with RC3 and Windows 10:
17:53:46: 0 MainMessageReceiver: SessionChangeNotifier.OnSessionChange(hwnd=265434, msg=689L, wparam=4L, lparam=1)
17:53:46: 0 MainMessageReceiver: SessionChangeNotifier.OnSessionChange(hwnd=265434, msg=689L, wparam=1L, lparam=1)
19:36:48: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=265434, uMsg=536L, wParam=32787L, lParam=156749016)
19:36:53: 0 MainMessageReceiver: timeout TriggerEventWait
File "threading.pyc", line 774, in __bootstrap
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 280, in __MainLoop
self.__DoOneEvent()
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 261, in __DoOneEvent
self.__PumpWaitingMessages()
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 287, in __PumpWaitingMessages
while PeekMessage(byref(msg), 0, 0, 0, PM_REMOVE):
File "C:\Program Files (x86)\EventGhost\eg\Classes\MessageReceiver.py", line 127, in WindowProc
res = handler(hwnd, mesg, wParam, lParam)
File "C:\Program Files (x86)\EventGhost\eg\Utils.py", line 428, in LogItWrapper
return func(*args, **kwargs)
File "C:\Program Files (x86)\EventGhost\plugins\System\PowerBroadcastNotifier.py", line 254, in OnPowerBroadcast
source=self.plugin
File "C:\Program Files (x86)\EventGhost\eg\Classes\EventThread.py", line 151, in TriggerEventWait
traceback.print_stack()
19:36:57: 1 MainThread: Document.ShowFrame()
19:36:57: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
19:36:58: 1 MainThread: Document.ShowFrame => None
19:37:04: 1 MainThread: Document.CheckFileNeedsSave()
19:37:04: 1 MainThread: Document.CheckFileNeedsSave => 5100
19:37:04: 1 MainThread: Document.Close()
19:37:04: 1 MainThread: MainFrame.Destroy()
19:37:04: 1 MainThread: LogCtrl.Destroy()
19:37:04: 1 MainThread: TreeCtrl.Destroy()
19:37:04: 1 MainThread: StatusBar.Destroy()
19:37:04: 1 MainThread: StatusBar.__del__()
19:37:04: 1 MainThread: MainFrame.Destroy => True
19:37:04: 1 MainThread: Document.GetExpandState()
19:37:04: 1 MainThread: Document.Close => None
19:37:04: 1 MainThread: MainFrame.Iconize(flag=False)
19:37:05: 1 MainThread: Triggering OnClose
It hung and I had to kill it in taskmanager to restart it.
Also is the latest install program supposed to uninstall the alternatemceirservice? Because if it doesn't, it can't update, or delete that folder.
Re: RC3 EG freeze
Post by kgschlosser » Tue Jul 11, 2017 12:03 pm
what were you doing when it hung?
all this states is that for some reason the action thread got hung. not why it got hung. This is the same error you keep on getting. there is something you have going on in your macros that is causing this hang. It is doing it with a lot of things. my suggestion to you is to create a new tree and one at a time move your macros until you find out which one is causing it.
Re: RC3 EG freeze
Post by kgschlosser » Tue Jul 11, 2017 12:04 pm
and we have not done anything with the alternatemceir service. this is going to resolve it's self once we put into place the plugin repo. because the alternate mceir service will be in the user plugin directory and not the core plugin directory and we will have no need to delete that folder.
Re: RC3 EG freeze
Post by blaher » Wed Jul 12, 2017 2:02 am
kgschlosser wrote:what were you doing when it hung?
I was starting Kodi and the macro contained the 'monitor on' action that seems to be a problem child. :) My tree is too big to do them one at a time, but I've deleted all instances of the monitor wakeup action, so hopefully that will fix it.
Re: RC3 EG freeze
Post by kgschlosser » Wed Jul 12, 2017 6:27 am
the thing is that monitor issue seems so specific to your setup... until... there was another bug report.. still as mysterious as yours. I am going to spend some time digging into the API for it now that I have spent wuite a bit of time working with the Windows API and have a much better understanding of how it works.
Re: RC3 EG freeze
Post by kgschlosser » Wed Jul 12, 2017 6:34 am
well well well...
look at what I have found
https://stackoverflow.com/questions/250 ... nt-turn-on
interesting. Microsoft strikes again. they broke it and never fixed it.
Re: RC3 EG freeze
Post by kgschlosser » Wed Jul 12, 2017 8:05 am
replace your plugins\System\__init__.py file with the one attached.
copy and paste the xml below into your tree and run the macro
<EventGhost Version="WIP">
    <Macro Name="Turn Off Monitor" Expanded="True">
            System.MonitorPowerOff()
            EventGhost.Wait(5.0)
            System.MonitorPowerOn()
(73.84 KiB) Downloaded 176 times
Re: RC3 EG freeze
Post by blaher » Thu Jul 13, 2017 3:35 am
That works! Well done. :)
I got an error in the log, but functionally it does the job. I changed the wait time to 10 secs, because the monitor takes quite a while to switch off fully.
13:31:14   Turn Off Monitor
13:31:14         13:31:14: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=2034904, uMsg=536L, wParam=32787L, lParam=159843264)
13:31:14      Wait: 10.0 sec(s)
13:31:19         13:31:19: 0 MainMessageReceiver: timeout TriggerEventWait
13:31:19           File "threading.pyc", line 774, in __bootstrap
13:31:19           File "threading.pyc", line 801, in __bootstrap_inner
13:31:19           File "threading.pyc", line 754, in run
13:31:19           File "C:\Program Files (x86)\EventGhost\eg\Utils.py", line 441, in LogItWithReturnWrapper
13:31:19             result = func(*args, **kwargs)
13:31:19           File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 280, in __MainLoop
13:31:19             self.__DoOneEvent()
13:31:19           File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 261, in __DoOneEvent
13:31:19             self.__PumpWaitingMessages()
13:31:19           File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 287, in __PumpWaitingMessages
13:31:19             while PeekMessage(byref(msg), 0, 0, 0, PM_REMOVE):
13:31:19           File "C:\Program Files (x86)\EventGhost\eg\Classes\MessageReceiver.py", line 127, in WindowProc
13:31:19             res = handler(hwnd, mesg, wParam, lParam)
13:31:19           File "C:\Program Files (x86)\EventGhost\eg\Utils.py", line 428, in LogItWrapper
13:31:19             return func(*args, **kwargs)
13:31:19           File "C:\Program Files (x86)\EventGhost\plugins\System\PowerBroadcastNotifier.py", line 254, in OnPowerBroadcast
13:31:19             source=self.plugin
13:31:19           File "C:\Program Files (x86)\EventGhost\eg\Classes\EventThread.py", line 151, in TriggerEventWait
13:31:19             traceback.print_stack()
13:31:24      Turn On Monitor
13:31:24   System.Monitor.Off
13:31:24   13:31:24: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=2034904, uMsg=536L, wParam=32787L, lParam=159842656)
13:31:24   System.Monitor.On
Re: RC3 EG freeze
Post by kgschlosser » Thu Jul 13, 2017 5:07 am
ok so now I know why you are getting that TriggerEventWait traceback...
this is because EG is only able to run one event at a time. and you are running an event that turned the monitor off. then have the macro wait. so the thread is in a busy state. so when the monitor shuts off it causes windows to send a notification into EG on a different thread. and when that happens it calls TriggerEventWait. which is exactly what it implies. Trigger the Event but wait for it to actually get triggered and not put into a queue. but since the macro with Wait(10.0) is holding up the works. the TriggerEventWait times out before the event from windows gets triggered. that is why you see that error. and that being said you will only see an error if you have debugging on. but another solution would be to run the script in a different thread then the action/event thread. so if you make a python script and copy and paste the code below into it then run the script. you should no longer get that error.
import threading
def run():
    import time
    eg.plugins.System.MonitorPowerOff()
    time.sleep(10)
    eg.plugins.System.MonitorPowerOn()
t = threading.Thread(target=run)
t.daemon = True
t.start()
Re: RC3 EG freeze
Post by kgschlosser » Thu Jul 13, 2017 5:11 am
@blaher
I told you i don't give up and we will get it sorted. sometimes it's a simple comment that someone else makes that sparks a thought. or one simple little tiny thing i read that makes me think a little differently. It could be 10 minutes, 10 days, or 10 years. but i will find a solution.
Re: RC3 EG freeze
Post by blaher » Sat Jul 15, 2017 3:41 am
kgschlosser wrote:@blaher
Thank you. It's much appreciated! :)
Re: RC3 EG freeze
Post by kgschlosser » Sun Jul 16, 2017 2:15 pm
no worries m8.
