[FIXED] Pasting XML directly into EventGhost tree
Diz
Post by Diz » Thu Jun 01, 2017 3:13 pm
whenever i copy from this forum i have always used that little 'select all' button at the top and i have noticed that this button always puts in an extra indent in from the left edge! this stops you being able to paste xml directly into the tree. however, if i dont use that 'select all' button and drag the mouse over the text myself to copy it then there is no extra indent and the left edge is where it is supposed to be and then it will paste directly into the tree!
Re: Pasting XML directly into EventGhost tree
Post by kgschlosser » Sun Jun 04, 2017 6:06 pm
hey Diz. add a [SOLVED] before the title on this post
