Solved: Auvisio VRC-1100 stopped working after Win 10 update 1607
Re: Auvisio VRC-1100 stopped working after Win 10 update 160
Post by kgschlosser » Wed Feb 08, 2017 6:54 pm
ok cool then i will know to look at the files on the eg server.. and i am also going to modify the WinUSB file to produce some really detailed logging so we can see what exactly is going wrong. instead of some mystery "install failed" statement
topix
Post by topix » Fri Feb 10, 2017 3:18 pm
Post by kgschlosser » Sat Feb 11, 2017 10:58 am
it very well could be... but i will tell you this.. the source files for the win usb wrapper between the 2 versions are identical. but the actual DLL's are 2 different sizes.
and the modified dates
EG 0.5 - Monday, ‎December ‎12, ‎2016, ‏‎2:34:08 PM
EG 0.4 - Monday, ‎February ‎15, ‎2016, ‏‎7:37:32 PM
So I have attached a copy if the WinUSBWrapper.dll from EG 0.4
I am not sure what versions of EG everyone is running. But the file is attached.. unzip it into the folder
YOUR_EG_INSTALL_DIR\lib27\site-packages
if you are running version 0.4 then it's not the dll file..
WinUsbWrapper.zip
(1.82 KiB) Downloaded 204 times
mrceolla
Post by mrceolla » Sun Feb 12, 2017 5:37 pm
I was running a 0.4 version :-(
Post by kgschlosser » Mon Feb 13, 2017 12:10 am
according to Microsoft if you upgraded to 1607 then the whole thing with them stopping unsigned drivers has not been turned on.. it is only if 1607 is a new install..
But Microsoft has been known to f*#$ things up quite a bit so... I am thinking from here i am going to have to modify the WinUsb.py file and add some aggressive debugging to see what is going on.
quisvir
Re: Auvisio VRC-1100 stopped working after Win 10 update 1607
Post by quisvir » Sat Oct 07, 2017 9:29 pm
Did anyone ever manage to find a definitive solution? I finally decided to upgrade my HTPC to Windows 10, only to run into this exact problem, and none of the suggestions/workarounds mentioned in this thread seem to help.
Post by kgschlosser » Sun Oct 08, 2017 6:26 am
you can try this to see if it fixes the problem. follow the direction located here
quisvir
Post by quisvir » Sun Oct 08, 2017 8:24 pm
It worked, thank you thank you thank you :)
Post by kgschlosser » Sun Oct 08, 2017 9:23 pm
where there is a will there is a way.
I am happy it solved your problem. it's good to know.
wezzix
Post by wezzix » Mon Oct 09, 2017 9:38 am
Confirmed! After disabling driver signature in BIOS, the EventGhost suggested driver install no longer instantly fails but instead shows a bright red windows warning regarding unsigned drivers. Installation then succeeds and remote works again. Yay! Sent you some beer/coffee money :)
Re: Solved: Auvisio VRC-1100 stopped working after Win 10 update 1607
Post by kgschlosser » Sat Oct 14, 2017 8:55 am
@wezzix
Thank You for the donation it is much appreciated.
Zeoch
Post by Zeoch » Fri Jun 07, 2019 9:11 am
in 2019 the download fails.
I enabled my Windows to allow all unsigned drivers but the error message says that the download failed.
How can I get the driver?
Kind regards
Rüdiger
Tschutscha
Post by Tschutscha » Mon Jul 29, 2019 1:46 pm
Hello!
I have the same problem as Zoech.
Does anyone have a solution?
Post by kgschlosser » Mon Jul 29, 2019 7:01 pm
Let me take a look at the plugin and see what it is trying to download.
Tschutscha
Post by Tschutscha » Sat Aug 03, 2019 6:22 am
Does anyone have a link where you can download the driver? I will then try to install the driver manually.
Regards
