Windows 10 issues (fixed)
Post by blaher » Thu Aug 11, 2016 5:11 am
Since moving to Windows 10, I've noticed that keyboard emulation and the Move Window, Resize Window actions don't seem to work any more. I'm using EventGhost 0.4.1.r1722.
Is it just me, or is it because Windows 10 is relatively new?
Thanks.
Re: Windows 10 issues
Post by kgschlosser » Thu Aug 11, 2016 10:52 am
windows 10 has caused numerous errors and I have been trying to sort out some of the issues. I think it would be great if one of the forum moderators would make a sticky for windows 10 problems. because they are kind of getting posted all over the place. that way they can be worked through one at a time without forgetting anyone.
and possibly a list at the beginning of that thread with a current list of known problems and if a fix has been found.
blackwind
Post by blackwind » Tue Aug 16, 2016 12:42 am
Sounds like you're trying to operate on elevated windows from an unelevated EventGhost. Run EventGhost as Administrator or disable UAC. There's nothing we can do on our end.
/bw
Post by blaher » Tue Aug 16, 2016 3:38 am
blackwind wrote:Sounds like you're trying to operate on elevated windows from an unelevated EventGhost. Run EventGhost as Administrator or disable UAC. There's nothing we can do on our end.
Thank you! That did the trick. I did have UAC disabled, but I was not running EventGhost as Admin, even though I am.
Also you have to click on the right part of the 'find window' in some applications, eg. Windows 10 Photos, or the move/resize bit won't work, or it will, but the keyboard emulation won't.
Cheers.
blackwind
Re: Windows 10 issues (fixed)
Post by blackwind » Tue Aug 16, 2016 5:28 am
It should also work if you disable UAC completely. Most people who think they've disabled UAC only have UAC notifications disabled. Unless you've set `EnableLUA` to 0, UAC is still active -- it's just not bothering you anymore.
/bw
Post by blaher » Wed Aug 17, 2016 3:22 am
blackwind wrote:It should also work if you disable UAC completely. Most people who think they've disabled UAC only have UAC notifications disabled. Unless you've set `EnableLUA` to 0, UAC is still active -- it's just not bothering you anymore.
Thanks again, this allows EventGhost to load on startup, when running as admin too. Before doing that, I had to use task scheduler to run a batch file on logon, which loaded EventGhost.
Edit: using the registry hack breaks some windows apps like photos, calculator, so the batch file method is a work around; here's mine, in case it helps others:
start "" "C:\Program Files (x86)\EventGhost\EventGhost.exe" -file "C:\Program Files (x86)\EventGhost\yourEGconfignameHERE.xml" -hide
exit
