[FIXED] OSD on Monitor 2 ( if no Monitor 2 )
Dejunai
Post by Dejunai » Wed Jun 06, 2007 11:40 am
I'm mid process of rebuilding my HTPC, all goes well, except... ( there is always an except ) when I load the previously developed XML for EG it expects a Monitor 2 for OSD messages... I seems to not be able to tell that at the moment there is no 2nd moniter... and thus results in a bunch of errors at the log level...
Any way to add a check to OSD->to->Specific->Screen that the screen exists before the failure?
no big deal.. :)
-Dejunai
Post by Bitmonster » Wed Jun 06, 2007 1:37 pm
Please post the Traceback information you get,
Dejunai
Post by Dejunai » Wed Jun 06, 2007 6:25 pm
Below is a very simple example...
Again, I can fix this no problem by enabling the 2nd monitor...
I just thought it might be something you'd want to look into...
And I neglected ( it was late ) to say just how very much appreciate EventGhost... Thank You!!!
-Dejunai
USB_UIRT.1700009E0FC0
Emulate Keystrokes: {Shift+Ctrl+F24}
Show OSD: Return from ScreenSaver
  File "wx\_core.pyc", line 13830, in <lambda>
  File "C:\EventGhost\eg\CorePlugins\EventGhost\ShowOSD.py", line 142, in ShowOSD
    d = GetMonitorDimensions()[displayNumber]
IndexError: list index out of range
Post by Bitmonster » Thu Jun 07, 2007 6:18 am
Thanks for your comments.
I have moved this topic to Bug Reports.
Will be fixed in the next beta, I guess. But since I have to finish some other restructuring of the code first, it might take a day or two.
Post by Bitmonster » Fri Jun 08, 2007 6:18 am
0.3.6.944 should handle this.
Dejunai
Post by Dejunai » Sat Jun 09, 2007 11:25 pm
I sincerely appreciate your effort, and I appreciate your continual dedication...
-Dejunai
